Product Administration Guide > Multilingual Data >
Translating a Class Display Name
Use this procedure to translate the display name for the product class. To translate a class display name
- Navigate to Application Administration > Class Administration.
- Select the product class display name you want to translate.
- Click the Class Translations tab.
- In the Class Translations tab, click New.
A new record appears.
- Click in the new record's Code field and select a language code from the Language Name dialog box.
The record is updated with the language name and language code.
- Enter the translation of the display name in the Display Name field, and then click Save.
The record is updated and displays the translation of the class display name.
- Repeat these steps to create additional language translations for the class display name.
