This appendix contains the following topics:
Each block maintains a set of workfiles containing the keys of the master information that is referred to and must be reported in the output file. Block 0 generation is based on the information extracted in the previous blocks contained in the workfile. If you add logic to populate any field that must be reported in the block 0 you must call the appropriated available business function to update the corresponding workfile. Thus, the UBEs of the block 0 will include the information for this field in the output tables.
The following table lists the fields and the corresponding business function that the system calls in order to update the workfiles:
Field | Description | Business Function |
COD_PART | Address Number | N76B0800 - SPED Fiscal - Address Book - BRA - 76B |
COD_ITEM / UNIT | Item Number / Unit of Measure | N76B0801 - SPED Fiscal - Items and UM - BRA - 76B |
COD_NAT | Transaction Nature | N76B0805 - SPED Fiscal - Transaction Nature - BRA - 76B |
COD_INF | Message Code | N76B0806 - SPED Fiscal - Messages information - BRA - 76B |
COD_CCUS | Cost Center | N76B0807 - SPED Fiscal - Cost Center - BRA - 76B |
UF | State | N76B0808 - State - BRA - 76B |
COD_CTA | GL Account | N76B0740 - SPED Fiscal - Account Workfile Operations |
In order to allow reprocessing, the UBEs call the business function N76B0810 SPED Fiscal - Delete Workfile - BRA - 76B at the beginning of the process to clear the workfiles for the corresponding block and job number.
Figure D-1 Example of the N76B0801 Business Function
