Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Controls and Columns Window
The Controls/Columns window is a window that displays the controls and list columns that you can add to an applet layout if you use the Applet Layout Editor. You drag a control or list column from the Controls/Columns window to a placeholder in the Applet Layout Editor in the same way that you drag an applet from the Applets window.
If you choose a control or a list column in the Controls/Columns window, then the Properties window displays the properties for the object you choose. The Controls/Columns window includes the following items:
  • Applet. A field that displays the name of the applet.
  • Template. A field that displays the Web template that the view references.
  • Change Template. A button that opens the Choose Template dialog box that allows you to choose another Web template.
  • Edit Template. A button that opens the Web template editor. For more information, see Specifying the Web Template Editor.
  • Mode. A drop-down list that displays the view mode, such as Base or Edit.
For an example that describes usage that is similar to usage for the Controls/Column window, see Using the Applets Window.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
