This chapter contains the following topics:
Section 12.4, "Printing the Late Authenticated Receipt Summary Report"
Section 12.5, "Printing the Late Authenticated Receipt Letter"
Section 12.6, "Viewing a History of Printed Authenticated Receipt Documents"
To reclaim input VAT, you must obtain a signed receipt from the subcontractor that you pay that shows the VAT amount for a certificate. The authenticated receipt includes information about the amount paid and the cumulative amounts for the job. You print and send an authenticated receipt for each payment that you make to a subcontractor. The subcontractor signs and returns the authenticated receipt to you as an acknowledgement of VAT and of the payment received.
To work with authenticated receipts, you:
Print and send an authenticated receipt.
Print the authenticated receipt after you process payments. Many companies send the authenticated receipt with the remittance. The JD Edwards EnterpriseOne software provides two programs to print authenticated receipts.
Log the return of the authenticated receipt.
You log the return so that you can send a reminder if the authenticated receipt is not returned in a timely manner.
Print the authenticated receipt summary to generate a report of the outstanding authenticated receipts.
Send a reminder letter to subcontractors who do not return the authenticated receipt by the due date.
The JD Edwards EnterpriseOne system also provides these programs for authenticated receipt processing:
Authenticated Receipt Print History (P74U0432).
Use this program to review a history of the authenticated receipts for each certificate for a job.
SPC Authenticated Receipt Retention Generation (R74U0426).
The SPC cascade automatically runs this program to generate the journal entries for retention. You run this program independently only when you do not use the automated process.
See Setting Processing Options for SPC Authenticated Receipt Retention Generation (R74U0426) .
This section provides an overview of authenticated receipts and discusses how to:
Run the Authenticated Receipt Print program.
Run the SPC Combined Payment Certificate and Authenticated Receipt program.
Set processing options for SPC Combined Payment Certificate and Authenticated Receipt (R74U0429).
The Authenticated Receipt Print program (R74U0428) generates a document that you send to the subcontractor. It also date stamps the certificate with the receipt date to prevent further documents from being printed. You use data selection to identify the certificate for which you print the document.
The SPC Combined Payment Certificate and Authenticated Receipt program generates a document that has the information that you send in a certificate as well as the information required for an authenticated receipt. The document generated by the SPC Combined Payment Certificate and Authenticated Receipt program meets the requirements of the monthly report that you must send to subcontractors when you withhold tax amounts from payments. Therefore, if you send the combined statement, you do not need to use the Statement of Payment and Deduction program (R74U4040) to generate a statement.
Select Authenticated Receipt Processing (G74U0524), Authenticated Receipt Print.
Select Authenticated Receipt Processing (G74U0524), SPC Combined Payment Certificate and Authenticated.
Processing options enable you to specify default processing values.
Enter 1 to summarize amounts of the certificate. If you leave this processing option blank, the system lists the detail lines from the subcontract purchase order.
Enter the names of those who must sign the document. If you do not enter any names, the report includes no signature lines.
You log the return of the signed authenticated receipt document to assure that your subcontractor acknowledges the receipt of a payment.
This section lists the forms used to log the authenticated receipt return.
Print the late authenticated receipt summary report to review the authenticated receipts for which you have not logged the return. You use this report to determine when to send a reminder letter to your subcontractors.
Run the Late Authenticated Receipt Summary report.
Set processing options for Late Authenticated Receipt Summary (R74U0430).
Select Authenticated Receipt Processing (G74U0524), Late Authenticated Receipt Summary.
Enter the number of days after which an authenticated receipt is considered overdue. If you leave this processing option blank, the system does not use the date that you printed the authenticated receipt to determine the records to print.
Enter 1 to suppress the display of foreign currency amounts. Leave this processing option blank to display foreign currency amounts.
Specify whether to display the check or certificate amount. Values are:
Blank: Certificate amount
1: Cheque amount
This section provides an overview of the late authenticated receipt letter and discusses how to:
Run the Late Authenticated Receipt Letter program.
Set processing options for Late Authenticated Receipt Letter (R74U0431).
You use the Late Authenticated Receipt Letter program (R74U0431) to print a reminder letter to send to a subcontractor who has not returned the authenticated receipt within the requested time frame. When you print the letter, the system prints information about the jobs, certificates, and amounts that were included on the unreturned receipt letter. You can specify in a processing option whether to add text that you set up in the Authenticated Receipt Letter Set-up program (P74U0431).
Select Authenticated Receipt Processing (G74U0524), Late Authenticated Receipt Letter.
Enter a letter name that you set up in the Authenticated Receipt Letter Set-up program. The system prints the text from the letter name that you specify at the bottom of the letter. If you leave this processing option blank, the system prints the number of days after which a letter is past due. You enter the number of days in the Authenticated Receipt Return Period processing option.
Enter a value from the SPC - Application Master (74U/LT) UDC table to specify the letter type.
Enter the number of days after which an authenticated receipt is considered overdue. The system prints this number on the letter.
Specify whether to print the check or certificate amount. Values are:
1: Cheque amount
You use the Authenticated Receipt Print History program (P74U0432) to view information about the late authenticated receipt letters that you printed from the Late Authenticated Receipt Letter program.
This section lists the forms used to view a history of printed late authenticated receipt documents.
Form Name | Form ID | Navigation | Usage |
Work With Authenticated Receipt Prints | W74U0432A | Authenticated Receipt Processing (G74U0524), Authenticated Receipt Print History | Review and select records. |
Late Letter Print History | W74U0432C | Select a record on the Work With Authenticated Receipt Prints form and then click Select. | Review the dates of the certificate, authenticated receipt document, and late authenticated receipt letters. You can also review the letter type and name and system information for the person who printed the letter. |
