This appendix contains the following topics:
Section B.2, "Registers and Fields for Block D (Release 9.1 Update)"
Section B.5, "Registers and Fields for Block H (Release 9.1 Update)"
Section B.6, "Registers and Fields for Block 1 (Release 9.1 Update)"
This table includes information about notas fiscais for goods:
Register Number | Field Number | Field Name | Description |
C001 | 1 | REG | Fixed value of C001. |
C001 | 2 | IND_MOV | Movement indicator. Values are:
0: Block with information 1: Block without information |
C100 | 1 | REG | Fixed value of C100. |
C100 | 2 | IND_OPER | Indicator of operation type. Values from F7611B.BNFS are:
0: Input 1: Output |
C100 | 3 | IND_EMIT | Indicator of fiscal document issue. Values are:
0: Owner issue 1: Other |
C100 | 4 | COD_PART | The system populates this field with the address book number from field 2 of register 0150. The system uses the remitter's address book record for inbound documents and the buyer's address book records for outbound documents. |
C100 | 5 | COD_MOD | Model of the fiscal document.
A value from UDC table 76B/CN. Values are: 01: Paper nota fiscal 55: BRNFI-NA 55: BRNFI-SP |
C100 | 6 | COD_SIT | Nota fiscal situation.
A value from UDC table 76B/CI. Values are: 00: Accepted 02: Canceled 04: Denied |
C100 | 7 | SER | Fiscal document series.
If the nota fiscal is a paper one and the F76B01TE table is empty, then the F7601B.BSER. If the nota fiscal has a legal number in table F76B01TE, then the system uses the series number of the nota fiscal. If the value is blank, the system completes the field with one space. |
C100 | 8 | NUM_DOC | Nota fiscal number.
If the nota fiscal is a paper one and the F76B01BTE table is empty, then the F7601B.FHBSER. If the nota fiscal has a legal number in table F76B01TE, then the system writes the character at position 9 of the legal number. |
C100 | 9 | CHV_NFE | Legal NFe key. |
C100 | 10 | DT_DOC | Issue date from F7601B.ISSU. |
C100 | 11 | DT_E_S | Input or output date.
If the nota fiscal is outbound, F7610B.BRADEJ. If the nota fiscal is inbound, F76B101.BRADLJ. |
C100 | 12 | VL_DOC | Total amount from F7601B.FHBVTN. |
C100 | 13 | IND_PGTO | Indicator of the payment type. Values are:
0: Immediate 1: Installments 9: Without payment The system completes this field with 1 if the value for the payment terms in the F03B11 and F0401 tables is 1. If the value is not 1, the system leaves this field blank. |
C100 | 14 | VL_DESC | Discount amount from F7601B.FHBDES. |
C100 | 15 | VL_ABAT_NT | Free port discount amount from F7601B.FHBDIZ. |
C100 | 16 | VL_MERC | Nota fiscal item amount from F76101B.BRAVAL. |
C100 | 17 | IND_FRT | Freight mode.
If the value in F7601B.FRTH is blank, write a value of 9 to the output file. If the value in F7601B.FRTH is not blank, write the value from the Description 02 field of UDC 76B/FO for the value that exists in F7601B.FRTH. |
C100 | 18 | VL_FRT | Freight amount from F76101B.BFRT. |
C100 | 19 | VL_SEG | Insurance amount from F76101B.BSEG. |
C100 | 20 | VL_OUT_DA | Expense amount from F76101B.BDFN. |
C100 | 21 | VL_BC_ICMS | ICMS taxable amount. SUM from F76111B.BBVL. |
C100 | 22 | VL_ICMS | ICMS amount. SUM from F76111B.BRAVCI. |
C100 | 23 | VL_BC_ICM_ST | ICMS substitute taxable amount. SUM from F76111B.BBIS. |
C100 | 24 | VL_ICMS_ST | ICMS substitute amount. SUM from F76111B.BVIS. |
C100 | 25 | VL_IPI | IPI amount. SUM from F76111B.BIPI. |
C100 | 26 | VL_PIS | PIS amount
F76B001.THBRTXA where F76B001.THBNNF = F7601B.FHBNNF and F76B001.THBSER = F7601B.FHBSER and F76B001.THN001 = F7601B.FHN001 and F76B001.THDCT = F7601B.FHDCT and F76B001.THBRTX = 05. |
C100 | 27 | VL_COFINS | COFINS amount
F76B001.THBRTXA where F76B001.THBNNF = F7601B.FHBNNF and F76B001.THBSER = F7601B.FHBSER and F76B001.THN001 = F7601B.FHN001 and F76B001.THDCT = F7601B.FHDCT and F76B001.THBRTX = 06 |
C100 | 28 | VL_PIS_ST | PIS substitute amount
The system leaves the field blank. |
C100 | 29 | VL_COFINS_ST | COFINS substitute amount
C105 | 1 | REG | Fixed value of C105. |
C105 | 2 | OPER | Operation type
The system leaves this field blank. |
C105 | 3 | UF | UF fiscal unit
C110 | 1 | REG | Fixed value of C110. |
C110 | 2 | COD_INF | Reference code (field 2 from register 0450 of block 0). |
C110 | 3 | TXT_COMPL | Complementary reference code.
Description |
C111 | 1 | REG | Fixed value of C111. |
C111 | 2 | NUM_PROC | Process identification
C111 | 3 | IND_PROC | Process indicator
C112 | 1 | REG | Fixed value of C112. |
C112 | 2 | COD_DA | Collection model document code.
C112 | 3 | UF | State
C112 | 4 | NUM_DA | Number of the collection documents.
C112 | 5 | COD_AUT | Bank authorization code
C112 | 6 | VL_DA | Expenses amount
C112 | 7 | DT_VCTO | Collection document due date
C112 | 8 | DT_PGTO | Collection document payment date
C113 | 1 | REG | Fixed value of C113. |
C113 | 2 | IND_OPER | Indicator of operation type. Values from F7611B.FDBNFS are:
C113 | 3 | IND_EMIT | Indicator of fiscal document issue. Values are:
C113 | 4 | COD_PART | The system populates this field with the address book number from field 2 of register 0150. The system uses the remitter's address book record for inbound documents and the buyer's address book record for outbound documents. |
C113 | 5 | COD_MOD | Model of the fiscal document.
C113 | 6 | SER | Fiscal document series.
If the nota fiscal is a paper one and the F76B01BTE table is empty, then the F7601B.FHBSER. If the nota fiscal has a legal number in table F76B01BTE, then the system uses the series number of the nota fiscal. |
C113 | 7 | SUB | Fiscal document subseries.
C113 | 8 | NUM_DOC | Fiscal document number.
If the nota fiscal is a paper one and the F76B01BTE table is empty, then the F7601B.FHBNNFR. If the nota fiscal has a legal number in table F76B01.BTE, then the system writes the character at position 9 of the legal number. |
C113 | 9 | DT_DOC | Issue date from F7601B.FHISSU. |
C114 | 1 | REG | Fixed value of C114. |
C114 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1
C114 | 3 | ECF_FAB | ECF serie number
C114 | 4 | ECF_CX | ECF Caixa number
C114 | 5 | NUM_DOC | Nota fiscal number
C114 | 6 | DT_DOC | Issue date
C115 | 1 | REG | Fixed value of C115. |
C115 | 2 | IND_CARGA | Indicator of carrier type
C115 | 3 | CNPJ_COL | CNPJ number of the contributor of the issue place.
C115 | 4 | IE_COL | Remit State Tax ID delivery
C115 | 5 | CPF_COL | Contributor's CPF of the issue place of the merchandise
C115 | 6 | COD_MUN_COL | Remit city. Must be a code from city table (www.ibge.gov.br)
C115 | 7 | CNPJ_ENTG | CNPJ number of the issue place
C115 | 8 | IE_ENTG | Issue CNPJ number
C115 | 9 | CPF_ENTG | CPF number of the contributor
C115 | 10 | COD_MUN_ENTG | Issue city. Must be code from city table (www.ibge.gov.br)
C116 | 1 | REG | Fixed value C116 |
C116 | 2 | COD_MOD | Model of the fiscal document.
If the nota fiscal is classical the system assigns value 01. Otherwise, depending on the Nota Fiscal type (UDC 76B/CN), the system assigns the following special handling code: BRNFI-NA : 55 BRNFI-TE : 22 BRNFEO: 55 |
C116 | 3 | NR_SAT | SAT serial number |
C116 | 4 | CHV_CFE | Coupon Fiscal Access Key |
C116 | 5 | NUM_CFE | Coupon Legal Number |
C116 | 6 | DT_DOC | Issue date |
C120 | 1 | REG | Fixed value of C120.
his register selects only Classical inbound notas fiscais; it does not select electronic notas fiscais. |
C120 | 2 | COD_DOC_IMP | Importation document type
If the value in F76B018.B76IDCT is DSI, then write 1 to the output file. If the value is other than DSI, then write 0 to the output file. |
C120 | 3 | NUM_DOC__IMP | Importation document number
The value from F76B018.B76IDOC. |
C120 | 4 | PIS_IMP | PIS amount tax
C120 | 5 | COFINS_IMP | COFINS amount tax
C120 | 6 | NUM_ACDRAW | Drawback number
C130 | 1 | REG | Fixed value of C130. |
C130 | 2 | VL_SERV_NT | Service not taxable ICMS amount.
C130 | 3 | VL_BC_ISSQN | ISSQN taxable amount.
For inbound transactions, if the value for TXTP in the F76B0401 table is 02, then use F76B0411.BRTXTT. For outbound transactions, F7611B.BBCS. |
C130 | 4 | VL_ISSQN | ISSQN amount.
For inbound transactions, if the value for TXTP in the F76B0401 table is 02, then use F76B0411.AA For outbound transactions, F7611B.BISS. |
C130 | 5 | VL_BC_IRRF | IRRF taxable amount.
Access the F76B0411 table for NOTA FISCAL INBOUND and retrieve VBBRTXTT when VBBRTXTP = 01, for NOTA FISCAL OUTBOUND - F7601B.FHBBCS. |
C130 | 6 | VL_IRRF | IRRF amount.
Inbound transactions: F76B0411.VBAA if the value of BRTXTP is equal to 01 Outbound transactions: F7601B.BIRT. |
C130 | 7 | VL_BC_PREV | INSS taxable amount.
Inbound nota fiscal: F76B0411.BRTXTT if the value for BRTXTP is 03. Outbound nota fiscal: Blank. |
C130 | 8 | VL_PREV | INSS value.
Inbound nota fiscal: F76B0411.AA if the value for BRTXTP is 03. Outbound nota fiscal: Blank |
C140 | 1 | REG | Fixed value of C140. |
C140 | 2 | IND_EMIT | Indicator of invoice issue. Values from F7611B.FDBNFS are:
C140 | 3 | IND_TIT | Indicator of the type of credit. Values are:
00: Duplicate 01: Check 02: Promissory 03: Receipt 99: Other To relate F7601B FHDCT with the values for this field, enter F7601B FHCT as Code and appropriate Special Handling Code for the type of credit in the 76B/DN UDC table. |
C140 | 4 | DESC_TIT | Complementary description of the invoice from F03B11.RPRMK. |
C140 | 5 | NUM_TIT | Invoice number from F7601B.FHBNNF + FHBSER. |
C140 | 6 | QTD_PARC | Quantity of the installments.
The number of installment records in the F03B11 for accounts receivable installments, and the number of installment records in the F0401 for accounts payable installments. |
C140 | 7 | VL_TIT | Invoice amount from F7601B.FHBVTN |
C141 | 1 | REG | Fixed value of C141. |
C141 | 2 | NUM_PARC | Installment number.
For each record written, increment the record number by 1. (Reads the installments in the F03B11 table.) |
C141 | 3 | DT_VCTO | Due date from F03B11.RPDDJ. |
C141 | 4 | VL_PARC | Installment amount from F03B11.RPAG - RPADSA. |
C160 | 1 | REG | Fixed value of C160. |
C160 | 2 | COD_PART | Carrier address number.
The value for F7601B.ANCR for the address book number from field 2 in register 0150 in block 0. |
C160 | 3 | VEIC_ID | Vehicle identification.
The last seven characters of the value at F7601B.LICP. |
C160 | 4 | QTD_VOL | Volume quantity from F7601B.FHTOQN. |
C160 | 5 | PESO_BRT | Gross weight from F76B01.FHITWT. |
C160 | 6 | PESO_LIQ | Net weight from F76B0.FHTOWT. |
C160 | 7 | UF_ID | Fiscal unit of vehicle
The first two characters of the value at F7601B.LICP. |
C165 | 1 | REG | Fixed value of C165. |
C165 | 2 | COD_PART | Carrier address number (field 2 from register 0150)
C165 | 3 | VEIC_ID | Vehicle identification
C165 | 4 | COD_AUT | SEFAZ authorization code
C165 | 5 | NR_PASSE | Number of the fiscal pass
C165 | 6 | HORA | Merchandise issue time
C165 | 7 | TEMPER | Temperature in Celsius degrees used for quantification of the volume of fuel.
C165 | 8 | QTD_VOL | Quantity of volumes carried.
C165 | 9 | PESO_BRT | Gross weight of the carried volumes (KG)
C165 | 10 | PESO_LIQ | Net weight of the carried volumes (KG)
C165 | 11 | NOM_MOT | Driver's name
C165 | 12 | CPF | CPF driver's number
C165 | 13 | UF_ID | Fiscal unit of vehicle identification
C170 | 1 | REG | Fixed value of C170. |
C170 | 2 | NUM_ITEM | Item line number from F76111B.LNID. |
C170 | 3 | COD_ITEM | Item number from F76111B.LITM. |
C170 | 4 | DESCR_COMPL | Complementary description of item.
C170 | 5 | QTD | Quantity from F76111B.UORG. |
C170 | 6 | UNID | Unit of measure from F76111B.UOM. |
C170 | 7 | VL_ITEM | Item amount from F76111B.AEXP. |
C170 | 8 | VL_DESC | Discount amount from F76111B.BDES. |
C170 | 9 | IND_MOV | Indicator of movement. Values are:
0: Real 1: Symbolic |
C170 | 10 | CST_ICMS | State tax situation from F76111B.BST1. |
C170 | 11 | CFOP | Transaction nature from F76111B.BRNOP. |
C170 | 12 | COD_NAT | F7611B BNOP concatenated to F7611B BSOP |
C170 | 13 | VL_BC_ICMS | ICMS taxable amount from F76111B.BBCL. |
C170 | 14 | ALIQ_ICMS | ICMS rate from F76111B.BRAAIC. |
C170 | 15 | VL_ICMS | ICMS amount from F76111B.BRAVCI. |
C170 | 16 | VL_BC_ICMS_ST | ICMS substitute taxable amount from F76111B.BBIS. |
C170 | 17 | ALIQ_ST | ICMS substitute taxable rate.
C170 | 18 | VL_ICMS_ST | IMCS substitute amount from F76111B.BVIS. |
C170 | 19 | IND_APUR | IPI index.
C170 | 20 | CST_IPI | IPI tax situation code.
The value at F76B012.B76TSIPI. If no value exists, then write the value from the Special Handling Code field of UDC 76B/CW for the value at F76111B. BRAITP. |
C170 | 21 | COD_ENQ | IPI legal code.
C170 | 22 | VL_BC_IPI | IPI taxable amount from F76111B.BBTP. |
C170 | 23 | ALIQ_IPI | IPI rate from F76111B.BRAAIP. |
C170 | 24 | VL_IPI | IPI amount from F76111B.BRBIPI. |
C170 | 25 | CST_PIS | PIS tax situation.
The value from F76B012.B76TSPIS. If no value exists, then write 03 to the output file. |
C170 | 26 | VL_BC_PIS | PIS taxable amount
F76B011.TDBRTXB where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = "05" |
C170 | 27 | ALIQ_PIS | PIS rate
F76B011.TDBRTXR where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = "05" |
C170 | 28 | QUANT_BC_PIS | PIS quantity.
C170 | 29 | ALIQ_PIS | PIS rate in money.
C170 | 30 | VL_PIS | F76B011.TDBRTXA where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = "05" |
C170 | 31 | CST_COFINS | Cofins tax situation.
The value from F76B012.B76TSCOF. If no value exists, then write 03 to the output file. |
C170 | 32 | VL_BC_COFINS | F76B011.TDBRTXB where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = "06" |
C170 | 33 | ALIQ_COFINS | F76B011.TDBRTXR where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = ""06"" |
C170 | 34 | QUANT_BC_COFINS | Cofins quantity.
C170 | 35 | ALIQ_COFINS | Cofins rate in money.
C170 | 36 | VL_COFINS | F76B011.TDBRTXA where F76B011.TDBNNF = F7611B.FDBNNF and F76B011.TDBSER = F7611B.FDBSER and F76B011.TDN001 = F7611B.FDN001 and F76B011.TDDCT = F7611B.FDDCT and F76B011.TDLNID = F7611B.FDLNID and F76B011.TDBRTX = ""06"" |
C170 | 37 | COD_CTA | Account number.
C171 | 1 | REG | Fixed value of C171. |
C171 | 2 | NUM_TANQUE | Tanque number
C171 | 3 | QTDE | Quantity of volumes.
C172 | 1 | REG | Fixed value of C172. |
C172 | 2 | VL_BC_ISSQN | ISSQN taxable amount.
For inbound transactions, if the value of TXTP in the F76B0401 table is 02, use F76B0411.BRTXTT. For outbound transactions, F7611B.BBCS. |
C172 | 3 | ALIQ_ISSQN | ISS tax amount.
For inbound transactions, F76B0411.BRALQ. For outbound transactions, F7611B.TXR3. |
C172 | 4 | VL_ISSQN | ISSQN amount.
For inbound transactions, F76B0411.AA. For outbound transactions, F7611B.BISS. |
C173 | 1 | REG | Fixed value of C173. |
C173 | 2 | LOTE_MED | Lot number of the medicine.
C173 | 3 | QTD_ITEM | Quantity by lot.
C173 | 4 | DT_FAB | Elaboration date
C173 | 5 | DT_VAL | Expiration date
C173 | 6 | IND_MED | ICMS substitution type
C173 | 7 | TP_PROD | Product type
C173 | 8 | VL_TAB_MAX | Maximum price
C174 | 1 | REG | Fixed value of C174. |
C174 | 2 | IND_ARM | Indicator of the Firearm. Values are:
0: Allowed use 1: Not allowed use |
C174 | 3 | NUM_ARM | Firearm number
C174 | 4 | DESCR_COMPL | Description
C175 | 1 | REG | Fixed value of C175. |
C175 | 2 | IND_VEIC_OPER | Indicator of vehicle operation type. Values are:
0: Concessionary sale 1: Direct invoice 2: Direct sale |
C175 | 3 | CNPJ | CNPJ number
C175 | 4 | UF | State
C175 | 5 | CHASSI_VEIC | Frame vehicle
C176 | 1 | REG | Fixed value of C176. |
C176 | 2 | COD_MOD_ULT_E | Nota fiscal model code
C176 | 3 | NUM_DOC_ULT_E | Nota fiscal number
C176 | 4 | SER_ULT_E | Nota fiscal serial number
C176 | 5 | DT_ULT_E | Date of the transaction
C176 | 6 | COD_PART_ULT_E | Address number
C176 | 7 | QUANT_ULT_E | Item quantity
C176 | 8 | VL_UNIT_ULT_E | Item unit value
C176 | 9 | VL_UNIT_BC_ST | Unit taxable amount
C177 | 1 | REG | Fixed value of C177. |
C177 | 2 | COD_SELO_IPI | IPI control code.
C177 | 3 | QT_SELO_IPI | Quantity of control code.
C178 | 1 | REG | Fixed value of C178. |
C178 | 2 | CL_ENQ | IPI code.
C178 | 3 | VL_UNID | Value per unit
C178 | 4 | QUANT_PAD | Total quantity
C179 | 1 | REG | Fixed value of C179. |
C179 | 2 | BC_ST_ORIG_DEST | Taxable base for ICMS ST from F7611B.BBIS. |
C179 | 3 | ICMS_ST_REP | ICMS ST amount from F7611B.BVIS. |
C179 | 4 | ICMS_ST_COMPL | ICMS ST.
C179 | 5 | BC_RET | Taxable base for ICMS withholding.
C179 | 6 | ICMS_RET | ICMS ST withholding.
C190 | 1 | REG | Fixed value of C190. |
C190 | 2 | CST_ICMS | State tax situation from F76111B.BST1. |
C190 | 3 | CFOP | Transaction nature from F76111B.BRNOP. |
C190 | 4 | ALIQ_ICMS | ICMS rate from F76111B.BRAAIC. |
C190 | 5 | VL_OPR | Transaction amount.
F76111B: AEXP + BVIS + BIPI + BRATDF − BDIS − BDES |
C190 | 6 | VL_BC_IMCS | ICMS taxable amount from F76111B,BBCL. |
C190 | 7 | VL_ICMS | ICMS amount from F76111B.BRAVCI. |
C190 | 8 | VL_BC_ICMS_ST | ICMS substitute taxable amount form F76111B.BBIS. |
C190 | 9 | VL_ICMS_ST | ICMS substitute tax from F76111B.BVIS. |
C190 | 10 | VL_RED_BC | Reduced taxable amount.
C190 | 11 | VL_IPI | IPI amount from F76111B.BRBIPI. |
C190 | 12 | COD_OBS | Observation code 0460
C195 | 1 | REG | Fixed value of C195. |
C195 | 2 | COD_OBS | Fiscal observation code
C195 | 3 | TXT_COMPL | Description
C197 | 1 | REG | Fixed value of C197. |
C197 | 2 | COD_AJ | Adjust code
C197 | 3 | DESCR_COMPL_AJ | Description
C197 | 4 | COD_ITEM | Item number
C197 | 5 | VL_BC_ICMS | Taxable amount
C197 | 6 | ALIQ_ICMS | ICMS tax rate
C197 | 7 | VL_ICMS | Tax amount
C197 | 8 | VL_OUTROS | Other values
C300 | 1 | REG | Fixed value of C300. |
C300 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1
C300 | 3 | SER | Fiscal document series
C300 | 4 | SUB | Fiscal document subseries
C300 | 5 | NUM_DOC_INI | Nota fiscal number
C300 | 6 | NUM_DOC_FIN | Nota fiscal number
C300 | 7 | DT_DOC | Issue date
C300 | 8 | VL_DOC | Total amount
C300 | 9 | VL_PIS | PIS amount
C300 | 10 | VL_COFINS | COFINS amount
C300 | 11 | COD_CTA | Debit/Credit account
C310 | 1 | REG | Fixed value of C310. |
C310 | 2 | NUM_DOC_CANC | Cancel legal number
C320 | 1 | REG | Fixed value of C320. |
C320 | 2 | CST_ICMS | Tributary situation
C320 | 3 | CFOP | Transaction nature
C320 | 4 | ALIQ_ICMS | ICMS tax rate
C320 | 5 | VL_OPR | Total amount
C320 | 6 | VL_BC_ICMS | Taxable amount
C320 | 7 | VL_ICMS | ICMS amount
C320 | 8 | VL_RED_BC | Reduction amount
C320 | 9 | COD_OBS | Observation
C321 | 1 | REG | Fixed value of C321. |
C321 | 2 | COD_ITEM | Item number
C321 | 3 | QTD | Item quantity
C321 | 4 | UNID | Unit of measure
C321 | 5 | VL_ITEM | Total amount
C321 | 6 | VL_DESC | Discount amount
C321 | 7 | VL_BC_ICMS | Taxable amount
C321 | 8 | VL_ICMS | ICMS amount
C321 | 9 | VL_PIS | PIS amount
C321 | 10 | VL_COFINS | COFINS amount
C350 | 1 | REG | Fixed value of C350. |
C350 | 2 | SER | Fiscal document series
C350 | 3 | SUB_SER | Fiscal document subseries
C350 | 4 | NUM_DOC | Document number
C350 | 5 | DT_DOC | Issue date
C350 | 6 | CNPJ_CPF | CNPJ or CPF according customer or supplier.
C350 | 7 | VL_MERC | Merchandise amount of nota fiscal
C350 | 8 | VL_DOC | Total amount
C350 | 9 | VL_DESC | Total discount amount
C350 | 10 | VL_PIS | PIS amount
C350 | 11 | VL_COFINS | COFINS amount
C350 | 12 | COD_CTA | Account number
C370 | 1 | REG | Fixed value of C370. |
C370 | 2 | NUM_ITEM | Sequential item number
C370 | 3 | COD_ITEM | Item number
C370 | 4 | QTD | Quantity
C370 | 5 | UNID | Unit of measure
C370 | 6 | VL_ITEM | Total item value
C370 | 7 | VL_DESC | Total item discount value
C390 | 1 | REG | Fixed value of C390. |
C390 | 2 | CST_ICMS | State tax situation
C390 | 3 | CFOP | Transaction nature
C390 | 4 | ALIQ_ICMS | ICMS rate
C390 | 5 | VL_OPR | Operation amount
C390 | 6 | VL_BC_ICMS | ICMS taxable amount
C390 | 7 | VL_ICMS | ICMS amount
C390 | 8 | VL_RED_BC | Taxable reduction amount
C390 | 9 | COD_OBS | Observation
C400 | 1 | REG | Fixed value of C400. |
C400 | 2 | COD_MOD | Nota fiscal type
C400 | 3 | ECF_MOD | Equipment type
C400 | 4 | ECF_FAB | Serie number
C400 | 5 | ECF_CX | Caixa number
C405 | 1 | REG | Fixed value of C405. |
C405 | 2 | DT_DOC | Z reduction
C405 | 3 | CRO | Counter initial position
C405 | 4 | CRZ | Counter final position
C405 | 5 | NUM_COO_FIN | Counter number
C405 | 6 | GT_FIN | Total amount
C405 | 7 | VL_BRT | Gross total sales
C410 | 1 | REG | Fixed value of C410. |
C410 | 2 | VL_PIS | PIS amount
C410 | 3 | VL_COFINS | COFINS amount
C420 | 1 | REG | Fixed value of C420. |
C420 | 2 | COD_TOT_PAR | Totalizator code
C420 | 3 | VLR_ACUM_TOT | Total amount
C420 | 4 | NR_TOT | Totalizator number
C420 | 5 | DESCR_NR_TOT | Situation description
C425 | 1 | REG | Fixed value of C425. |
C425 | 2 | COD_ITEM | Item number
C425 | 3 | QTD | Item quantity
C425 | 4 | UNID | Unit of measure
C425 | 5 | VL_ITEM | Accumulated amount
C425 | 6 | VL_PIS | PIS amount
C425 | 7 | VL_COFINS | COFINS amount
C460 | 1 | REG | Fixed value of C460. |
C460 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
C460 | 3 | COD_SIT | Fiscal document situation according to reference table 4.1.2.
C460 | 4 | NUM_DOC | Fiscal number (CCF or COO)
C460 | 5 | DT_DOC | Issue date
C460 | 6 | VL_DOC | Total amount
C460 | 7 | VL_PIS | PIS amount
C460 | 8 | VL_COFINS | COFINS amount
C460 | 9 | CPF_CNPJ | The system leaves this field blank. |
C460 | 10 | NOM_ADQ | The system leaves this field blank. |
C470 | 1 | REG | Fixed value of C470. |
C470 | 2 | COD_ITEM | Item number (field 2 of the register 0200).
C470 | 3 | QTD | Quantity
C470 | 4 | QTD_CANC | Cancelled quantity
C470 | 5 | UNID | Unit of measure
C470 | 6 | VL_ITEM | Item amount
C470 | 7 | CST_ICMS | State tax situation, regarding reference table 4.3.1.
C470 | 8 | CFOP | Transaction nature
C470 | 9 | ALIQ_ICMS | ICMS rate
C470 | 10 | VL_PIS | PIS amount
C470 | 11 | VL_COFINS | COFINS amount
C490 | 1 | REG | Fixed value of C490. |
C490 | 2 | CST_ICMS | State tax situation, according to reference table 4.3.1.
C490 | 3 | CFOP | Transaction nature
C490 | 4 | ALIQ_ICMS | ICMS rate
C490 | 5 | VL_OPR | Operation amount
C490 | 6 | VL_BC_ICMS | Taxable amount
C490 | 7 | VL_ICMS | ICMS amount
C490 | 8 | COD_OBS | Observation
C495 | 1 | REG | Fixed value of C495. |
C495 | 2 | ALIQ_ICMS | ICMS rate
C495 | 3 | COD_ITEM | Item number
C495 | 4 | QTD | Quantity
C495 | 5 | QTD_CANC | Cancelled quantity
C495 | 6 | UNID | Unit of measure
C495 | 7 | VL_ITEM | Total amount
C495 | 8 | VL_DESC | Discount amount
C495 | 9 | VL_CANC | Cancelled amounts
C495 | 10 | VL_ACMO | Other values
C495 | 11 | VL_BC_ICMS | Taxable amount
C495 | 12 | VL_ICMS | ICMS tax amount
C495 | 13 | VL_ISEN | ICMS exempt amount
C495 | 14 | VL_NT | ICMS exempt amount
C495 | 15 | VL_ICMS_ST | ICMS exempt amount
C500 | 1 | REG | Fixed value of C500. |
C500 | 2 | IND_OPER | Indicator of operation type: Values are:
0: Input 1: Output The system leaves this field blank. |
C500 | 3 | IND_EMIT | Indicator of issue fiscal document. Values are:
0: Owner issue 1: Others The system leaves this field blank. |
C500 | 4 | COD_PART | Address number (field 2 of the register 0150; remittent in the case of input document; buyer in the case of output document.
C500 | 5 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
C500 | 6 | COD_SIT | Fiscal document situation according to reference table 4.2.1.
C500 | 7 | SER | Fiscal document series
C500 | 8 | SUB | Fiscal document subseries.
C500 | 9 | COD_CONS | Consumer class according to reference table 4.5.1.
C500 | 10 | NUM_DOC | Nota fiscal number
C500 | 11 | DT_DOC | Issue date
C500 | 12 | DT_E_S | Input or output date
C500 | 13 | VL_DOC | Total amount
C500 | 14 | VL_DESC | Discount amount
C500 | 15 | VL_FORN | Total consumption amount
C500 | 16 | VL_SERV_NT | Service not taxable ICMS amount
C500 | 17 | VL_TERC | Third payment amount
C500 | 18 | VL_DA | Expenses amount
C500 | 19 | VL_BC_ICMS | ICMS taxable amount
C500 | 20 | VL_ICMS | ICMS amount
C500 | 21 | VL_BC_ICMS_ST | Accumulated taxable amount
C500 | 22 | VL_ICMS_ST | Accumulated ICMS withheld
C500 | 23 | COD_INF | Reference code (field 2 from register 0450)
C500 | 24 | VL_PIS | PIS amount
C500 | 25 | VL_COFINS | COFINS amount
C500 | 26 | TP_LIGACAO | Connection type
C500 | 27 | COD_GRUPO_TENSAO | Tension
C510 | 1 | REG | Fixed value of C510. |
C510 | 2 | NUM_ITEM | Item line number
C510 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
C510 | 4 | COD_CLASS | Item classification of electric power according to reference table 4.4.1
C510 | 5 | QTD | Quantity
C510 | 6 | UNID | Unit of measure
C510 | 7 | VL_ITEM | Item amount
C510 | 8 | VL_DESC | Discount amount
C510 | 9 | CST_ICMS | State tax situation according to reference table 4.3.1.
C510 | 10 | CFOP | Transaction nature
C510 | 11 | VL_BC_ICMS | ICMS taxable amount
C510 | 12 | ALIQ_ICMS | ICMS rate
C510 | 13 | VL_ICMS | ICMS amount
C510 | 14 | VL_BC_ICMS_ST | Substitution base amount
C510 | 15 | ALIQ_ST | ICMS substitution tax rate
C510 | 16 | VL_ICMS_ST | Substitution amount
C510 | 17 | IND_REC | Indicator of income type. Values are:
0: Owner income 1: Third income The system leaves this field blank. |
C510 | 18 | COD_PART | Address number (field 2 of the register 0150; remittent in the case of input document; buyer in the case of output document.
C510 | 19 | VL_PIS | PIS amount
C510 | 20 | VL_COFINS | COFINS amount
C510 | 21 | COD_CTA | Account number
C590 | 1 | REG | Fixed value of C590. |
C590 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
C590 | 3 | CFOP | Transaction nature
C590 | 4 | ALIQ_ICMS | ICMS tax rate
C590 | 5 | VL_OPR | Operation total amount
C590 | 6 | VL_BC_ICMS | Operation taxable amount
C590 | 7 | VL_ICMS | Operation ICMS amount
C590 | 8 | VL_BC_ICMS_ST | Operation substitution taxable amount
C590 | 9 | VL_ICMS_ST | Operation substitution amount
C590 | 10 | VL_RED_BC | Operation reduction amount
C590 | 11 | COD_OBS | Observation
C600 | 1 | REG | Fixed value of C600. |
C600 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
C600 | 3 | COD_MUN | City code must be from city table (www.ibge.gov.br).
C600 | 4 | SER | Fiscal document series
C600 | 5 | SUB | Fiscal document subseries
C600 | 6 | COD_CONS | Consumer class according to reference table.
C600 | 7 | QTD_CONS | Quantity of consolidate documents
C600 | 8 | QTD_CANC | Quantity of cancelled documents
C600 | 9 | DT_DOC | Consolidate date
C600 | 10 | VL_DOC | Total amount
C600 | 11 | VL_DESC | Discount amount accumulated
C600 | 12 | CONS | Total consumption in KW/h
C600 | 13 | VL_FORN | Supply amount accumulated
C600 | 14 | VL_SERV_NT | Service not taxable ICMS amount
C600 | 15 | VL_TERC | Third payment amount
C600 | 16 | VL_DA | Expenses amount accumulated
C600 | 17 | VL_BC_ICMS | ICMS taxable amount accumulated
C600 | 18 | VL_ICMS | ICMS amount accumulated
C600 | 19 | VL_BC_ICMS_ST | Operation substitution taxable amount
C600 | 20 | VL_ICMS_ST | Operation substitution amount
C600 | 21 | VL_PIS | PIS amount
C600 | 22 | VL_COFINS | COFINS amount
C601 | 1 | REG | Fixed value of C601. |
C601 | 2 | NUM_DOC_CANC | Cancelled nota fiscal number
C610 | 1 | REG | Fixed value of C610. |
C610 | 2 | COD_CLASS | Item classification of electric power according to reference table.
C610 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
C610 | 4 | QTD | Quantity accumulated of the item
C610 | 5 | UNID | Unit of measure
C610 | 6 | VL_ITEM | Item amount accumulated
C610 | 7 | VL_DESC | Discount amount accumulated
C610 | 8 | CST_ICMS | State tax situation according to reference
C610 | 9 | CFOP | Transaction nature
C610 | 10 | ALIQ_ICMS | ICMS rate
C610 | 11 | VL_BC_ICMS | ICMS taxable amount accumulated
C610 | 12 | VL_ICMS | ICMS accumulated tax amount
C610 | 13 | VL_BC_ICMS_ST | ICMS substitution taxable amount accumulated
C610 | 14 | VL_ICMS_ST | ICMS withholding amount
C610 | 15 | VL_PIS | PIS amount
C610 | 16 | VL_COFINS | COFINS amount
C610 | 17 | COD_CTA | Account number
C690 | 1 | REG | Fixed value of C690. |
C690 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
C690 | 3 | CFOP | Transaction nature
C690 | 4 | ALIQ_ICMS | ICMS tax rate
C690 | 5 | VL_OPR | Total operation amount
C690 | 6 | VL_BC_ICMS | Taxable operation amount
C690 | 7 | VL_ICMS | ICMS operation amount
C690 | 8 | VL_RED_BC | Taxable reduction amount
C690 | 9 | VL_BC_ICMS_ST | Substitution tributary amount
C690 | 10 | VL_ICMS_ST | ICMS withholding amount
C690 | 11 | COD_OBS | Observation
C700 | 1 | REG | Fixed value of C700. |
C700 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
C700 | 3 | SER | Fiscal document series
C700 | 4 | NRO_ORD_INI | Initial order number
C700 | 5 | NRO_ORD_FIN | Final order number
C700 | 6 | DT_DOC_INI | Initial issue date
C700 | 7 | DT_DOC_FIN | Final issue date
C700 | 8 | NOM_MEST | Volume number
C700 | 9 | CHV_COD_DIG | Access fiscal key
C790 | 1 | REG | Fixed value of C790. |
C790 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
C790 | 3 | CFOP | Transaction nature
C790 | 4 | ALIQ_ICMS | ICMS tax rate
C790 | 5 | VL_OPR | Operation total amount
C790 | 6 | VL_BC_ICMS | Operation taxable amount
C790 | 7 | VL_ICMS | Operation ICMS amount
C790 | 8 | VL_BC_ICMS_ST | Operation substitution taxable amount
C790 | 9 | VL_ICMS_ST | ICMS withholding amount
C790 | 10 | VL_RED_BC | Operation reduction amount
C790 | 11 | COD_OBS | Observation
C791 | 1 | REG | Fixed value of C791. |
C791 | 2 | UF | State
C791 | 3 | VL_BC_ICMS_ST | ICMS substitute taxable amount
C791 | 5 | VL_ICMS_ST | ICMS substitute amount
C800 | 1 | REG | Fixed value C800 |
C800 | 2 | COD_MOD | Model of the fiscal document.
C800 | 3 | COD_SIT | Nota fiscal situation.
C800 | 4 | NUM_CFE | Coupon Legal Number |
C800 | 5 | DT_DOC | Coupon Issue Date |
C800 | 6 | VL_CFE | Fiscal Coupon amount |
C800 | 7 | VL_PIS | PIS amount |
C800 | 8 | VL_COFINS | Cofins amount |
C800 | 9 | CNPJ_CPF | CNPJ or CPF according customer/supplier |
C800 | 10 | NR_SAT | SAT serial number |
C800 | 11 | CHV_CFE | Coupon Fiscal Access Key |
C800 | 12 | VL_DESC | Discount amount |
C800 | 13 | VL_MERC | Total amount |
C800 | 14 | VL_OUT_DA | Expenses amount |
C800 | 15 | VL_ICMS | ICMS amount |
C800 | 16 | VL_PIS_ST | Substitution PIS amount |
C800 | 17 | VL_COFINS_ST | Substitution COFINS amount |
C850 | 1 | REG | Fixed value C850 |
C850 | 2 | CST_ICMS | Tributary situation |
C850 | 3 | CFOP | Transaction nature |
C850 | 4 | ALIQ_ICMS | ICMS tax rate |
C850 | 5 | VL_OPR | Transaction amount according CST_ICMS and CFOP |
C850 | 6 | VL_BC_ICMS | Operation taxable amount according CST_ICMS and CFOP |
C850 | 7 | VL_ICMS | ICMS amount according CST_ICMS and CFOP |
C850 | 8 | COD_OBS | Fiscal Observation Code |
C860 | 1 | REG | Fixed value C860 |
C860 | 2 | COD_MOD | Model of the fiscal document.
C860 | 3 | NR_SAT | SAT serial number |
C860 | 4 | DT_DOC | Issue date |
C860 | 5 | DOC_INI | Initial document number |
C860 | 6 | DOC_FIM | Final document number |
C890 | 1 | REG | Fixed value C890 |
C890 | 2 | CST_ICMS | State tax situation from F76111B.BST1 |
C890 | 3 | CFOP | Transaction nature |
C890 | 4 | ALIQ_ICMS | ICMS tax rate |
C890 | 5 | VL_OPR | Transaction amount according CST_ICMS and CFOP |
C890 | 6 | VL_BC_ICMS | Operation taxable amount according CST_ICMS and CFOP |
C890 | 7 | VL_ICMS | ICMS amount according CST_ICMS and CFOP |
C890 | 8 | COD_OBS | Fiscal observation code |
C990 | 1 | REG | Fixed value of C990. |
C990 | 2 | QTD_LIN_C | Quantity of lines in block C. |
Block D includes information about notas fiscais for telephone services. Not all of the information required in this block resides in the JD Edwards EnterpriseOne tables. This table lists only the fields that are populated from the JD Edwards EnterpriseOne tables.
Note: You must populate the other required fields in block D by running custom programming. Add your custom programs to the sequence that you set up in the SPED Fiscal Block Setup program (P76B0730). |
Register | Field Number | Field Name | Description |
D001 | 1 | REG | Fixed value of D001. |
D001 | 2 | IND_MOV | Movement indicator. Values are:
D100 | 1 | REG | Fixed value of D100. |
D100 | 2 | IND_OPER | Indicator of operation type. Values are:
D100 | 3 | IND_EMIT | Indicator of issue fiscal document. Values are:
D100 | 4 | COD_PART | The system populates this field with the address number from field 2 of register 0150.
Remittent in the case of input document; buyer in the case of output document. The system leaves this field blank. |
D100 | 5 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
D100 | 6 | COD_SIT | Fiscal document situation according to reference table 4.2.1.
D100 | 7 | SER | Fiscal document series
D100 | 8 | SUB | Fiscal document subseries
D100 | 9 | NUM_DOC | Nota fiscal number
D100 | 10 | CHV_CTE | Electronic transport document
D100 | 11 | DT_DOC | Issue date
D100 | 12 | DT_A_P | Fiscal issue date
D100 | 13 | TP_CT-e | CT type
D100 | 14 | CHV_CTE_REF | CT fiscal access key
D100 | 15 | VL_DOC | Total amount
D100 | 16 | VL_DESC | Discount amount
D100 | 17 | IND_FRT | Freight mode. Values are:
0: Payment by third party 1: Payment by emitter 2: Payment by address book number 9: Without freight |
D100 | 18 | VL_SERV | Service amount
D100 | 19 | VL_BC_ICMS | ICMS taxable amount
D100 | 20 | VL_ICMS | ICMS amount
D100 | 21 | VL_NT | Nontaxable amount
D100 | 22 | COD_INF | The system populates this field with the reference code from field 2 of register 0450.
D100 | 23 | COD_CTA | Account number
D110 | 1 | REG | Fixed value of D110. |
D110 | 2 | NUM_ITEM | Item line number
D110 | 3 | COD_ITEM | The system populates this field with the item number from field 2 of register 0150.
D110 | 4 | VL_SERV | Service amount
D110 | 5 | VL_OUT | Other values
D120 | 1 | REG | Fixed value of D120. |
D120 | 2 | COD_MUN_ORIG | Origin city of the service. Must be a code from city table (www.ibge.gov.br)
D120 | 3 | COD_MUN_DEST | Destination city of the service. Must be a code from city table (www.ibge.gov.br)
D120 | 4 | VEIC_ID | Vehicle identification
D120 | 5 | UF_ID | Fiscal unit of vehicle identification
D130 | 1 | REG | Fixed value of D130. |
D130 | 2 | COD_PART_CONSG | The system populates this field with the consignee address number from field 2 of register 0150.
D130 | 3 | COD_PART_RED | Dispatcher address number (field 2 of the register 0150; remittent in the case of input document; buyer in the case of output document)
D130 | 4 | IND_FRT_RED | Freight mode of the dispatch operation. Values are:
0: Payment by emitter 1: Payment by address number The system leaves this field blank. |
D130 | 5 | COD_MUN_ORIG | Origin city of the service. Must be a code from city table (www.ibge.gov.br)
D130 | 6 | COD_MUN_DEST | Destination city of the service. Must be a code from city table (www.ibge.gov.br)
D130 | 7 | VEIC_ID | Vehicle identification
D130 | 8 | VL_LIQ_FRT | Freight net amount
D130 | 9 | VL_SEC_CAT | Sum of the Sec/Cat amount
D130 | 10 | VL_DESP | Dispatch amount
D130 | 11 | VL_PEDG | Toll amount
D130 | 12 | VL_OUT | Other amount
D130 | 13 | VL_FRT | Total freight amount
D130 | 14 | UF_ID | Fiscal unit of vehicle identification
D140 | 1 | REG | Fixed value of D140. |
D140 | 2 | COD_PART_CONSG | The system populates this field with the consignee address number from field 2 of register 0150.
Remitter in the case of input document; buyer in the case of output document The system leaves this field blank. |
D140 | 3 | COD_MUN_ORIG | Origin city of the service. Must be a code from city table (www.ibge.gov.br)
D140 | 4 | COD_MUN_DEST | Destination city of the service. Must be a code from city table (www.ibge.gov.br)
D140 | 5 | IND_VEIC | Indicator of the type of transporter. Values are:
0: Embarkation 1: Tug The system leaves this field blank. |
D140 | 6 | VEIC_ID | Embarkation identification
D140 | 7 | IND_NAV | Indicator of navigation type
D140 | 8 | VIAGEM | Trip number
D140 | 9 | VL_FRT_LIQ | Freight amount
D140 | 10 | VL_DESP_PORT | Port expenses amount
D140 | 11 | VL_DESP_CAR_DESC | Expenses amount with load
D140 | 12 | VL_OUT | Other amount
D140 | 13 | VL_FRT_BRT | Gross freight amount
D140 | 14 | VL_FRT_MM | Additional freight amount
D150 | 1 | REG | Fixed value of D150. |
D150 | 2 | COD_MUN_ORIG | Origin city of the service. Must be a code from city table (www.ibge.gov.br)
D150 | 3 | COD_MUN_DEST | Destination city of the service. Must be a code from city table (www.ibge.gov.br)
D150 | 4 | VEIC_ID | Plane identification
D150 | 5 | VIAGEM | Trip number
D150 | 6 | IND_TFA | Indicator of the applied rate
D150 | 7 | VL_PESO_TX | Weight tax
D150 | 8 | VL_TX_TERR | Terrestrial tax amount
D150 | 9 | VL_TX_RED | Dispatch tax amount
D150 | 10 | VL_OUT | Other amount
D150 | 11 | VL_TX_ADV | Ad valorem rate amount
D160 | 1 | REG | Fixed value of D160. |
D160 | 2 | DESPACHO | Dispatch number
D160 | 3 | CNPJ_CPF_REM | CNPJ number
Remittent of the goods if addressee is services render; addressee of the goods if remittent is services render. The system leaves this field blank. |
D160 | 4 | IE_REM | State tax ID
D160 | 5 | COD_MUN_ORI | Original municipal code
D160 | 6 | CNPJ_CPF_DEST | CPF number
D160 | 7 | IE_DEST | State tax ID
D160 | 8 | COD_MUN_DEST | From municipal code
D161 | 1 | REG | Fixed value of D161. |
D161 | 2 | IND_CARGA | Indicator of carrier type.
D161 | 3 | CNPJ_CPF_COL | Remit CNPJ number
D161 | 4 | IE_COL | Remit State Tax ID delivery
D161 | 5 | COD_MUN_COL | Remit city. Must be a code from city table (www.ibge.gov.br) |
D161 | 6 | CNPJ_CPF_ENTG | Issue CNPJ number
D161 | 7 | IE_ENTG | Issue CNPJ number
D161 | 8 | COD_MUN_ENTG | Issue city. Must be a code from city table (www.ibge.gov.br)
D162 | 1 | REG | Fixed value of D162. |
D162 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
D162 | 3 | SER | Fiscal document series
D162 | 4 | NUM_DOC | Fiscal document subseries
D162 | 5 | DT_DOC | Issue date
D162 | 6 | VL_DOC | Total amount
D162 | 7 | VL_MERC | Nota fiscal item amount
D162 | 8 | QTD_VOL | Quantity of volumes
D162 | 9 | PESO_BRT | Total weight
D162 | 10 | PESO_LIQ | Net weight
D170 | 1 | REG | Fixed value of D170. |
D170 | 2 | COD_PART_CONSG | The system populates this field with the consignee address number from field 2 of register 0150.
D170 | 3 | COD_PART_RED | The system populates this field with the re-dispatcher address number from field 2 of register 0150.
D170 | 4 | COD_MUN_ORIG | Origin city of the service. Must be a code from city table (www.ibge.gov.br)
D170 | 5 | COD_MUN_DEST | Destination city of the service. Must be a code from city table (www.ibge.gov.br)
D170 | 6 | OTM | Operator register
D170 | 7 | IND_NAT_FRT | Indicator freight nature. Values are:
0: Business 1: Not business The system leaves this field blank. |
D170 | 8 | VL_LIQ_FRT | Freight amount by weight/volume.
D170 | 9 | VL_GRIS | Gris amount
D170 | 10 | VL_PDG | Toll amount
D170 | 11 | VL_OUT | Other amount
D170 | 12 | VL_FRT | Freight amount
D170 | 13 | VEIC_ID | Vehicle identification
D170 | 14 | UF_ID | Fiscal unit of vehicle identification
D180 | 1 | REG | Fixed value of D180. |
D180 | 2 | NUM_SEQ | Modal sequential number
D180 | 3 | IND_EMIT | Indicator of issue invoice. Values are:
D180 | 4 | CNPJ_CPF_EMIT | CNPJ number model emittent
D180 | 5 | UF_EMIT | State model emittent
D180 | 6 | IE_EMIT | State tax ID model emittent
D180 | 7 | COD_MUN_ORIG | Origin state of the service
D180 | 8 | CNPJ_CPF_TOM | CNPJ number services render
D180 | 9 | UF_TOM | State services render
D180 | 10 | IE_TOM | State tax ID services render
D180 | 11 | COD_MUN_DEST | Origin city of the service. Must be a code from city table (www.ibge.gov.br).
D180 | 12 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
D180 | 13 | SER | Fiscal document series
D180 | 14 | SUB | Fiscal document subseries
D180 | 15 | NUM_DOC | Nota fiscal number
D180 | 16 | DT_DOC | Issue date
D180 | 17 | VL_DOC | Total amount
D190 | 1 | REG | Fixed value of D190. |
D190 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
D190 | 3 | CFOP | Transaction nature
D190 | 4 | ALIQ_ICMS | ICMS tax rate
D190 | 5 | VL_OPR | Total operation amount
D190 | 6 | VL_BC_ICMS | Taxable operation amount
D190 | 7 | VL_ICMS | ICMS tax operation amount
D190 | 8 | VL_RED_BC | Reduction operation amount
D190 | 9 | COD_OBS | Observations
D195 | 1 | REG | Fixed value D195 |
D195 | 2 | COD_OBS | Fiscal observation code |
D195 | 3 | TXT_COMPL | Description of the supplementary observation code |
D197 | 1 | REG | Fixed value D197 |
D197 | 2 | COD_AJ | Adjustment code |
D197 | 3 | DESCR_COMPL_AJ | Description of the additional adjustment of tax document |
D197 | 4 | COD_ITEM | Item number |
D197 | 5 | VL_BC_ICMS | ICMS taxable amount |
D197 | 6 | ALIQ_ICMS | ICMS rate |
D197 | 7 | VL_ICMS | ICMS amount |
D197 | 8 | VL_OUTROS | Other values |
D300 | 1 | REG | Fixed value of D300. |
D300 | 2 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
D300 | 3 | SER | Fiscal document series
D300 | 4 | SUB | Sub fiscal document series
D300 | 5 | NUM_DOC_INI | Initial number
D300 | 6 | NUM_DOC_FIN | Final number
D300 | 7 | CST_ICMS | State tax situation
D300 | 8 | CFOP | Transaction nature
D300 | 9 | ALIQ_ICMS | ICMS rate
D300 | 10 | DT_DOC | Issue date
D300 | 11 | VL_OPR | Transaction amount
D300 | 12 | VL_DESC | Discount amount
D300 | 13 | VL_SERV | Total amount
D300 | 14 | VL_SEG | Insurance amount
D300 | 15 | VL_OUT DESP | Other values
D300 | 16 | VL_BC_ICMS | ICMS taxable amount
D300 | 17 | VL_ICMS | ICMS amount
D300 | 18 | VL_RED_BC | Reduced taxable amount
D300 | 19 | COD_OBS | Fiscal observation code
D300 | 20 | COD_CTA | Account number
D301 | 1 | REG | Fixed value of D301. |
D301 | 2 | NUM_DOC_CANC | Cancelled nota fiscal number
D310 | 1 | REG | Fixed value of D310. |
D310 | 2 | COD_MUN_ORIG | Origin state of the service
D310 | 3 | VL_SERV | Total amount
D310 | 4 | VL_BC_ICMS | ICMS taxable amount
D310 | 5 | VL_ICMS | ICMS amount
D350 | 1 | REG | Fixed value of D350. |
D350 | 2 | COD_MOD | Nota fiscal model
D350 | 3 | ECF_MOD | Equipment model
D350 | 4 | ECF_FAB | ECF serial number
D350 | 5 | ECF_CX | ECF box number
D355 | 1 | REG | Fixed value of D355. |
D355 | 2 | DT_DOC | Date of reduction Z
D355 | 3 | CRO | Counter position at restart operation
D355 | 4 | CRZ | Counter position of reduction Z
D355 | 5 | NUM_COO_FIN | Counter number of last operation day
D355 | 6 | GT_FIN | Total final amount
D355 | 7 | VL_BRT | Total sales amount without tax
D360 | 1 | REG | Fixed value of D360. |
D360 | 2 | VL_PIS | The system leaves this field blank. |
D360 | 3 | VL_COFINS | The system leaves this field blank. |
D365 | 1 | REG | Fixed value of D365. |
D365 | 2 | COD_TOT_PAR | The system leaves this field blank. |
D365 | 3 | VLR_ACUM_TOT | The system leaves this field blank. |
D365 | 4 | NR_TOT | The system leaves this field blank. |
D365 | 5 | DESCR_NR_TOT | The system leaves this field blank. |
D370 | 1 | REG | Fixed value of D370. |
D370 | 2 | COD_MUN_ORIG | Origin state of the service
D370 | 3 | VL_SERV | Total amount
D370 | 4 | QTD_BILH | Amount of emitted tickets
D370 | 5 | VL_BC_ICMS | ICMS taxable amount
D370 | 6 | VL_ICMS | ICMS amount
D390 | 1 | REG | Fixed value of D390. |
D390 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
D390 | 3 | CFOP | Transaction nature
D390 | 4 | ALIQ_ICMS | ICMS rate
D390 | 5 | VL_OPR | Transaction amount
D390 | 6 | VL_BC_ISSQN | ISSQN taxable amount
D390 | 7 | ALIQ_ISSQN | ISS tax rate
D390 | 8 | VL_ISSQN | ISSQN amount
D390 | 9 | VL_BC_ICMS | ICMS taxable amount
D390 | 10 | VL_ICMS | ICMS amount
D390 | 11 | COD_OBS | Fiscal observation code
D400 | 1 | REG | Fixed value of D400. |
D400 | 2 | COD_PART | Address number (field 2 of the register 0150)
D400 | 3 | COD_MOD | Nota fiscal model
D400 | 4 | COD_SIT | Nota fiscal situation
D400 | 5 | SER | Fiscal document series
D400 | 6 | SUB | Fiscal document subseries
D400 | 7 | NUM_DOC | Fiscal note number
D400 | 8 | DT_DOC | Issue date
D400 | 9 | VL_DOC | Total amount
D400 | 10 | VL_DESC | Discount amount accumulated
D400 | 11 | VL_SERV | Total amount
D400 | 12 | VL_BC_ICMS | ICMS taxable amount
D400 | 13 | VL_ICMS | ICMS amount
D400 | 14 | VL_PIS | PIS amount
D400 | 15 | VL_COFINS | COFINS amount
D400 | 16 | COD_CTA | Account number
D410 | 1 | REG | Fixed value of D410. |
D410 | 2 | COD_MOD | The system leaves this field blank. |
D410 | 3 | SER | Nota fiscal model
D410 | 4 | SUB | Fiscal document series
D410 | 5 | NUM_DOC_INI | Initial number
D410 | 6 | NUM_DOC_FIN | Final number
D410 | 7 | DT_DOC | Issue date
D410 | 8 | CST_ICMS | State tax situation according to reference table 4.3.1.
D410 | 9 | CFOP | Transaction nature
D410 | 10 | ALIQ_ICMS | ICMS rate
D410 | 11 | VL_OPR | Transaction amount
D410 | 12 | VL_DESC | Discount amount accumulated
D410 | 13 | VL_SERV | Total amount
D410 | 14 | VL_BC_ICMS | ICMS taxable amount
D410 | 15 | VL_ICMS | ICMS amount
D411 | 1 | REG | Fixed value of D411. |
D411 | 2 | NUM_DOC_CANC | Cancelled nota fiscal number
D420 | 1 | REG | Fixed value of D420. |
D420 | 2 | COD_MUN_ORIG | Origin state of the service
D420 | 3 | VL_SERV | Total amount
D420 | 4 | VL_BC_ICMS | ICMS taxable amount
D420 | 5 | VL_ICMS | ICMS amount
D500 | 1 | REG | Fixed value of D500. |
D500 | 2 | IND_OPER | Indicator of operation type. Values are:
0: Purchase 1: Sales Value from F7611B.BNFS |
D500 | 3 | IND_EMIT | Indicator of fiscal document issue. Values are:
D500 | 4 | COD_PART | Participant code.
D500 | 5 | COD_MOD | Model of the fiscal document according to reference table 4.1.1.
The value 22. |
D500 | 6 | COD_SIT | Nota fiscal situation.
D500 | 7 | SER | Nota fiscal series.
If the length of the value in F76B01TE.B76ELN is 13 characters, then this field is blank. If the length is 15 characters, then this field includes characters 14 and 15. If the length is 27 characters, then this field includes the text SERIE UNICA. |
D500 | 8 | SUB | The system leaves this field blank. |
D500 | 9 | NUM_DOC | If the nota fiscal sub serie has a legal number in the F76B01TE table, then the system writes the character at position 9 of the legal number.
If the nota fiscal sub serie is a paper one and the F7601BTE is empty, then the system uses F7601B.FHBNNFR. If the nota fiscal has a legal number in the F7601BTE table, then the system uses the series number from it. |
D500 | 10 | DT_DOC | Issue date from F7601B.FHISSU. |
D500 | 11 | DT_A_P | Input or output date.
For inbound transactions, the value from F76101B.BRADLJ. For outbound transactions, the value from F76101B.BRADEJ |
D500 | 12 | VL_DOC | Total amount from F7601B.FHBVTN. |
D500 | 13 | VL_DESC | Discount amount from F7601B.FHBDES. |
D500 | 14 | VL_SERV | Total amount F7601B.FHBVTN. |
D500 | 15 | VL_SERV_NT | Total amount that is non-taxable for ICMS.
D500 | 16 | VL_TERC | Amount of invoices in the name of others.
D500 | 17 | VL_DA | Expenses amount from F7601B.BDFN. |
D500 | 18 | VL_BC_ICMS | ICMS taxable amount from F7601B.BBCL. |
D500 | 19 | VL_ICMS | ICMS amount from F7601B.BCIM. |
D500 | 20 | COD_INF | The system leaves this field blank. |
D500 | 21 | VL_PIS | PIS amount
For inbound and outbound transactions, the value of F76B011.BRTXA when the value of BRTX is 05. |
D500 | 22 | VL_COFINS | COFINS Amount
For inbound and outbound transactions the value of F76B011.BRTXA when the value of BRTX is 06. |
D500 | 23 | COD_CTA | ICMS amount.
D500 | 24 | TP_ASSINANTE | Consumer type.
The system leaves this field blank. Note: The JD Edwards EnterpriseOne system does not store these values, so the system cannot populate this field. However, you must provide the appropriate values in the file that you submit. You must customize the program to populate this field with one of these values: 1: Comercial/Industrial 2: Poder Público 3: Residencial/Pessoa física 4: Público 5: Semi-Público 6: Outros |
D510 | 1 | REG | Fixed value of D510. |
D510 | 2 | NUM_ITEM | Item line number
D510 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
D510 | 4 | COD_CLASS | Item classification of communication service according to reference table 4.4.1.
D510 | 5 | QTD | Item quantity
D510 | 6 | UNID | Unit of measure
D510 | 7 | VL_ITEM | Item amount
D510 | 8 | VL_DESC | Discount amount
D510 | 9 | CST_ICMS | State tax situation according to reference table 4.3.1.
D510 | 10 | CFOP | Transaction nature
D510 | 11 | VL_BC_ICMS | ICMS taxable amount
D510 | 12 | ALIQ_ICMS | ICMS rate
D510 | 13 | VL_ICMS | ICMS amount
D510 | 14 | VL_BC_ICMS_ST | ICMS substitute taxable amount
D510 | 15 | VL_ICMS_ST | ICMS substitute tax
D510 | 16 | IND_REC | Indicator of income type
D510 | 17 | COD_PART | Address number (field 2 of the register 0150)
D510 | 18 | VL_PIS | PIS amount
D510 | 19 | VL_COFINS | COFINS amount
D510 | 20 | COD_CTA | Account number
D530 | 1 | REG | Fixed value of D530. |
D530 | 2 | IND_SERV | Service indicator type
D530 | 3 | DT_INI_SERV | Service initial date
D530 | 4 | DT_FIN_SERV | Service final date
D530 | 5 | PER_FISCAL | Fiscal period of service presentation
D530 | 6 | COD_AREA | Terminal invoice area code
D530 | 7 | TERMINAL | Identification of the terminal invoice
D590 | 1 | REG | Fixed value of D590. |
D590 | 2 | CST_ICMS | State tax situation from F76111B.BST1. |
D590 | 3 | CFOP | Transaction nature from F76111B.BRNOP. |
D590 | 4 | ALIQ_ICMS | ICMS rate from F76111B.BRAAIC. |
D590 | 5 | VL_OPR | Transaction amount.
D590 | 6 | VL_BC_ICMS | ICMS taxable amount from F7601B.BBCL. |
D590 | 7 | VL_ICMS | ICMS amount from F7601B.BRAVCI. |
D590 | 8 | VL_BC_ICMS_ST | ICMS substitute taxable amount form F76111B.BBIS. |
D590 | 9 | VL_ICMS_ST | ICMS substitute tax from F76111B.BVIS. |
D590 | 10 | VL_RED_BC | Reduced taxable amount.
D590 | 11 | COD_ODB | Description
D600 | 1 | REG | Fixed value of D600. |
D600 | 2 | COD_MOD | Nota fiscal model
D600 | 3 | COD_MUN | Remit city. Must be code from city table (www.ibge.gov.br)
D600 | 4 | SER | Fiscal document series
D600 | 5 | SUB | Fiscal document subseries
D600 | 6 | COD_CONS | Consumer class
D600 | 7 | QTD_CONS | Quantity of consolidate documents
D600 | 8 | DT_DOC | Issue date
D600 | 9 | VL_DOC | Total amount
D600 | 10 | VL_DESC | Discount amount accumulated
D600 | 11 | VL_SERV | Total amount
D600 | 12 | VL_SERV_NT | Total amount non taxable by ICMS
D600 | 13 | VL_TERC | Third payment amount
D600 | 14 | VL_DA | Expenses amount
D600 | 15 | VL_BC_ICMS | ICMS taxable amount
D600 | 16 | VL_ICMS | ICMS amount
D600 | 17 | VL_PIS | PIS amount
D600 | 18 | VL_COFINS | COFINS amount
D610 | 1 | REG | Fixed value of D610. |
D610 | 2 | COD_CLASS | Item classification of communication service according to reference table 4.4.1.
D610 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
D610 | 4 | QTD | Accumulated quantity
D610 | 5 | UNID | Unit of measure
D610 | 6 | VL_ITEM | Item amount
D610 | 7 | VL_DESC | Discount amount accumulated
D610 | 8 | CST_ICMS | State tax situation according to reference table 4.3.1.
D610 | 9 | CFOP | Transaction nature
D610 | 10 | ALIQ_ICMS | ICMS rate
D610 | 11 | VL_BC_ICMS | ICMS taxable amount
D610 | 12 | VL_ICMS | ICMS amount
D610 | 13 | VL_BC_ICMS_ST | ICMS substitute taxable amount
D610 | 14 | VL_ICMS_ST | ICMS substitute tax
D610 | 15 | VL_RED_BC | Reduced taxable amount
D610 | 16 | VL_PIS | PIS amount
D610 | 17 | VL_COFINS | COFINS amount
D610 | 18 | COD_CTA | Account number
D690 | 1 | REG | Fixed value of D690. |
D690 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
D690 | 3 | CFOP | Transaction nature
D690 | 4 | ALIQ_ICMS | ICMS rate
D690 | 5 | VL_OPR | Transaction amount
D690 | 6 | VL_BC_ICMS | ICMS taxable amount
D690 | 7 | VL_ICMS | ICMS amount
D690 | 8 | VL_BC_ICMS_ST | ICMS substitute taxable amount
D690 | 9 | VL_ICMS_ST | ICMS substitute tax
D690 | 10 | VL_RED_BC | Reduced taxable amount
D690 | 11 | COD_OBS | Fiscal observation code
D695 | 1 | REG | Fixed value of D695. |
D695 | 2 | COD_MOD | Nota fiscal model
D695 | 3 | SER | Fiscal document series
D695 | 4 | NRO_ORD_INI | Initial order number
D695 | 5 | NRO_ORD_FIN | Final order number
D695 | 6 | DT_DOC_INI | Initial issue date
D695 | 7 | DT_DOC_FIN | Final issue date
D695 | 8 | NOM_MEST | Volume number
D695 | 9 | CHV_COD_DIG | Access fiscal key
D696 | 1 | REG | Fixed value of D696. |
D696 | 2 | CST_ICMS | State tax situation according to reference table 4.3.1.
D696 | 3 | CFOP | Transaction nature
D696 | 4 | ALIQ_ICMS | ICMS rate
D696 | 5 | VL_OPR | Transaction amount
D696 | 6 | VL_BC_ICMS | ICMS taxable amount
D696 | 7 | VL_ICMS | ICMS amount
D696 | 8 | VL_BC_ICMS_ST | ICMS substitute taxable amount
D696 | 9 | VL_ICMS_ST | ICMS substitute tax
D696 | 10 | VL_RED_BC | Reduced taxable amount
D696 | 11 | COD_OBS | Fiscal observation code
D697 | 1 | REG | Fixed value of D697. |
D697 | 2 | UF | State
D697 | 3 | VL_BC_ICMS_ST | ICMS substitute taxable amount
D697 | 4 | VL_ICMS_ST | ICMS substitute tax
D990 | 1 | REG | Fixed value of D990. |
D990 | 2 | QTD_LIN_D | Quantity of lines in block D |
Block E includes information about IPI and ICMS taxes. Not all of the information required in this block resides in the JD Edwards EnterpriseOne tables. This section lists only the fields that are populated from the JD Edwards EnterpriseOne tables.
E001 | 1 | REG | Fixed value of E001. |
E001 | 2 | IND_MOV | Movement indicator. Values are:
E100 | 1 | REG | Fixed value of E100. |
E100 | 2 | DT_INI | Verification start date from a value that you enter in the SPED Fiscal Administ Process program. |
E100 | 3 | DT_FIN | Verification end date from a value that you enter in the SPED Fiscal Administ Process program. |
E110 | 1 | REG | Fixed value of E110. |
E110 | 2 | VL_TOT_DEBITOS | Total debit amount.
For output nota fiscal, the sum of F76101B BICM. |
E110 | 3 | VL_AJ_DEBITOS | Total debit adjustment amount.
E110 | 4 | VL_TOT_AJ_DEBITOS | Total debit adjustment.
E110 | 5 | VL_ESTORNOS_CRED | Total adjustments for debit reversions.
E110 | 6 | VL_TOT_CREDITOS | Total credit amount.
For inbound nota fiscal, the sum of F76101B BICM. |
E110 | 7 | VL_AJ_CREDITOS | Total credit adjustment amount.
E110 | 8 | VL_TOT_AJ_CREDITOS | Total credit adjustment.
E110 | 9 | VL_ESTORNOS_DEB | Total adjustments for credit reversions.
E110 | 10 | VL_SLD_CREDOR_ANT | ICMS credit balance to transfer to next period. |
E110 | 11 | VL-SLD_APURADO | Balance due.
Sum fields: 02+03+04+05−06−07−08−09−10 |
E110 | 12 | VL_TOT_DED | Deduction amounts.
E110 | 13 | VL_ICMS_RECOLHER | Net amount.
The value in field 11 minus the value in field 12. |
E110 | 14 | VL_SLD_CREDOR_TRANSPORT_AR | ICMS credit balance to transfer to next period.
The system completes this field when the net amount is in favor to the contributor. |
E110 | 15 | DEB_ESP | ICMS amount to pay
The system completes this field when the net amount is in favor to the fiscal authority. |
E111 | 1 | REG | Fixed value of E111. |
E111 | 2 | COD_AJ_APUR | Verification adjust code
E111 | 3 | DESCR_COMPL_AJ | Description
E111 | 4 | VL_AJ_APUR | Verification amount
E112 | 1 | REG | Fixed value of E112. |
E112 | 2 | NUM_DA | Document number
E112 | 3 | NUM_PROC | Process number
E112 | 4 | IND_PROC | Indicator of process origin. Values are:
0: Sefaz 1: Justiça Federal 2: Justiça Estadual 9: Others The system leaves this field blank. |
E112 | 5 | PROC | Description
E112 | 6 | TXT_COMPL | The system populates this field with the reference code field 2 of register 0450.
E113 | 1 | REG | Fixed value of E113. |
E113 | 2 | COD_PART | Address number.
E113 | 3 | COD_MOD | Nota fiscal model
E113 | 4 | SER | Fiscal document series
E113 | 5 | SUB | Fiscal document subseries
E113 | 6 | NUM_DOC | Nota fiscal number
E113 | 7 | DT_DOC | Issue date
E113 | 8 | COD_ITEM | Item number
E113 | 9 | VL_AJ_ITEM | Adjust amount
E115 | 1 | REG | Fixed value of E115. |
E115 | 2 | COD_INF_ADIC | Additional information
E115 | 3 | VL_INF_ADIC | Reference value
E115 | 4 | DESCR_COMPL_AJ | Additional information
E116 | 1 | REG | Fixed value of E116. |
E116 | 2 | COD_OR | To pay code according to reference table 5.4.
000 |
E116 | 3 | VL_OR | To pay amount = E110, field 13 if field is different than zero. |
E116 | 4 | DT_VCTO | Due date is the last date of the job. |
E116 | 5 | COD_REC | Receita code = 0. |
E116 | 6 | NUM_PROC | Process number
E116 | 7 | IND_PROC | Indicator of process origin. Values are:
E116 | 8 | PROC | Description
E116 | 9 | TXT_COMPL | Description
E116 | 10 | MES_REF | Monthly. The system reports the value only if E116 Field 3 is informed. |
E200 | 1 | REG | Fixed value of E200. |
E200 | 2 | UR | State from F76101B. BRAUFE. |
E200 | 3 | DT_FIN | Verification beginning date from a value that you enter in the SPED Fiscal Block Setup program. |
E200 | 4 | DT_FIN | Verification end date from a value that you enter in the SPED Fiscal Block Setup program. |
E210 | 1 | REG | Fixed value of E210. |
E210 | 2 | IND_MOV_ST | Movement indicator. Values are:
0: without ICMS ST 1: with ICMS ST |
E210 | 3 | VL_SLD_CRED_ANT_ST | ICMS substitute tax balance to transfer to next period. |
E210 | 4 | VL_DEVOL_ST | Total ICMS substitute tax by returned goods.
E210 | 5 | VL_RESSARC_ST | Total ICMS substitute tax by indemnity.
E210 | 6 | VL_OUT_CRED_ST | Total credit substitute tax.
For outbound notas fiscais, F7611B.FDBNFS. For inbound notas fiscais, F76111B.BVIS. |
E210 | 7 | VL_AJ_CREDITOS_ST | Total credit ICMS substitute tax by adjustments to the legal documents.
E210 | 8 | VL_RETENÇAO_ST | Total ICMS substitute tax withheld.
E210 | 9 | VL_OUT_DEB_ST | Total debit substitute tax.
E210 | 10 | VL_AJ_DEBITOS_ST | Total debit ICMS substitute tax by adjustments to the legal documents.
E210 | 11 | VL_SLD_DEV_ANT_ST | ICMS substitute tax to pay before deductions.
Sum of fields: [(09+10+11) − (04+05+06+07+08)]. |
E210 | 12 | VL_DEDUÇÕES_ST | ICMS substitute tax deduction.
E210 | 13 | VL_ICMS_RECOL_ST | Amount to pay.
The value of field 12 minus the value of field 13. |
E210 | 14 | VL_SLD_CRED_ST_TRANSFORTAR | ICMS substitute tax credit balance to transfer to next period.
Sum of fields: [(04+05+06+07+08) − (09+10+11)]. |
E210 | 15 | DEB_ESP_ST | Extra values
E220 | 1 | REG | Fixed value of E220. |
E220 | 2 | COD_AJ_APUR | Adjust code according to table 5.1.1.
E220 | 3 | DESCR_COMPL_AJ | Description
E220 | 4 | VL_AJ_APUR | Adjust amount
E230 | 1 | REG | Fixed value of E230. |
E230 | 2 | NUM_DA | Document number
E230 | 3 | NUM_PROC | Process number
E230 | 4 | IND_PROC | Indicator of process origin. Values are:
E230 | 5 | PROC | Description
E230 | 6 | TXT_COMPL | The system populates this field with the reference code from field 2 of register 0450.
E240 | 1 | REG | Fixed value of E240. |
E240 | 2 | COD_PART | Address number
E240 | 3 | COD_MOD | Nota fiscal model
E240 | 4 | SER | Fiscal document series
E240 | 5 | SUB | Fiscal document subseries
E240 | 6 | NUM_DOC | Nota fiscal number
E240 | 7 | DT_DOC | Issue date
E240 | 8 | COD_ITEM | Item number
E240 | 9 | VL_AJ_ITEM | Adjust amount
E250 | 1 | REG | Fixed value of E250. |
E250 | 2 | COD_OR | To pay code, according to reference table 5.4.
E250 | 3 | VL_OR | To pay amount
E250 | 4 | DT_VCTO | Due date
E250 | 5 | COD_REC | Receita code
E250 | 6 | NUM_PROC | Process number
E250 | 7 | IND_PROC | Indicator of process origin. Values are:
E250 | 8 | PROC | Description
E250 | 9 | TXT_COMPL | Description
E250 | 10 | MES_REF | Monthly
E500 | 1 | REG | Fixed value of E500. |
E500 | 2 | IND_APUR | Period indicator. Values are:
0: Monthly 1: 10 months Value is always 0. |
E500 | 3 | DT_INI | Verification begin date.
From a value that you set up in the SPED Fiscal Block Setup program. |
E500 | 4 | DT_FIN | Verification end date.
E510 | 1 | REG | Fixed value of E510. |
E510 | 2 | CFOP | Transaction nature from F76111B.BRNOP. |
E510 | 3 | CST_IPI | IPI tax situation code.
The value from F76B012.B76TSIPI. If no value exists, then write the value from the Special Handling Code field of UDC 76B/CW for the value that exists in F76111B. BRAITP. |
E510 | 4 | VL_CONT_IPI | Accounting amount by CFOP and CTIPI.
The sum of the values from F76111B.AEXP − F76111B.BDES. |
E510 | 5 | VL_BC_IPI | IPI taxable amount by CFOP and CTIPI from F76111B.BBTP. |
E510 | 6 | VL_IPI | IPI amount by CFOP and CTIPI from F76111B.BRBIPI. |
E520 | 1 | REG | Fixed value of E510. |
E520 | 2 | VL_SD_ANT_IPI | IPI credit balance before period zero. |
E520 | 3 | VL_DEB_IPI | Total debit amount "output with debit tax": For output, if (F76111B.BRAITP) = "1,4,5"Sum F76111B.BIPI. |
E520 | 4 | VL_CRED_IPI | Total amount "input with credit tax": For input, if (F76111B.BRAITP) = "1,4,5"Sum F76111B.BIPI. |
E520 | 5 | VL_OD_IPI | Total amount "other debit": For output, if (BF76111B.BRAITP = "5"), sum BF76111B.BRABIP. If (BF76111B.BRAITP) = "3", sum F76111B.BIPI. |
E520 | 6 | VL_OC_IPI | Total amount "other credit": For input, if (BF76111B.BRAITP = "5"), sum BF76111B.BRABIP. If (BF76111B.BRAITP) = "3", sum F76111B.BIPI. |
E520 | 7 | VL_SC_IPI | IPI credit balance to transfer to next period: TotalCredit = TotalCreditTax + TotalOtherCreditTax + IPI Credit Balance Before Period |
E520 | 8 | VL_SD_IPI | IPI amount to pay: TotalDebit = TotalDebitTax + TotalOtherDebitTax. if TotalCredit > TotalDebit then IPI credit balance to transfer to next period = TotalCredit - TotalDebit IPI Amount to pay = 0 Else IPI credit balance to transfer to next period = 0 IPI Amount to pay = TotalDebit - TotalCreditEnd |
E530 | 1 | REG | Fixed value of E530. |
E530 | 2 | IND_AJ | Indicator of adjust type. Values are:
0: Debit adjust 1: Credit adjust The system leaves this field blank. |
E530 | 3 | VL_AJ | Adjust amount
E530 | 4 | COD_AJ | Adjust code according to table 4.5.4.
E530 | 5 | IND_DOC | Origin of the document
E530 | 6 | NUM_DOC | Document number
E530 | 7 | DESCR_AJ | Adjust description
E990 | 1 | REG | Fixed value of E990. |
E990 | 2 | QTD_LIN_E | Quantity of lines in block E. |
Block G includes information about CIAP. JD Edwards EnterpriseOne has not localized this information. The JD Edwards EnterpriseOne system generates block G and block G registers, but populates only the REG fields of the registers. You must populate the other required fields in block G by running custom programming. Add your custom programs to the sequence that you set up in the SPED Fiscal Block Setup program.
G001 | 1 | REG | Fixed value of G001. |
G001 | 2 | IND_MOV | Movement indicator. Values are:
0: Block with information 1: Block without information |
G110 | 1 | REG | Fixed value of G110. |
G110 | 2 | DT_INI | Initial date
G110 | 3 | DT_FIN | Final date
G110 | 4 | SALDO_IN_ICMS | Begin ICMS amount
G110 | 5 | SOM_PARC | ICMS quotes amount
G110 | 6 | VL_TRIB_EXP | Total output |
G110 | 7 | VL_TOTAL | Total ICMS amount
G110 | 8 | IND_PER_SAI | Participation index.
G110 | 9 | ICMS_APROP | ICMS appropriate
G110 | 10 | SOM_ICMS_OC | ICMS other credits.
G125 | 1 | REG | Fixed value of G125 |
G125 | 2 | COD_IND_BEM | Patrimonial code
G125 | 3 | DT_MOV | Movement date
G125 | 4 | TIPO_MOV | Movement type
G125 | 5 | VL_IMOB_ICMS_OP | ICMS amount
G125 | 6 | VL_IMOB_ICMS_ST | ICMS subs amount
G125 | 7 | VL_IMOB_ICMS_FRT | Freight ICMS amount
G125 | 8 | VL_IMOB_ICMS_DIF | ICMS differential amount
G125 | 9 | NUM_PARC | Quote number
G125 | 10 | VL_PARC_PASS | Quote amount
G126 | 1 | REG | Fixed value of G126. |
G126 | 2 | DT_INI | Initial date.
G126 | 3 | DT_FIM | Final date.
G126 | 4 | NUM_PARC | Number of the parcel of the ICMS.
G126 | 5 | VL_PARC_PASS | Value of the parcel of ICMS of appropriation.
G126 | 7 | VL_TRIB_OC | Total value of outputs in the period indicated in this register.
G126 | 8 | IND_PER_SAI | Index of participation of Field 06 divided by field 07.
G126 | 9 | VL_PARC_APROP | Value of other credits of ICMS (field 05 times or field 08).
G130 | 1 | REG | Fixed value of G130. |
G130 | 2 | IND_EMIT | Fiscal note type
G130 | 3 | COD_PART | Emission type
G130 | 4 | COD_MOD | Nota fiscal model
G130 | 5 | SERIE | Serial number
G130 | 6 | NUM_DOC | Legal number
G130 | 7 | CHV_NFE_CTE | Fiscal access key
G130 | 8 | DT_DOC | Emission date
G140 | 1 | REG | Fixed value of G140. |
G140 | 2 | NUM_ITEM | Fixed asset number
G140 | 3 | COD_ITEM | Item number
G990 | 1 | REG | Fixed value of G990. |
G990 | 2 | QTD_LIN_G | Lines quantity |
Block H includes information about inventory.
H001 | 1 | REG | Fixed value of H001. |
H001 | 2 | IND_MOV | Movement indicator. Values are:
H005 | 1 | REG | Fixed value of H005. |
H005 | 2 | DT_INV | Inventory date. |
H005 | 3 | VL_INV | Inventory total amount.
Total stock from the F4111 table. |
H005 | 4 | MOT_INV | Inventory reason. This value is defined by a processing option. Values are:
H010 | 1 | REG | Fixed value of H010. |
H010 | 2 | COD_ITEM | Item number.
Field 02 of the register 0200 in block 0. |
H010 | 3 | UNID | Unit value from F4111.LLTRUM. |
H010 | 4 | QTD | Quantity from F4111.LLTRQT. |
H010 | 5 | VL_UNIT | Unit value from F4111.LLUNCS. |
H010 | 6 | VL_ITEM | Item amount from F4111.LLPAID. |
H010 | 7 | IND_PROP | Indicator of inventory owner from a value that you enter in the SPED Fiscal Constant Setup program (P76B0715). Values are:
0: Own item in internal stock 1: Own item in external stock 2: Third item in internal stock |
H010 | 8 | COD_PART | Address number of the inventory owner from field 2 of the register 0150 for block 0. |
H010 | 9 | COD_OBS | Fiscal observation code.
H010 | 10 | COD_CTA | Account code
The system retrieves the value for this field by using the value in the Transaction Document Type processing option, the business unit from the Item As Of file (F41112), and the GL Category from the Item Branch/Plant table (F4102) to identify the DMAAI 4122 record from which to obtain the account to write to this field. |
H020 | 1 | REG | Fixed value H020 |
H020 | 2 | CST_ICMS | Tributary situation |
H020 | 3 | BC_ICMS | ICMS taxable amount |
H020 | 4 | VL_ICMS | ICMS amount |
H990 | 1 | REG | Fixed value of H990. |
H990 | 2 | QTD_LIN_H | Quantity of lines in block H. |
The JD Edwards EnterpriseOne system generates block 1 and block 1 registers, but populates only the REG fields of the registers. You must populate the other required fields in block 1 by running custom programming. Add your custom programs to the sequence that you set up in the SPED Fiscal Block Setup program.
Register Number | Field Number | Field Name | Description |
1001 | 1 | REG | Fixed value of 1001. |
1001 | 2 | IND_MOV | Movement indicator. Values are:
1010 | 1 | REG | Fixed value "1010" |
1010 | 2 | IND_EXP | Data for register 1100 |
1010 | 3 | IND_CCRF | Data for register 1200 |
1010 | 4 | IND_COMB | Data for register 1300 |
1010 | 5 | IND_USINA | Data for register 1390 |
1010 | 6 | IND_VA | Data for register 1400 |
1010 | 7 | IND_EE | Data for register 1500 |
1010 | 8 | IND_CART | Data for register 1600 |
1010 | 9 | IND_FORM | Data for register 1700 |
1010 | 10 | IND_AER | Data for register 1800 |
1100 | 1 | REG | Fixed value of 1100. |
1100 | 2 | IND_DOC | Document type. Values are:
0: Exportation declaration 1: Simplify exportation declaration The system leaves this field blank. |
1100 | 3 | NRO_DE | Declaration number
1100 | 4 | DT_DE | Declaration date
1100 | 5 | NAT_EXP | Exportation type. Values are:
0: Direct 1: Indirect The system leaves this field blank. |
1100 | 6 | NRO_RE | Register number
1100 | 7 | DT_RE | Register date
1100 | 8 | CHC_EMB | Shipment number
1100 | 9 | DT_CHC | Shipment date
1100 | 10 | DT_AVB | Declaration date
1100 | 11 | TP_CHC | Document type according to Siscomex
1100 | 12 | PAIS | Country code
1105 | 1 | REG | Fixed value of 1105. |
1105 | 2 | COD_MOD | Nota fiscal model
1105 | 3 | SERIE | Fiscal note series
1105 | 4 | NUM_DOC | Nota fiscal number
1105 | 5 | CHV_NFE | Fiscal access key
1105 | 6 | DT_DOC | Issue date
1105 | 7 | COD_ITEM | Item number
1110 | 1 | REG | Fixed value of 1110. |
1110 | 2 | COD_PART | Address number
1110 | 3 | COD_MOD | Fiscal note type
1110 | 4 | SER | Fiscal series number
1110 | 5 | NUM_DOC | Fiscal note number
1110 | 6 | DT_DOC | Issue date
1110 | 7 | CHV_NFE | Fiscal access key
1110 | 8 | NR_ MEMO | Exportation number
1110 | 9 | QTD | Quantity exported
1110 | 10 | UNID | Unit of measure
1200 | 1 | REG | Fixed value of 1200. |
1200 | 2 | COD_AJ_APUR | Adjustment code according to table 5.1.1.
1200 | 3 | SLD_CRED | Fiscal credits balance of previous periods
1200 | 4 | CRÉD_APR | Appropriate total credit in the month
1200 | 5 | CRED_RECEB | Received total credit against transfers
1200 | 6 | CRED_UTIL | Total credit of the period
1200 | 7 | SLD_CRED_FIM | Total fiscal credit accumulated for next period.
1210 | 1 | REG | Fixed value of 1210. |
1210 | 2 | UTILIZAÇÃO DE CRÉDITOS FISCAIS – ICMS – para TIPO_UTIL | Credit type of use according to table 5.5.
1210 | 3 | NR_DOC | Quantity documents used at credit discharge
1210 | 4 | VL_CRED_UTIL | Total credit used
1300 | 1 | REG | Fixed value of 1300. |
1300 | 2 | COD_ITEM | Item number (field 2 of the register 0200)
1300 | 3 | DATA_FECH | Date of the locking of the movement
1300 | 4 | ESTQ_ABERT | Supply at the beginning of the day in liters
1300 | 5 | VOL_ENTR | Total volume of the Inputs in liters
1300 | 6 | VOL_DISP | Available volume (04+05) in liters
1300 | 7 | VOL_SAIDAS | Total volume of the outputs in liters
1300 | 8 | ESTQ_ESCR | Contractual supply (06-07) in liters
1300 | 9 | VAL_AJ_PERDA | Value of loss in liters
1300 | 10 | VAL_AJ_GANHO | Value of gain in liters
1300 | 11 | FECH_FISICO | Supply of locking in liters
1310 | 1 | REG | Fixed value of 1310. |
1310 | 2 | NUM_TANQUE | Tank where the fuel was stored
1310 | 3 | ESTQ_ABERT | Initial daily stock (liters)
1310 | 4 | VOL_ENTR | Daily received liters
1310 | 5 | VOL_DISP | Available volume (03+04) (liters)
1310 | 6 | VOL_SAIDAS | Total volume of the outputs in liters
1310 | 7 | ESTQ_ESCR | Contractual stock (06-07) in liters
1310 | 8 | VAL_AJ_PERDA | Value of loss in liters
1310 | 9 | VAL_AJ_GANHO | Value of gain in liters
1310 | 10 | FECH_FISICO | Physical volume stock in liter
1320 | 1 | REG | Fixed value of 1320. |
1320 | 2 | NUM_BICO | Number of bomb
1320 | 3 | NR_INTERV | Intervention number
1320 | 4 | MOT_INTERV | Intervention reason
1320 | 5 | NOM_INTERV | Intervention name
1320 | 6 | CNPJ_INTERV | CNPJ of the responsible company for the intervention
1320 | 7 | CPF_INTERV | CPF of responsible technician for the intervention
1320 | 8 | VAL_FECHA | Value of the final reading
1320 | 9 | VAL_ABERT | Value of the initial reading
1320 | 10 | VOL_AFERI | Gauging bomb, in liters
1320 | 11 | VOL_VENDAS | Sales in liters (08 - 09 -10)
1350 | 1 | REG | Fixed value of 1350. |
1350 | 2 | SERIE | Bomb serie number
1350 | 3 | FABRICANTE | Bomb manufacturer name
1350 | 4 | MODELO | Bomb model
1350 | 5 | TIPO_MEDICAO | Measurement identification
1360 | 1 | REG | Fixed value of 1360. |
1360 | 2 | NUM_LACRE | Number of the sealing wax associated in the bomb
1360 | 3 | DT_APLICACAO | Date of application of the sealing wax
1370 | 1 | REG | Fixed value of 1370. |
1370 | 2 | NUM_BICO | Pipe bomb sequential number
1370 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
1370 | 4 | NUM_TANQUE | Tank that stores the fuel
1390 | 01 | REG | Fixed value "1390" |
1390 | 02 | COD_PROD | Product code. Values are:
1391 | 01 | REG | Fixed value "1391" |
1391 | 02 | DT_REGISTRO | Product date |
1391 | 03 | QTD_MOID | Quantity of cane crushed (tons) |
1391 | 04 | ESTQ_INI | Initial stock (liters / kg) |
1391 | 05 | QTD_PRODUZ | Amount produced (liters / kg) |
1391 | 06 | ENT_ANID_HID | Entry of anhydrous alcohol from the transformation of hydrated alcohol or entry of hydrated alcohol from the transformation of the anhydrous alcohol (liters). |
1391 | 07 | OUTR_ENTR | Other entries (liters / Kg) |
1391 | 08 | PERDA | Evaporation (liters) or break weight (kg) |
1391 | 09 | CONS | Consumption (liters) |
1391 | 10 | SAI_ANI_HID | Output processing (liters) |
1391 | 11 | SAÍDAS | Output (liters / Kg) |
1391 | 12 | ESTQ_FIN | Ending inventory (liters / Kg) |
1391 | 13 | ESTQ_INI_MEL | Initial inventory of residual honey (kg) |
1391 | 14 | ROD_DIA_MEL | Honey production waste (kg) |
1391 | 15 | UTIL_MEL | Residual honey used (kg) |
1391 | 16 | PROD_ALC_MEL | Production of ethanol (liters) from the residual honey. |
1391 | 17 | OBS | Comments |
1400 | 1 | REG | Fixed value of 1400. |
1400 | 2 | COD_ITEM | Item number (field 2 of the register 0200)
1400 | 3 | MUN | Original municipal code
1400 | 4 | VALOR | Municipal monthly value
1500 | 1 | REG | Fixed value of 1500. |
1500 | 2 | IND_OPER | Operation type
1500 | 3 | IND_EMIT | Fiscal note emitter
1500 | 4 | COD_PART | Address number (field 2 of the register 0150)
1500 | 5 | COD_MOD | Nota fiscal model
1500 | 6 | COD_SIT | Nota fiscal situation
1500 | 7 | SER | Fiscal document series
1500 | 8 | SUB | Fiscal document subseries
1500 | 9 | COD_CONS | Consumer class
1500 | 10 | NUM_DOC | Fiscal note number
1500 | 11 | DT_DOC | Issue date
1500 | 12 | DT_E_S | Input/output date
1500 | 13 | VL_DOC | Total amount
1500 | 14 | VL_DESC | Discount amount
1500 | 15 | VL_FORN | Supplied total amount
1500 | 16 | VL_SERV_NT | Total amount non taxable by ICMS
1500 | 17 | VL_TERC | Third payment amount
1500 | 18 | VL_DA | Expenses amount
1500 | 19 | VL_BC_ICMS | ICMS taxable amount
1500 | 20 | VL_ICMS | ICMS amount
1500 | 21 | VL_BC_ICMS_ST | ICMS substitute taxable amount
1500 | 22 | VL_ICMS_ST | ICMS substitute tax
1500 | 23 | COD_INF | Reference code (field 2 from register 0450)
1500 | 24 | VL_PIS | PIS amount
1500 | 25 | VL_COFINS | COFINS amount
1500 | 26 | TP_LIGACAO | Connection type
1500 | 27 | COD_GRUPO_TENSAO | Tension
1510 | 1 | REG | Fixed value of 1510. |
1510 | 2 | NUM_ITEM | Item line number
1510 | 3 | COD_ITEM | Item number (field 2 of the register 0200)
1510 | 4 | COD_CLASS | Item classification of communication service according to reference table 4.4.1.
1510 | 5 | QTD | Item quantity
1510 | 6 | UNID | Unit of measure
1510 | 7 | VL_ITEM | Item amount
1510 | 8 | VL_DESC | Discount amount
1510 | 9 | CST_ICMS | State tax situation according to reference table 4.3.1.
1510 | 10 | CFOP | Transaction nature
1510 | 11 | VL_BC_ICMS | ICMS taxable amount
1510 | 12 | ALIQ_ICMS | ICMS rate
1510 | 13 | VL_ICMS | ICMS amount
1510 | 14 | VL_BC_ICMS_ST | ICMS substitute taxable amount
1510 | 15 | ALIQ_ST | ICMS rate
1510 | 16 | VL_ICMS_ST | ICMS substitute tax
1510 | 17 | IND_REC | Indicator of income type
1510 | 18 | COD_PART | Address number (field 2 of the register 0150)
1510 | 19 | VL_PIS | PIS amount
1510 | 20 | VL_COFINS | COFINS amount
1510 | 21 | COD_CTA | Account number
1600 | 1 | REG | Fixed value of 1600. |
1600 | 2 | COD_PART | Address number (field 2 of the register 0150)
1600 | 3 | TOT_CREDITO | Transaction with credit card
1600 | 4 | TOT_DEBITO | Transaction with debit card
1700 | 1 | REG | Fixed value of 1700. |
1700 | 2 | COD_DISP | Cod. Disp.authorized
1700 | 3 | COD_MOD | Fiscal model
1700 | 4 | SER | Serial number
1700 | 5 | SUB | Subserial number
1700 | 6 | NUM_DOC_INI | Initial number
1700 | 7 | NUM_DOC_FIN | Final number
1700 | 8 | NUM_AUT | Authorization code
1710 | 1 | REG | Fixed value of 1710. |
1710 | 2 | NUM_DOC_INI | Initial number
1710 | 3 | NUM_DOC_FIN | Final number
1800 | 1 | REG | Fixed value of 1800. |
1800 | 2 | VL_CARGA | Services amounts
1800 | 3 | VL_PASS | Services amounts
1800 | 4 | VL_FAT | Total amount
1800 | 5 | IND_RAT | Tax conversion
1800 | 6 | VL_ICMS_ANT | ICMS amount
1800 | 7 | VL_BC_ICMS | ICMS amount
1800 | 8 | VL_ICMS_APUR | ICMS amount
1800 | 9 | VL_BC_ICMS_APUR | Taxable amount
1800 | 10 | VL_DIF | Calculated amount
1900 | 1 | REG | Fixed value of 1900. |
1900 | 2 | IND_APUR_ICM | The system leaves this field blank. |
1900 | 3 | DESCR_COMPL_OUT_APUR | The system leaves this field blank. |
1910 | 1 | REG | Fixed value of 1910. |
1910 | 2 | DT_INI | The system leaves this field blank. |
1910 | 3 | DT_FIN | The system leaves this field blank. |
1920 | 1 | REG | Fixed value of 1920. |
1920 | 2 | VL_TOT_TRANSF_DEBITOS_OA | The system leaves this field blank. |
1920 | 3 | VL_TOT_AJ_DEBITOS_OA | The system leaves this field blank. |
1920 | 4 | VL_ESTORNOS_CRED_OA | The system leaves this field blank. |
1920 | 5 | VL_TOT_TRANSF_CREDITOS_OA | The system leaves this field blank. |
1920 | 6 | VL_TOT_AJ_CREDITOS_OA | The system leaves this field blank. |
1920 | 7 | VL_ESTORNOS_DEB_OA | The system leaves this field blank. |
1920 | 8 | VL_SLD_CREDOR_ANT_OA | The system leaves this field blank. |
1920 | 9 | VL_SLD_APURADO_OA | The system leaves this field blank. |
1920 | 10 | VL_TOT_DED | The system leaves this field blank. |
1920 | 11 | VL_ICMS_RECOLHER_OA | The system leaves this field blank. |
1920 | 12 | VL_SLD_CREDOR_TRANSP_OA | The system leaves this field blank. |
1920 | 13 | DEB_ESP_OA | The system leaves this field blank. |
1921 | 1 | REG | Fixed value of 1921. |
1921 | 2 | COD_AJ_APUR | The system leaves this field blank. |
1921 | 3 | DESCR_COMPL_AJ | The system leaves this field blank. |
1921 | 4 | VL_AJ_APUR | The system leaves this field blank. |
1922 | 1 | REG | Fixed value of 1922. |
1922 | 2 | NUM_DA | The system leaves this field blank. |
1922 | 3 | NUM_PROC | The system leaves this field blank. |
1922 | 4 | IND_PROC | The system leaves this field blank. |
1922 | 5 | PROC | The system leaves this field blank. |
1922 | 6 | TXT_COMPL | The system leaves this field blank. |
1923 | 1 | REG | Fixed value of 1923. |
1923 | 2 | COD_PART | The system leaves this field blank. |
1923 | 3 | COD_MOD | The system leaves this field blank. |
1923 | 4 | SER | The system leaves this field blank. |
1923 | 5 | SIUB | The system leaves this field blank. |
1923 | 6 | NUM_DOC | The system leaves this field blank. |
1923 | 7 | DT_DOC | The system leaves this field blank. |
1923 | 8 | COD_ITEM | The system leaves this field blank. |
1923 | 9 | VL_AJ_ITEM | The system leaves this field blank. |
1925 | 1 | REG | Fixed value of 1925. |
1925 | 2 | COD_INF_ADIC | The system leaves this field blank. |
1925 | 3 | VL_INF_ADIC | The system leaves this field blank. |
1925 | 4 | DESCR_COMPL_AJ | The system leaves this field blank. |
1926 | 1 | REG | Fixed value of 1926. |
1926 | 2 | COD_OR | The system leaves this field blank. |
1926 | 3 | VL_OR | The system leaves this field blank. |
1926 | 4 | DT_VCTO | The system leaves this field blank. |
1926 | 5 | COD_REC | The system leaves this field blank. |
1926 | 6 | NUM_PROC | The system leaves this field blank. |
1926 | 7 | IND_PROC | The system leaves this field blank. |
1926 | 8 | PROC | The system leaves this field blank. |
1926 | 9 | TXT_COMPL | The system leaves this field blank. |
1926 | 10 | MES_REF | The system leaves this field blank. |
Block 0 includes information about the reporting company. If the required value is not in JD Edwards EnterpriseOne tables, the system leaves the Description field blank.
0000 | 1 | REG | Fixed value of 0000. |
0000 | 2 | COD_VER | Code of layout version, according to reference table 3.1.1 |
0000 | 3 | COD_FIN | File Type. Values are:
0: Original 1: Substitute |
0000 | 4 | DT_INI | Begin date of the file. |
0000 | 5 | DT_FIN | End date of the file. |
0000 | 6 | NOME | Mailing name from F0111.MLNM. |
0000 | 7 | CNPJ | CNPJ number, if the reporting entity is a legal entity, from F0101.TAX. |
0000 | 8 | CPF | CPF number, if the reporting entity is a natural person, from F0101.TAX. |
0000 | 9 | UF | State from F0116.ADDS. |
0000 | 10 | IE | State tax ID.
If the contributor is an individual entity (1, 4, or P) then the word Isento if not, F0101.ABTX2. |
0000 | 11 | COD_MUN | City code.
The city code associated with the address number in the Supplemental Database program (P00092). The code must be from city table (www.ibge.gov.br). |
0000 | 12 | IM | Municipal tax ID from F76011.BMUN. |
0000 | 13 | SUFRAMA | SUFRAMA number from F76011.BISC. |
0000 | 14 | IND_PERFIL | Fiscal presentation type.
This field is completed from a value that you enter in the Fiscal Presentation Type field in SPED Fiscal Constant Setup program (P76B0715). |
0000 | 15 | IND_ATIV | Activity code. Values are:
0: Other 1: Industry This field is completed from a value that you enter Activity Code field in the SPED Fiscal Constant Setup program. |
0001 | 1 | REG | Fixed value of 0001. |
0001 | 2 | IND_MOV | Movement indicator. This field indicates if the block has information in the file. Values are:
0005 | 1 | REG | Fixed value of 0005. |
0005 | 2 | FANTASIA | Mailing name from F0111.MLNM. |
0005 | 3 | CEP | Zip code from F0116.ADDZ. |
0005 | 4 | END | Mailing address, as defined in a processing option. |
0005 | 5 | NUM | Mailing address, as defined in a processing option. |
0005 | 6 | COMPL | Mailing address, as defined in a processing option. |
0005 | 7 | BAIRRO | CIF data $N description of UDC 76B/NE |
0005 | 8 | FONE | Phone number.
The system concatenates F0115. PAR1 and F0115.PH1 when PHTP is blank. |
0005 | 9 | FAX | Fax number.
(F0115. PAR1 + PH1 when PHTP = FAX) |
0005 | 10 | Email address.
(F01151.EMAL when AETP = E) |
0015 | 1 | REG | Fixed value of 0015. |
0015 | 2 | UF_ST | State from F0116.ADDS. |
0015 | 3 | IE_ST | State tax ID from F76011.TX2. |
0100 | 1 | REG | Fixed value of 0100. |
0100 | 2 | NOME | Mailing name from F0111.MLNM.
The mailing name of the accountant from F0111.MLNM for the address book number specified in the SPED Fiscal Constant Setup program. |
0100 | 3 | CPF | CPF number.
The value from F76011.AIBCPF or F0101.TAX for the address book number specified for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 4 | CRC | CRC number.
This system retrieves this value from the Address Book Inscriptions table (F76B140) with Inscription Code equal to 30. |
0100 | 5 | CNPJ | CNPJ number.
The value of F0101.TAX for the address book number specified for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 6 | CEP | Zip code.
The value of F0116.ADDZ for the address book number specified for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 7 | END | Mailing address, as defined in a processing option. |
0100 | 8 | NUM | Mailing address, as defined in a processing option. |
0100 | 9 | COMPL | Mailing address, as defined in a processing option. |
0100 | 10 | BAIRRO | CIF data $N description of UDC 76B/NE |
0100 | 11 | FONE | Phone number.
The value of F0115. PAR1 + PH1 when PHTP is blank for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 12 | FAX | Fax number.
The value of F0115. PAR1 + PH1 when PHTP equals FAX for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 13 | Email address.
The value of F01151.EMAL when AETP equals E for the accountant in the SPED Fiscal Constant Setup program. |
0100 | 14 | COD_MUN | City code.
The city code associated with the address book number for the accountant in the SPED Fiscal Constant Setup program as set up in the Supplemental Database program (P0092). |
0150 | 1 | REG | Fixed value of 0150. |
0150 | 2 | COD_PART | Address number. |
0150 | 3 | NOME | Mailing number from F0111.MLNM. |
0150 | 4 | COD_PAIS | Country from F0116.CTR
A value from the NFe IBGE Country Code (76B/CD) UDC table. |
0150 | 5 | CNPJ | CNPJ number from F0101.TAX. |
0150 | 6 | CPF | CPF number from F76011.AIBCPF or F0101.TAX |
0150 | 7 | IE | State tax ID.
If the contributor is an individual entity (1, 4, or P) then the word Isento, if not, F0101.ABTX2. |
0150 | 8 | COD_MUN | City code.
The city code associated with the address book number as set up in the Supplemental Database program (P0092). |
0150 | 9 | SUFRAMA | SUFRAMA number from F76011.BISC. |
0150 | 10 | END | Mailing address, as defined in a processing option. |
0150 | 11 | NUM | Mailing address, as defined in a processing option. |
0150 | 12 | COMPL | Mailing address, as defined in a processing option. |
0150 | 13 | BAIRRO | CIF data $N description of UDC 76B/NE |
0175 | 1 | REG | Fixed value of 0175. |
0175 | 2 | DT_ALT | Number of the field in the 0150 register that changed, if the Address by Effective Date constant in the Address Book Constants program (P0000) is enabled; otherwise the field is blank. |
0175 | 3 | NR_CAMPO | The new value for the name in the F0016 table, if the Address by Effective Date constant in the Address Book Constants program (P0000) is enabled; otherwise the field is blank. |
0175 | 4 | CONT_ANT | The old value from the F0016 table, if the Address by Effective Date constant in the Address Book Constants program (P0000) is enabled; otherwise the field is blank. |
0190 | 1 | REG | Fixed value of 0190. |
0190 | 2 | UNID | Unit measure code from UDC 00/UM. |
0190 | 3 | DESCR | Unit of measure description from UDC 00/UM. |
0200 | 1 | REG | Fixed value of 0200. |
0200 | 2 | COD_ITEM | Item number.
(F4101.ITM / LITM / AITM) |
0200 | 3 | DESCR_ITEM | Item description from F4101.DSC1. |
0200 | 4 | COD_BARRA | Bar code.
When the value of AN8 is 0 and XRT is UP in the F4104 table, write the value from the CITM.F7611B. |
0200 | 5 | COD_ANT_ITEM | Item number.
0200 | 6 | UNID_INV | Stock unit of measure.
Access the F4101 table (key LITM or ITM) and retrieve the primary unit of measure (IMUOM1). |
0200 | 7 | TIPO_ITEM | Item type from UDC 70/01 table. |
0200 | 8 | COD_NCM | Mercosur code from the UDC 70/02 table. |
0200 | 9 | EX_IPI | Ex code from the UDC 70/03 table. |
0200 | 10 | COD_GEN | Item generic code from the UDC 70/04 table. |
0200 | 11 | COD_LST | Service code from the UDC 70/05 table. |
0200 | 12 | ALIQ_ICMS | Uses the item master number, the company mark up level (AC30 of the company address book) and the state of the company (state field of address book company) to access to the F7608B table then recover the F7608B.TXRL. Uses only state from to access the F7608B, The states always in blanks. |
0205 | 1 | REG | Fixed value of 0205. |
0205 | 2 | DESCR_ANT_ITEM | Description from the F4101.DSC1 table. |
0205 | 3 | DT_INI | Begin date.
View item changes in the F76B0765 table. This field is completed using a value that you enter in the SPED Fiscal Administ Process program. |
0205 | 4 | DT_FIM | End date.
0205 | 5 | COD_ANT_ITEM | Item code of the last item
0206 | 1 | REG | Fixed value of 0206. |
0206 | 2 | COD_COMB | Combustible code.
0220 | 1 | REG | Fixed value of 0220. |
0220 | 2 | UNID_CONV | Converted unit of measure.
Access the F41003 table and retrieve the converted unit of measure (RUM). |
0220 | 3 | FAT_CONV | Conversion factor.
Access the F41003 table and retrieve the conversion factor (CONV). |
0300 | 1 | REG | Fixed value of 0300. |
0300 | 2 | COD_IND_BEM | Fixed asset number from F1201.FLANUMB |
0300 | 3 | IDENT_MERC | Fixed asset type. Values are:
1: Fixed asset 2: Component Retrieve F1201.FANUMB and F1201.FAAAID. If they are equal, it is a fixed asset. If they are different, it is a component. |
0300 | 4 | DESCR_ITEM | Fixed asset description from F1201.FADL01. |
0300 | 5 | COD_PRNC | Principal fixed asset number from the F1201.FAAAID when item 3 is equal to 2. |
0300 | 6 | COD_CTA | GL account for fixed asset from F1201.FAAMCU.FAAOBJ.FAASUB |
0300 | 7 | NR_PARC | Number of quotes.
0305 | 1 | REG | Fixed value of 0305. |
0305 | 2 | COD_CCUS | Cost center from F1201.FALOC. |
0305 | 3 | FUNC | Asset functionalityfrom the supplermental database. |
0305 | 4 | VIDA_UTIL | Asset life from F1202.FLADLM. First record found in ledger AA. |
0400 | 1 | REG | Fixed value of 0400. |
0400 | 2 | COD_NAT | Transaction nature code from F7615B.tnbnop and tnbsop. |
0400 | 3 | DESCR_NAT | Transaction nature description from F7615B.tndesc. |
0450 | 1 | REG | Fixed value of 0450. |
0450 | 2 | COD_INF | Observation fiscal book code from UDC 40/PM. |
0450 | 3 | TXT | Description of 0450- COD_INF |
0460 | 1 | REG | Fixed value of 0460. |
0460 | 2 | COD_OBS | Fiscal observation code.
0460 | 3 | TXT | Description
0500 | 1 | REG | Fixed value of 0500. |
0500 | 2 | DT_ALT | Inclusion/Change date from the F0901.UPMJ or DT_INI field from record 0000 if F0901.UPMJ is greater than DT_INI. |
0500 | 3 | COD_ NAT_CC | Account/Group type code from the B76AGTC field (Account/Group Type Code) in the Brazilian Account Information table (F76B925). |
0500 | 4 | IND_CTA | Account type indicator. Values are:
S: Resumed (Sintetica) (Accounts Group) A: Analytic (Account) If F0901.GMPEC equals N, then S else A. |
0500 | 5 | NÍVEL | Account Level analytic/Accounts group from F0901.GMLDA. |
0500 | 6 | COD_CTA | Accounting Code analytic/Accounts group from F0901.MCU, F0901.OBJ, and F0901.SUB. |
0500 | 7 | NOME_CTA | Account Name analytic/Accounts group from F0901.DL01. |
600 | 1 | REG | Fixed value of 0600. |
600 | 2 | DT_ALT | Inclusion/Change date from F0006.UPMJ or DT_INI field from record 0000 if F0901.UPMJ is greater than DT_INI. |
600 | 3 | COD_CCUS | Cost center number. |
600 | 4 | CCUS | Cost center name from F0006.DL01. |
0990 | 1 | REG | Fixed value of 0990. |
0990 | 2 | QTD_LIN_0 | Quantity of lines in block 0. |
Block 9 controls how the other blocks are joined and includes information about the number of records in the blocks.
9001 | 1 | REG | Fixed value of 9001. |
9001 | 2 | IND_MOV | Movement indicator. Values are:
9900 | 1 | REG | Fixed value of 9900. |
9900 | 2 | REG_BLC | Record code. |
9900 | 3 | QTD_REG_BLC | Quantity of records in the block described in the previous field. |
9990 | 1 | REG | Fixed value of 9990. |
9990 | 2 | QTD_LIN_9 | Quantity of records for block 9. |
9999 | 1 | REG | Fixed value of 9999. |
9999 | 2 | QTD_LIN | Quantity of lines in the file. |
