B Delivered Workflow for JD Edwards EnterpriseOne Procurement Management
This appendix contains the following topics:
B.1 Delivered Workflow for JD Edwards EnterpriseOne Procurement Management
This section discusses the JD Edwards EnterpriseOne Procurement Management workflow.
B.1.1 Purchase Order Acknowledgement Approval
This section discusses the Purchase Order Acknowledgement Approval workflow.
B.1.1.1 Description
Workflow Description
During workflow processing, the system determines whether Quantity, Unit Cost, Extended Amount, or Promised Delivery Date exceeds the tolerance that is defined by the buyer. If Quantity, Unit Cost, Extended Amount, or Promised Delivery Date exceeds the tolerance, then the system changes the order line status to Awaiting Approval, as defined in the processing option, and sends the order line to the buyer's distribution list for approval.
Workflow Trigger
When the system is acknowledging an order line, if the Quantity, Unit Cost, Extended Amount, or Promised Delivery Date exceeds tolerance, then the system changes the order line status to Awaiting Approval and sends an approval message to the associated distribution list.
Workflow Action
The buyer in the distribution list receives a message in the Awaiting Approval queue in the Work Center. Upon receipt, the buyer can approve or reject the message.
B.1.1.2 Workflow Objects
System
43
Workflow Object Name
K43181
Object IDs
W43S01B, W43S01E
Event Description / Function Names
Button Clicked, Button Clicked
Sequence / Line Numbers
47, 48
B.1.2 Promised Date Change
This section discusses the Promised Date Change workflow.
B.1.2.1 Description
During workflow processing, the system sends a message to an approver if the Promised Delivery Date has changed on a purchase order.
Workflow Trigger
When the Promised Delivery Date has changed, the system sends a message to a reviewer.
Workflow Action
When the Promised Delivery Date has changed, the system sends a message to a reviewer. If the reviewer approves the date, the system updates the date. Otherwise, the system does not update the date. The system also sends a message to the originator whether the date is approved or rejected.
B.1.2.2 Workflow Objects
System
43
PROMISEDDT
Object ID
N4301790
StartWorkFlowProcessOnTheWeb
2
