Using Siebel Tools > Using Siebel Tools > Process of Setting Up the Development Environment > Specifying the Data Source That Siebel Tools UsesThis task is a step in Process of Setting Up the Development Environment. This topic describes how to specify the data source so that Siebel Tools and the Siebel Web Client connect to the same local repository. It is recommended that you maintain only one local repository for use with Siebel Tools and with this client. This configuration allows you to use this client to view and test modifications that you make in Siebel Tools. Starting with Siebel CRM version 8.0, if you extract a local repository, and if you use the default settings, then Siebel CRM encrypts the local repository. If you use Siebel Tools to download the local repository, then Siebel CRM does not automatically use the Siebel Web Client to connect to this repository. This book uses the term Siebel Web Client. You can use the Siebel Web Client or the Siebel Mobile Web Client in most topics that this book describes. For more information about these Siebel client types, see Siebel Deployment Planning Guide. To specify the data source that Siebel Tools uses
For more information about connecting Siebel Tools and the Siebel Web Client to the same local repository, see 475398.1 (Doc ID) on My Oracle Support. This document was previously published as Siebel FAQ 229. For more information about extracting a repository, see Siebel Remote and Replication Manager Administration Guide. About the Configuration FilesYou use two configuration files when you use Siebel Tools. A Siebel Business Application references a configuration file when it starts. For example, the configuration file for Siebel Call Center is uagent.cfg. Siebel CRM typically locates this configuration file in the following directory: For example, You can customize some parameters in this configuration file. Siebel Tools references the tools.cfg configuration file. You can use it to set various options, such as enabling object check out or setting default directories. It resides in the following directory: |
Using Siebel Tools | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
