Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties > About Process Properties > About the Multi Value Property WindowThe ways in which the Multi Value Property Window (MVPW) is used include:
Figure 12 illustrates the MVPW displaying predefined process properties, as it appears when the canvas is first opened for editing a new workflow process. To view an example that uses the MVPW, see Defining the Workflow Process. Process Properties in the MVPWWhen you click the canvas with no step or connector chosen, the child objects of the overall workflow process are displayed. The Process Properties tab in the MVPW displays the workflow's process property definitions. To view process properties associated with a workflow process
Step Arguments in the MVPWWhen you click a step in the process designer canvas, the step's input and output arguments are displayed in the MVPW. Depending on the type of step chosen, the MVPW displays one or a combination of tabs. To view step arguments displayed through the MVPW
Defining the Type Argument Field in the MVPWWhen you pick the Type argument field in the MVPW, other argument fields must be specified, depending on the value you pick. Table 15 describes the argument fields that must be specified. Changes for Siebel Version 8.0With Siebel version 8.0, the Multi Value Properties Window (MVPW) replaces the list applet in most cases in the Process Designer. Rather than viewing a step's properties by clicking the step then accessing a list applet below the canvas, you view the step's properties in the Properties window, and the step's child items in the MVPW. Rather than right-clicking a step to see the step's input and output arguments, you view them in the MVPW. You can add and delete values from within the MVPW in the same manner as was performed in previous releases in the list applets. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2008, Oracle. All rights reserved. | |
