This chapter includes these topics:
Section 21.1, "Accounts Receivable Deduction Activities Overview"
Section 21.2, "Accounts Receivable Deduction Activities Real-Time Events"
This chapter provides detailed information about the business interfaces that are available for the Accounts Receivable Deduction Activities business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Real-Time Events | This list includes the real-time events for the Accounts Receivable Deduction Activities business object:
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Accounts Receivable Deduction Activities business object, which includes the RTDAOUT event, which contains the RTDADTL single event.
RTDAOUT is used by the JD Edwards EnterpriseOne system to provide Accounts Receivable deduction information to third-party systems.
Event Type | Event Description | Event Category | Event Aggregate | Product Code |
RTDAOUT | AR Deduction Activities | RTE | Container
Container event for: RTDADTL (D03B0208B) |
H03B |
Please see the real-time event that is contained by this event for information about the event fields.
Conceptual Approach
Deduction processing creates a new record in the A/R Deduction Management table (F03B40). The R45730 program is run to select the appropriate deduction records and to trigger a real-time notification. The system then publishes a notify event indicating that deductions were created in the A/R Deduction Management table. This event contains the recently selected deduction and its pertinent information.
Objects that Can Initiate the Event
The following object can initiate the event, and all single events contained within the event:
R03B0208 - Extract and Export Open Siebel Deductions
RTDADTL is used by the JD Edwards EnterpriseOne system to provide Accounts Receivable deduction information to third-party systems.
Event Name | Event Description | Event Type | Event Category | Product Code | Data Structure | Event Relationship |
RTDADTL | AR Deduction Activities Details | RTE | Single | H03B | D03B0208B: Deductions Activity Record | Included in container event RTDAOUT. |
Conceptual Approach
Deduction processing creates a new record in the A/R Deduction Management table (F03B40). The R45730 program is run to select the appropriate deduction records and to trigger a real-time notification for the WSG integration. The WSG integration then publishes a notify event indicating that deductions were created in the A/R Deduction Management table. This event contains the recently selected deduction and its pertinent information.
