This appendix contains the following topics:
This appendix lists the values that the JD Edwards EnterpriseOne system provides for the F76B0780 table. Some registers might have several different combinations of values. For those registers, all of the possible values are provided. Some registers have only one valid combination of values. For those registers, only that value is provided. Not all registers have values for all data items. For example, all registers in block 0 are classified as other, and not as input or output records, so no value is provided for the input and output fields, and values for those fields are not described in the tables.
The fields that exist in the F76B0780 table, and that are populated for the registers are:
Version (B76ATCT)
Block (B76BLCK)
Record (B76RECD) (register)
Fiscal Presentation Type (B76FPTY)
Cotepe Input Rule (B76CIR)
Cotepe Output Rule (B76COR)
Cotepe All Rule (B76CAR) (other)
This table lists the register and field values for block C.
RegisterB76RECD | ProfileB76FPTY | InputB76CIR | OutputB76COR |
C001 | A | O | O |
C100 | A | OC | OC |
C105 | A | OC | OC |
C110 | A | OC | OC |
C111 | A | OC | OC |
C112 | A | OC | OC |
C113 | A | OC | OC |
C114 | A | OC | OC |
C115 | A | N | OC |
C116 | A | N | OC |
C120 | A | OC | N |
C130 | A | N | OC |
C140 | A | OC | OC |
C141 | A | C | C |
C160 | A | N | OC |
C165 | A | N | OC |
C170 | A | C | C |
C171 | A | OC | N |
C172 | A | N | OC |
C173 | A | OC | OC |
C174 | A | N | OC |
C175 | A | OC | OC |
C176 | A | OC | OC |
C177 | A | N | OC |
C178 | A | N | OC |
C179 | A | N | OC |
C190 | A | C | C |
C195 | A | OC | OC |
C197 | A | OC | OC |
C300 | A | N | N |
C310 | A | N | N |
C320 | A | N | N |
C321 | A | N | N |
C350 | A | N | OC |
C370 | A | N | C |
C390 | A | N | C |
C400 | A | N | OC |
C405 | A | N | C |
C410 | A | N | OC |
C420 | A | N | C |
C425 | A | N | N |
C460 | A | N | C |
C470 | A | N | C |
C490 | A | N | C |
C495 | A | N | C |
C500 | A | OC | OC |
C510 | A | N | C |
C590 | A | C | C |
C600 | A | N | N |
C601 | A | N | N |
C610 | A | N | N |
C690 | A | N | N |
C700 | A | N | OC |
C790 | A | N | C |
C791 | A | N | OC |
C800 | A | N | OC |
C850 | A | N | OC |
C860 | A | N | OC |
C890 | A | N | OC |
C990 | A | O | O |
C001 | B | O | O |
C100 | B | OC | OC |
C105 | B | OC | OC |
C110 | B | OC | OC |
C111 | B | OC | OC |
C112 | B | OC | OC |
C113 | B | OC | OC |
C114 | B | OC | OC |
C115 | B | N | OC |
C116 | B | N | OC |
C120 | B | OC | N |
C130 | B | N | OC |
C140 | B | OC | OC |
C141 | B | C | C |
C160 | B | N | OC |
C165 | B | N | OC |
C170 | B | C | C |
C171 | B | OC | N |
C172 | B | N | OC |
C173 | B | OC | OC |
C174 | B | N | OC |
C175 | B | OC | OC |
C176 | B | OC | OC |
C177 | B | N | OC |
C178 | B | N | OC |
C179 | B | N | OC |
C190 | B | C | C |
C195 | B | OC | OC |
C197 | B | OC | OC |
C300 | B | N | OC |
C310 | B | N | OC |
C320 | B | N | C |
C321 | B | N | C |
C350 | B | N | N |
C370 | B | N | N |
C390 | B | N | N |
C400 | B | N | OC |
C405 | B | N | C |
C410 | B | N | OC |
C420 | B | N | C |
C425 | B | N | C |
C460 | B | N | N |
C470 | B | N | N |
C490 | B | N | C |
C495 | B | N | C |
C500 | B | OC | N |
C510 | B | N | N |
C590 | B | C | N |
C600 | B | N | OC |
C601 | B | N | OC |
C610 | B | N | C |
C690 | B | N | C |
C700 | B | N | OC |
C790 | B | N | C |
C791 | B | N | OC |
C800 | B | N | OC |
C850 | B | N | OC |
C860 | B | N | OC |
C890 | B | N | OC |
C990 | B | O | O |
This table lists the registers and field values for block D.
D001 | A | O | O |
D100 | A | OC | OC |
D110 | A | N | C |
D120 | A | N | C |
D130 | A | N | C |
D140 | A | N | C |
D150 | A | N | C |
D160 | A | N | C |
D161 | A | N | OC |
D162 | A | N | OC |
D170 | A | N | C |
D180 | A | N | OC |
D190 | A | C | C |
D300 | A | N | OC |
D301 | A | N | OC |
D310 | A | N | C |
D350 | A | N | OC |
D355 | A | N | C |
D360 | A | N | OC |
D365 | A | N | C |
D370 | A | N | C |
D390 | A | N | C |
D400 | A | N | OC |
D410 | A | N | C |
D411 | A | N | OC |
D420 | A | N | C |
D500 | A | OC | OC |
D510 | A | N | C |
D520 | A | N | OC |
D530 | A | N | OC |
D590 | A | C | C |
D600 | A | N | N |
D610 | A | N | N |
D620 | A | N | N |
D690 | A | N | N |
D695 | A | N | OC |
D696 | A | N | C |
D697 | A | N | OC |
D990 | A | O | O |
D001 | B | O | O |
D100 | B | OC | OC |
D110 | B | N | OC |
D120 | B | N | C |
D130 | B | N | C |
D140 | B | N | C |
D150 | B | N | C |
D160 | B | N | C |
D161 | B | N | N |
D162 | B | N | OC |
D170 | B | N | C |
D180 | B | N | OC |
D190 | B | C | C |
D300 | B | N | OC |
D301 | B | N | OC |
D310 | B | N | C |
D350 | B | N | OC |
D355 | B | N | C |
D360 | B | N | OC |
D365 | B | N | C |
D370 | B | N | N |
D390 | B | N | C |
D400 | B | N | OC |
D410 | B | N | N |
D411 | B | N | N |
D420 | B | N | C |
D500 | B | OC | N |
D510 | B | N | N |
D520 | B | N | N |
D530 | B | N | N |
D590 | B | C | N |
D600 | B | N | OC |
D610 | B | N | C |
D620 | B | N | OC |
D690 | B | N | C |
D695 | B | N | OC |
D696 | B | N | C |
D697 | B | N | OC |
D990 | B | O | O |
This table lists the registers and field values for block E.
Register(B76RECD) | OtherB76CAR |
E001 | O |
E100 | O |
E110 | O |
E111 | OC |
E112 | OC |
E113 | OC |
E115 | OC |
E116 | OC |
E200 | OC |
E210 | C |
E220 | OC |
E230 | OC |
E240 | OC |
E250 | OC |
E500 | OC |
E510 | OC |
E520 | C |
E530 | OC |
E990 | O |
This table lists the registers and field values for block G.
G001 | O |
G100 | OC |
G125 | C |
G126 | OC |
G130 | C |
G140 | C |
G990 | O |
This table lists the registers and field values for block H.
H001 | O |
H005 | OC |
H010 | OC |
H990 | O |
This table lists the registers and field values for block 1.
1001 | O |
1100 | OC |
1105 | OC |
1110 | OC |
1200 | OC |
1210 | OC |
1300 | OC |
1310 | OC |
1320 | OC |
1350 | OC |
1360 | OC |
1370 | OC |
1400 | OC |
1500 | OC |
1510 | OC |
1600 | OC |
1700 | OC |
1710 | OC |
1800 | OC |
1990 | OC |
1910 | OC |
1920 | OC |
1921 | OC |
1922 | OC |
1923 | OC |
1925 | OC |
1926 | OC |
This table lists the values for block 0:
0000 | O |
0001 | O |
0005 | O |
0015 | OC |
0100 | O |
0150 | OC |
0175 | OC |
0190 | OC |
0200 | OC |
0205 | OC |
0206 | OC |
0220 | OC |
0300 | OC |
0305 | OC |
0400 | OC |
0450 | OC |
0460 | OC |
0500 | N |
0600 | C |
0990 | O |
This table lists the registers and field values for block 9.
9001 | O |
9900 | O |
9990 | O |
9999 | O |
