Product Administration Guide > Multilingual Data >
Translating an Attribute Display Name and Description
Use this procedure to translate both the display name for an attribute and its description. To translate an attribute display name and description
- Navigate to Application Administration > Class Administration.
- Select the product class where the attribute you want to translate is defined.
- In Dynamic Attributes, select the attribute you want to translate.
- Click the Attribute Translations tab.
- In the Attribute Translations tab, click New.
A new record appears.
- Click in the new record's Code field and select a language code from the Language Name dialog box.
The record is updated with the language name and language code.
- Enter the translation of the display name in the Display Name field.
- Enter the translation of the description in the Description field.
- Click Save to save the record.
The record is updated and displays the translations.
- Repeat these steps to create additional language translations for this attribute's Display Name and Description.
