This appendix contains the following topics:
This appendix provides an overview of supplier self-service programs and discusses how to set processing options for supplier self-service programs.
The supplier self-service portlets, which were delivered in previous releases of JD Edwards EnterpriseOne, are available for your use, though they function somewhat differently from the SRM portlet.
The following table lists the supplier self-service portlets and their associated applications:
This section discusses how to set processing options for:
Self Service Quote Response Entry (P4334SS).
Self-Service Supplier Analysis Summary (P43230SA).
Note: The Self-Service - Supplier Payment Inquiry program (P04111) and the Self Service - Purchase Order Inquiry program (P4310SS) are used by the SRM portlet, so the processing options for those programs are documented in the setup chapter for that portlet. Also, the Self Service - Update Address Book Record program (P01012SS) is documented in the JD Edwards EnterpriseOne Address Book Implementation Guide. |
Use these processing options to supply the default values for the Self Service Quote Response Entry program.
These processing options specify the default values that the system uses for searching and sorting quote information.
Specify the default search criteria for the Refine Quote Search option. Values are:
01: Search all quotes.
02: Search open quotes only.
03: Search closed quotes only.
04: Search quotes for which there has been no response.
Specify the default sort criteria for the refine quote sort option. Values are:
01: Sort by Quantity
02: Sort by Response Required Date
03: Sort by Quote Entered Date
04: Sort by Responded Date
05: Sort by Quote Number
Specify the default sort option for Quote Price History display. Values are:
02: Sort by Quoted Price
03: Sort by Promised Delivery Date
04: Sort by Expiration Date
These processing options specify codes that the system uses for displaying quote information.
Specify the cross-reference type code for supplier's item. The cross-reference type codes can be found in UDC 41/DT.
Specify the default date type for the Advanced Search form. The specified date type will be selected with the radio button. Values are:
1: Response Required Date
2: Quote Entered Date
3: Responded Date
Specify the Closed Status Code. All higher statuses are also consider closed. Enter a status code from UDC 40/AT.
Specify the Type Code to display the supplier's Ship To address. Enter a type code from UDC 01/W0.
These processing options specify default-processing information.
Specify the Document Type for the quotes. Enter a document type from UDC 00/DT.
Specify the number of days to calculate the From date for Advanced Search. The system subtracts the number of days specified from today's date to determine the From date.
Specify the number of records to query and display. Use this processing option wisely to maximize system performance.
Use these processing options to supply the default values for the Self-Service Supplier Analysis Summary program.
These processing options specify the default values that the system uses for displaying information.
Specify the default view for performance analysis display. If you leave this processing option blank, the quality analysis view is used. Values are:
1: Quality analysis.
2: Delivery analysis.
3: Cost analysis.
Specify the specific costing method (01 - 08) to be displayed as the inventory cost. If you leave this processing option blank, costing method 08 is used.
Specify the cost type that must be compared against the paid cost for variance information. If you leave this processing blank, ordered cost is used. Values are:
1: Inventory cost.
2: Ordered cost.
3: Receipt cost.
These processing options specify how the system displays information.
Specify the cross-reference type code to be used for displaying supplier item number. If you leave this processing option blank, the JD Edwards EnterpriseOne internal item number is displayed.
Specify the unit of measure for displaying quantities. If you leave this processing option blank, EA (each) is used.
Specify the format name for cost analysis. Based on this format name, the Key Performance Indicators for cost analysis are retrieved from the Inquiry Formats table (F5193).
Specify the format name for delivery analysis. Based on this format name, the Key Performance Indicators for delivery analysis are retrieved from the Inquiry Formats table (F5193).
Specify the format name for quality analysis. Based on this format name, the Key Performance Indicators for quality analysis are retrieved from the Inquiry Formats table (F5193).
This processing option is used to calculate the "from" month for display.
Specify the default "from" month for the View Performance Summary page. The number entered here is subtracted from the current month to calculate the "from" month.
These processing options control whether good and bad performances are highlighted
The following term applies to all of the processing options on the Delivery tab.
Specify whether you want the first column to be highlighted. If you want this column to be highlighted then you must specify the From and To values for both the Good and Bad performances. If you leave this processing option blank, 0 is used. Values are:
Blank: Do not highlight good and bad performances.
1: Highlight good and bad performances.
Column heading are retrieved from the Inquiry Formats table (F5193). Good performances are highlighted in green and bad performances are highlighted in red.
