This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Inventory Location Master business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Real-Time Events | This list includes the real-time events for the Inventory Location Master business object: |
Batch Import Programs | This list includes the batch import programs for the Inventory Location Master business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Item Master business object, which include:
RTIBOUT is used by the JD Edwards EnterpriseOne system to notify third-party systems when an item location has been added, changed, or deleted in order to keep the two systems synchronized. Adding an Item Balance record that does not have quantity information or deleting an Item Balance record will not be published.
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure |
RTIBOUT | Item Balance by Location | RTE | Container
Container event for RTIBOUTA (D4101660A). |
H41 | D4101660A: Item Balance Real Time Event Notification Template |
Conceptual Approach
An inventory location that has been added, changed, or deleted in the JD Edwards EnterpriseOne system updates the Item Location (F41021) table. When an item balance record is modified, an RTIBOUT real-time event notification is published.
Currently, this real-time event is used only by the APS integration.
Objects that Can Initiate the Event
These objects can initiate the RTIBOUT event:
XT4111Z1 - Inventory Transactions
XF41021 - Update F41021 Locations
B4100430 - Update Misc F41021 Fields
B4101370 - F41021 Update Quantities
N4202100 - F41021 Commitments Processing
B4100100 – Location Status Update
B4101810 – Process F41021WF Records
XF41021P – Update F41021 Locationsfor OT Orders
P41024 – Location Revisions
P4108 - Lot Master
R41083 – Update Effective Lots
RTIBOUTA is used by the JD Edwards EnterpriseOne system to notify third-party systems when an item location has been added, changed, or deleted in order to keep the two systems synchronized. Adding an Item Balance record that does not have quantity information or deleting an Item Balance record will not be published.
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
RTIBOUTA | Item Balance by Loc Details | RTE | Single | H41 | D4101660A: Item Balance Real Time Event Notification Template | Included in container event RTIBOUT |
Conceptual Approach
An inventory location that has been added, changed, or deleted in the JD Edwards EnterpriseOne system updates the Item Location (F41021) table. When an item balance record is modified, an RTIBOUT real-time event notification is published. The RTIBOUT real-time event notification contains the RTIBOUTA event.
RTIBOUT2 is used by the JD Edwards EnterpriseOne system to notify third-party systems when an item location has been added, changed, or deleted in order to keep the two systems synchronized. Adding an Item Balance record that does not have quantity information or deleting an Item Balance record will not be published.
RTIBOUT2 | Item Balance by Loc Version 2 | RTE | Container
Container event for RTIBOUTB (D4101661A). |
H41 | D4101661A: Item Balance Real Time Event Notification Template |
Conceptual Approach
An inventory location that has been added, changed, or deleted in the JD Edwards EnterpriseOne system updates the Item Location (F41021) table. When an item balance record is modified, an RTIBOUT2 real-time event notification is published.
These objects can initiate the RTIBOUT2 event, and the single event contained within the event:
P4108 - Lot Master
RTIBOUTB is used by the JD Edwards EnterpriseOne system to notify third-party systems when an item location has been added, changed, or deleted in order to keep the two systems synchronized. Adding an Item Balance record that does not have quantity information or deleting an Item Balance record will not be published.
RTIBOUTB | Item Bal by Loc Dtl Version2 | RTE | Single | H41 | D4101661A: Item Balance Real Time Event Notification Template | Included in container event RTIBOUT |
Conceptual Approach
An inventory location that has been added, changed, or deleted in the JD Edwards EnterpriseOne system updates the Item Location (F41021) table. When an item balance record is modified, an RTIBOUT2 real-time event notification is published. The RTIBOUT2 real-time event notification contains the RTIBOUTB event.
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Inventory Location Mastger business object:
