This chapter contains the following topics:
This section provides an overview of Spanish VAT.
If you work with Spanish VAT, you should understand these terminology and principles:
VAT returns for each month must be completed on a special form and filed with the local tax office on the 20th of the month.
You must pay any excess output VAT over input VAT at the time of filing.
To be exempt from VAT, the business must work within these guidelines:
Goods must be physically moved to another EU-member country.
Customers must have VAT identification codes.
Invoices must display applicable VAT numbers.
Goods cannot be of a special category, such as vehicles.
This table lists the country-specific setup and functionality for Spain.
Setup or Process | Description |
UDCs (user-defined codes) | In addition to the base software UDCs:
Companies and individuals | To set up companies and individuals for Spain:
Customers and suppliers | You can generate reports for customer and supplier balances. |
Chart of accounts | Spain uses a chart of accounts that is different from the standard chart of accounts provided.
See Understanding the Alternate Chart of Accounts for Spain. |
Bank accounts | When setting up bank accounts for Spain:
Invoice processing | In addition to standard invoice processing, you can print invoices with an attached International Payment Instructions (IPI). To print these invoices and attachments:
Accounts Receivable draft processing | A validation routine exists for bank IDs and bank accounts. The system uses the validation routine when you process accounts receivable drafts.
To use draft processing for accounts receivables in Spain:
Payment processing | A validation routine exists for bank IDs and bank accounts. The system uses the validation routine when you process EFT payments.
Before processing payments in Spain:
Intracommunity VAT | Before you process VAT reportable transactions for Spain, set up intracommunity tax rate areas. |
Tax processing and reporting | JD Edwards EnterpriseOne provides these VAT reports:
See Using Additional Reports for Spain. Other required tax reports and filings for Spain include:
Fixed asset depreciation | JD Edwards EnterpriseOne software provides a predefined depreciation method for Spain. |
Financial reports | To set up your system for financial statements reports for Spain, set up:
To generate financial statement reports, run the Generate Financial Report program (R749110). |
Intrastat and other European Union reporting | See "Setting Up European Union (EU) and SEPA Functionality" in the JD Edwards EnterpriseOne Applications Localizations for European Reporting and SEPA Processing Implementation Guide. |
Integrity reports | JD Edwards EnterpriseOne software provides these integrity reports for Spain:
Oracle Business Accelerator | The JD Edwards EnterpriseOne Oracle Business Accelerator solution is available for Spain, as well as other countries. The preconfigured data that are part of the Oracle Business Accelerator solution is based on business processes that have been designed according to the best business practices for a specific country and industry. |
