Siebel Database Upgrade Guide for DB2 for z/OS > Postupgrade Tasks for Siebel Database and File System > Updating File System AttachmentsEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Since Siebel CRM 7.5, filenames of attachments include the attachment table name. If an upgrade migrates the records in an attachment table to a new attachment table, you must run a utility to update the file system attachment names. Oracle provides a utility to update attachment filenames in the Siebel File System. Table 14 lists the input table name to use when you run the utility. The utility updates all files containing the table name you specify. For example, if you specify the tables S_OLDTABLE_ATT and S_NEWTABLE_ATT, the utility updates the files system attachments by copying all attachment files containing the string S_OLDTABLE_ATT to attachment files containing the string S_NEWTABLE_ATT.
To update file system attachments
For example, since |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
