Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties > About Process Properties > About Process Properties and Property SetsSiebel workflow uses a structure known as the property set to pass data to and from a workflow process step. A property set is a hierarchical structure that contains name/value pairs, known as properties, at each level in the hierarchy. A process property is a container used to store data associated with the property set. Figure 13 illustrates how a process property works within a workflow process. Example usage within a workflow process is described in the following sequence:
The process property therefore manages property sets in two ways, as described in Table 13. Initial Process Property ValuesWhen a workflow process is started, process properties of type string, number, or date with an In/Out type of In or In/Out are initialized to the input property with the same name, if one exists. Hierarchy process properties with an In/Out type of In or In/Out are initialized with child input property sets that have a matching name. Process properties with their Default String set to [Value] are initialized with the value in the Value property of the input property set. Concluded Process Property ValuesWhen a workflow process concludes, process properties of type string, number, or date with an In/Out type of In or In/Out are stored as properties in the output property set. Hierarchy process properties with an In/Out type of In or In/Out are stored as child property sets. If a process property with the name [Value] is defined, the property's value is stored in the Value property of the output property set. NOTE: The process property [Value] can also be used to pass binary data in a Sub Process step. The subprocess input argument [Value] can be initialized with data in the main process then retrieved in the Sub Process step. For more information, see Passing Data To and From a Workflow Process. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
