38 Currency Information
This chapter includes these topics:
38.1 Currency Information Overview
This chapter provides detailed information about the business interfaces that are available for the Currency Information business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Business Services The Currency Information business object uses the lookupCurrencyCodes (J0000060) method.
For additional details on this service, see Section 39.2, "FoundationEnvironmentManager Business Services."
Real-Time Events This list includes the real-time events for the Currency Information business object:
  • RTCROUT
Batch Import Programs This list includes the batch import programs for the Currency Information business object:
  • External Exchange Rate Processor program (R0015Z1)
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
38.2 Currency Information Real-Time Events
This section describes the available real-time events associated with the Currency Information business object, which include:
  • RTCROUT
38.2.1 RTCROUT
RTCROUT is used by the JD Edwards EnterpriseOne system to notify third-party systems of currency exchange rate additions, changes, or deletions.
Event Type Event Description Event Category Event Aggregate Product Code Data Structure
RTCROUT Currency Information RTE Single H09 D0900200B: Currency Exchange Rates Real Time Event Notification - B
38.2.1.1 Conceptual Approach
When a user adds, modifies, or deletes a currency exchange rate in the JD Edwards EnterpriseOne system, the system updates the Currency Exchange Rate table (F0015) and publishes the RTCROUT event. This event contains all columns from the modified currency exchange rate record and an action code specifying what action was performed on the data (add, change, or delete).
38.2.1.2 Objects that Can Initiate the Event
These objects can initiate the RTCROUT event:
  • F0015 - Currency Exchange Rates table trigger
38.3 Currency Information Batch Import Programs
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Currency Information business object:
Program and Program Type Description Available Documentation
This is a temporary table import program.
After you upload exchange rates from an external source into the F0015Z1 and, if necessary, revise the rates, run the External Exchange Rate Processor program (R0015Z1). This program processes information from the F0015Z1 workfile and stores it in the F0015 table. See this topic:
