Siebel Business Process Framework: Workflow Guide > Reference Materials for Siebel Workflow > Predefined Business Services > Other Business Services used with a Workflow ProcessThis topic mentions other business services that are sometimes with a workflow process. About the Synchronous Assignment Manager Requests Business ServiceThe Synchronous Assignment Manager Requests business service is for assigning an object using Assignment Manager rules. For more information, see Siebel Assignment Manager Administration Guide. This service has one method available, Assign. This method sends a request to the assignment manager server component. Assign ArgumentsTable 89 describes Assign method arguments. Avoiding Errors Due to Locked RecordsThe Synchronous Assignment Manager Requests business service attempts to assign records that meet the appropriate criteria, even if they are locked. To prevent errors in your process due to locked records, set up a condition in your workflow process or workflow policy to skip records that do not meet the condition ASGN_USR_EXCLD_FLG = N. About the Report Business ServiceThe Report business service automates sending, scheduling, printing, saving, and emailing reports. It also automates administrative jobs such as synching new users. For more information, see Siebel Reports Administration Guide. About the FINS Data Transfer Utilities Business ServiceThe FINS Data Transfer Utilities business service allows you to transfer data from a source business component to a destination business component without using script. For more information, see Siebel Finance Guide. About the FINS Validator Business ServiceThe FINS Validator business service allows you to validate data based on predefined rules. It is developed through Application Administration, not through script. The Validator business service supports custom messages. For more information, including invoking the FINS Validator Service from a workflow, see Siebel Finance Guide. About the Dynamic UI Business ServiceThis business service and associated administration views allow you to create and render views containing a single read-only applet in the Siebel Financial Services application. For more information, see Siebel Finance Guide. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
