This chapter includes these topics:
Section 8.2, "Asset Master - Equipment Extensions Business Services - EquipmentManager"
Section 8.3, "Asset Master - Equipment Extensions Batch Export Programs"
This chapter provides detailed information about the business interface components that are available for the Asset Master - Equipment Extensions business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Business Services | The EquipmentManager published business service (JP17000) manages these business services: |
| Real-Time Events | This list includes the real-time events for the Asset Master - Equipment Extensions business object:
This event is documented in the Equipment Location chapter. For detailed information, see Section 10.2, "Equipment Locations Real-Time Events." |
| Batch Export Programs | This list includes the batch export programs for the Asset Master - Equipment Extensions business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
The EquipmentManager web service (JP170001) manages the processing of equipment-related web service operations. This table includes a description of the EquipmentManager web service operations:
| Operation | Description |
| EquipmentProcessor | Use this operation to add new equipment records, or change existing equipment records in the JD Edwards EnterpriseOne system. |
| EquipmentQueryProcessor | Use this operation to retrieve and review equipment records that are stored in the JD Edwards EnterpriseOne database. |
To access Javadoc for the EquipmentManager web service and its related operations, review these Javadoc packages:
JP170001 (EquipmentManager)
J1700001 (equipmentProcessor)
J1700002 (equipmentQueryProcessor)
The equipmentProcessor web service operation is an inbound transaction operation that enables consumers to add new equipment records to the JD Edwards EnterpriseOne system, or to change existing equipment records. The operation uses the CRMInstalledBaseProcessing business function (N1702710) to process equipment information.
If the operation completes successfully, all data additions and changes are updated in these JD Edwards EnterpriseOne tables:
Asset Master table (F1201)
Equipment Master Extension table (F1217)
If the operation encounters errors while processing, no updates are made to the JD Edwards EnterpriseOne tables, and the error messages are returned to the consumer.
Before you use this operation, you can set business service properties to specify how the system processes equipment data. This table includes information about the business service properties that the EquipmentProcessor operation uses:
| Group | Key | Description | Default Value |
| J1700001 | J1700001_EQ_MBF_VERSION | Use this property to specify the version of the Equipment Master Revisions application (P1702) that the CRMInstalledBase business function (N1702710) uses to process equipment information. | ZJDE0001 |
This table includes information that can help determine whether the EquipmentProcessor operation is functioning correctly:
| Question | Answer |
| How can I tell if the operation completes successfully? | If the operation completes successfully, all changes or additions are updated in the JD Edwards EnterpriseOne system.
The records that are returned to the consumer include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system. At a minimum, the system returns non-zero values for these fields:
| If I encounter errors while process a transaction, do I need to reverse the transaction? | This operation uses standard transaction processing. If the system encounters errors during processing, no data in the JD Edwards EnterpriseOne system is updated. No manual updates are required. |
| Does this operation use record reservation? | No. The operation does not reserve records within the JD Edwards EnterpriseOne system during processing. |
The EquipmentQueryProcessor web service operation is a database query operation that enables consumers to retrieve and review equipment records from the JD Edwards EnterpriseOne system. The operation retrieves data from these EnterpriseOne tables:
If the operation encounters errors, processing stops and the errors are returned to the consumer.
Before you use this operation, you can set business service properties to specify how the system retrieves data from the JD Edwards EnterpriseOne database. This table includes information about the business service properties that the EquipmentQueryProcessor operation uses:
| J1700002 | J1700002_V1201R_MAX_GRID_ROWS_RETURNED | Use this business service property to specify the maximum number of records the operation can return for a query. | 20 |
Note: It is strongly recommended that you set this business service property to a value other than 0 (zero). If you leave this value set to 0, the system returns all matching records, which could impact performance. |
This table includes information that can help determine whether the EquipmentQueryProcessor operation is functioning correctly:
| Question | Answer |
| How can I tell if the operation completes successfully? | If the operation completes successfully, zero to many records that match the selection criteria are returned to the consumer. If the operation completes successfully, but finds no matching records, a record count of zero (0) is returned.
| If I encounter errors while processing a transaction, do I need to reverse the transaction? | This is a database query operation that does not perform transactions. If you encounter errors during processing, review your search criteria and business service property settings and try your query again. If the operation does not return any records, verify that records matching your query exist in the JD Edwards EnterpriseOne database. |
You use batch export programs to retrieve and format data from the JD Edwards EnterpriseOne database so that it can be used by an external software system.
This table lists and describes the available batch export programs that are associated with the Asset Master - Equipment Extensions business object:
