This chapter includes these topics:
Section 22.2, "Accounts Receivable Invoice Business Services - ARInvoiceManager"
Section 22.3, "Accounts Receivable Invoice Real-Time Events"
Section 22.4, "Accounts Receivable Invoice Batch Import Programs"
This chapter provides detailed information about the business interfaces that are available for the Accounts Receivable Invoice business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Business Services | The ARInvoinceManager published business service (JP03B000) manages these business services:
| Real-Time Events | This list includes the real-time events for the Accounts Receivable Invoice business object: |
| Batch Import Programs | This list includes the batch import programs for the Accounts Receivable Invoice business object: |
| Additional Interfaces | The Accounts Receivable Invoice business object also uses the following business interfaces:
See Setting Processing Options for Invoice Entry MBF Processing Options (P03B0011). |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the ARInvoiceManager published business service (JP03B000), and the associated business services, which includes:
| Operation | Description |
| processARInvoice (J03B0001) | Use this operation to process the AR Invoice information in the JD Edwards Enterprise One AR Management system. This operation enables you to add, change, delete/void invoices. |
| getARInvoice (J03B0002) | Use this operation to retrieve AR information from the Enterprise One database. The operation uses the user-defined search criteria to retrieve the records. |
| getARInvoiceRevisions (J03B0003) | Use this operation to retrieve AR revisions information from the Enterprise One database. The operation uses the user-defined search criteria to retrieve the records. |
To access Javadoc for the ARInvoiceManager web service and its related operations, review these Javadoc packages:
JP03B000 (ARInvoiceManager)
J03B0001 (ProcessARInvoiceProcessor)
J03B0002 (ARInvoiceQueryProcessor)
J03B0003 (getARInvoiceRevisions)
processARInvoiceProcessor (J03B0001) is a web service operation that calls the processARInvoice method, based on the action of the user. This method enables consumers to add, change, or delete/void invoice records in the Enterprise One database.
When the processARInvoice method is called, the operation calls the BSFNs - ProcessInvoiceHeader_Wrapper (B03B1000), ProcessInvoiceDetail_Wrapper (B03B1000), ProcessGLInvoiceHeader_Wrapper (B03B1000),ProcessGLInvoiceDetail_Wrapper (B03B1000), CommitInvoice_Wrapper (B03B1000), and ARGLClearCache_Wrapper (B03B1000), to add, change, or delete/void Invoice records.
If the operation is successful, the system updates the AR invoice information in the JD Edwards Enterprise One Accounts Receivable system. If the operation encounters errors, processing stops and the errors are returned to the consumer.
Note: Be aware of the following items when using this method:
Before you can use this operation, you can set business properties to specify how the system processes the AR Information. This table includes information about the business service properties that the processARInvoice web service operation uses:
| Group | Key | Description | Default Value |
| J03B0001 | J03B0001_AR_GL_VERSION | Use this business service property to specify the version of the Invoice Entry program that will be used while processing the data. | ZJDE0001 |
| J03B0001 | J03B0001_AR_GL_VERSION | Use this business service property to specify the version of the Journal Entry program that will be used while processing the data. | ZJDE0001 |
This table includes information that can help determine whether the ARInvoiceProcessor operation is functioning correctly:
| Question | Answer |
| How can I tell if the operation completes successfully? | If the operation completes successfully, the system returns a confirmation message to the consumer.
The message includes all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards EnterpriseOne system. At a minimum, the system returns a non-zero value for these fields:
| If I encounter errors while process a transaction, do I need to reverse the transaction? | This operation uses standard transaction processing. In the event that the operation encounters errors, all JD Edwards Enterprise One tables are returned to their original state, and no updates are performed. No manual updates are necessary. |
| Does this operation use record reservation? | This operation reserves records in the JD Edwards Enterprise One system during the change or cancellation of an AR invoice. |
The getARInvoice (J03B0002) is a database query operation that enables consumers to retrieve and review AR Invoice records from the JD Edwards Enterprise One database. The operation returns one or more records to the consumers from the Customer Ledger (F03B11) and Account Ledger (F0911) tables that meet the specified search criteria.
Before you can use this operation, you can set business properties to specify how the system processes the invoice information. This table includes information about the business service properties that the getARInvoice web service operation uses:
| J03B0002 | J03B0002_MAX_ROWS_F03B11 | Use this business service property to specify the maximum number of AR records the operation can return for a query.
The default value is set to 100; however, this might limit the returned data when searching for AR records. If you find that limiting the number of results returned to 100 does not enable you to find the records you are searching for, it is acceptable to increase this value to a number that fits your business needs.. |
100 |
| J03B0002 | J03B0002_MAX_ROWS_F0911 | Use this business service property to specify the maximum number of GL records the operation can return for a query.
The default value is set to 100; however, this might limit the returned data when searching for GL Records. If you find that limiting the number of results returned to 100 does not enable you to find the GL records you are searching for, it is acceptable to increase this value to a number that fits your business needs. |
100 |
The following table includes information that can help determine whether the ARInvoiceQueryProcessor (J03B0002) operation is functioning correctly:
| Question | Answer |
| How can I tell if the operation completes successfully? | If the operation completes successfully, zero to many records are returned, based on the selection criteria.
The records that are returned to the consumer include all of the fields that are listed in the response interface for this operation. However, some of those fields can contain blank or zero values, depending on the data that exists in the JD Edwards Enterprise One system. At a minimum, the system returns a non-zero value for these fields:
| If I encounter errors while process a transaction, do I need to reverse the transaction? | This is a database query operation that does not perform transactions.
If you encounter errors during processing, review your search criteria and business service property settings and try your query again. If the operation does not return any records, verify that records matching your query exist in the JD Edwards Enterprise One database. |
| Does this operation use record reservation? | No. This operation does not reserve records. |
The getARInvoiceRevisions (J03B0003) is a database query operation that enables consumers to retrieve and review AR invoice revisions records from the JD Edwards Enterprise One database. The operation returns one or more records to the consumers from the Invoice Revisions (F03B112) table that meets the specified search criteria.
Before you can use this operation, you can set business properties to specify how the system processes the AR Revisions Information. This table includes information about the business service properties that the getARInvoiceRevisions web service operation uses:
| J03B0003 | J03B0003_MAX_ROWS_F03B112 | Use this business service property to specify the maximum number of AR records the operation can return for a query.
The default value is set to 100; however, this might limit the returned data when searching for AR revision records. If you find that limiting the number of results returned to 100 does not enable you to find the records you are searching for, it is acceptable to increase this value to a number that fits your business needs.. |
100 |
The following table includes information that can help determine whether the ARInvoiceRevisionsQueryProcessor (J03B0003) operation is functioning correctly:
| Question | Answer |
ProcessARInvoiceRecurringInformationProcessor (J03B0004) is a web service operation that calls the processARInvoiceRecurringInformation method. This method enables consumers to change the recurring information of AR recurring invoice records in the JD Edwards Enterprise One database.
When the processARInvoiceRecurringInformation method is called, the operation calls the BSFN - ProcessInvoiceRecurringInfo (B03B1001) to change the recurring information of invoice records.
If the operation is successful, the system updates the AR invoice recurring information in the JD Edwards Enterprise One Accounts Receivable system. If the operation encounters errors, processing stops and the errors are returned to the consumer.
The following table includes information that can help determine whether the ProcessARInvoiceRecurringInformationProcessor (J03B0004) operation is functioning correctly:
| Question | Answer |
| How can I tell if the operation completes successfully? | If the operation completes successfully, no errors are returned to the consumer. |
This section describes the available real-time events associated with the Accounts Receivable Invoice business object which include:
RTARIVOUT is used by the JD Edwards EnterpriseOne system to inform third-party systems when an Invoice has been added, changed, or deleted in order to keep the two systems synchronized.
| Event Type | Event Description | Event Category | Event Aggregate | Product Code |
| RTARIVOUT | Accounts Receivable Invoice | RTE | Container
Container event for: RTARIVOUTA (D03B1011) RTAVIROUTB (D0901011) |
03B |
Conceptual Approach
An invoice is added, modified or deleted in the JD Edwards EnterpriseOne system, which creates, modifies, or deletes a record in the Customer Ledger table (F03B11) and Account Ledger table (F0911).
Objects that Can Initiate the Event
The following objects can initiate the event, and all single events contained within the event:
B0000080 - Update A/R Post Status Flags
B03B0011- Invoice Entry Master Business
B03B0012 - F03B14 Apply Receipt to Invoice
B03B0013 - Delete Invoice from F03B11
B03B0015 - Void Invoice
B03B0018 - A/R Speed Status Change
B03B0019 - F03B13 Void/NSF Receipt
B03B0023 - F03B14 Void/Delete Receipt
B03B0112 - F03B21 - Write Notification Detail from Cache
B03B0116 - F03B23 - BF Write Fee Journal
B03B0179 - Void NSF Draft At Any Status
N03B0077 - F03B41 - Void all Activity Records
N03B0198 - Update A/R from Address Book
P03B120 - Recurring Invoice Review
P03B40 - Deduction Processing
R15117 - Lease Global Update
R155001 - Real Estate Management Statement
R15903 - Priority Code Reapplication
R15906 - Billing Detail Service/Tax Date
RTAVIROUTA is used by the JD Edwards EnterpriseOne system to inform third-party systems when an invoice pay item has been added, changed, or deleted in order to keep the two systems synchronized.
| Event Name | Event Description | Event Type | Event Category | Product Code | Data Structure | Event Relationship |
| RTARIVOUTA | AR Invoice Details | RTE | Single | D03B1011 - AR Inv Real Time Event | Included in container event RTARIVOUT. |
Conceptual Approach
An Invoice PayItem is added, modified or deleted in the JD Edwards EnterpriseOne system, which creates, modifies, or deletes a record in the Customer Ledger table (F03B11).
RTARIVOUTB is used by the JD Edwards EnterpriseOne system to inform third-party systems when an GL distribution line for an invoice has been added, changed, or deleted in order to keep the two systems synchronized.
| RTARIVOUTB | AR Invoice GL Details | RTE | Single | D0901011 - GL Inv Real Time Event | Included in container event RTARIVOUT. |
Conceptual Approach
The GL distribution line is added, modified or deleted for an invoice in the JD Edwards EnterpriseOne system, which creates, modifies, or deletes a record in the Account Ledger table (F0911).
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Accounts Receivable Invoice business object:
