74 Test Result
This chapter includes these topics:
74.1 Test Result Overview
This chapter provides detailed information about the business interfaces that are available for the Test Result business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Batch Import Programs This list includes the batch import programs for the Test Result business object:
  • Batch Test Results program (R3711Z1I)
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
74.2 Test Result Batch Import Programs
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Test Result business object:
Program and Program Type Description Available Documentation
Batch Test Results program (R3711Z1I) You run the Batch Test Results program (R3711Z1I) to copy the information from the unedited transaction table to the Test Results table (F3711). See this topic:
