Siebel Business Process Framework: Workflow Guide > Reference Materials for Siebel Workflow > Reference of Workflow Policy Object Properties > Properties of the Workflow Policy ComponentThe Workflow Policy Components OBLE displays a list of workflow policy components for the parent workflow policy object currently chosen in the OBLE. The Workflow Policy Components OBLE displays both the primary policy component and nonprimary policy components and how each of the policy components are related. Table 122 describes properties displayed in the Workflow Policy Components OBLE. How the Primary Component and Non-Primary Components are Represented in the OBLEThe Primary property provides a visual indication of which component is the primary component and which components are the nonprimary components. For example, in Figure 26 the Workflow Policy Component named Account has the primary property checked, which defines Account as the primary component. Other components listed in the Workflow Policy Components OBLE are nonprimary components of the Workflow Policy Component named Account. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
