75 UOM Conversions
This chapter includes these topics:
75.1 UOM Conversions Overview
This chapter provides detailed information about the business interfaces that are available for the UOM Conversions business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Real-Time Events This list includes the real-time events for the UOM Conversions business object:
  • RTUOMOUT, which is a container event for RTUOMDTL.
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
75.2 UOM Conversions Real-Time Events
This section describes the available real-time events associated with the Item Master business object, which include:
75.2.1 RTUOMOUT
RTUOMOUT is a container event generated by the JD Edwards EnterpriseOne system to notify third-party systems of adds and changes to unit of measure conversions.
Event Type Event Description Event Category Event Aggregate Product Code
RTUOMOUT Item UOM Conversion Master RTE Container
Container event for RTUOMDTL (D4102170A).
H41
Conceptual Approach
Unit of measure conversion information that is added or modified for a given item in the Unit of Measure table F41002 is sent out in a real-time event.
Special Setup
If the system constant Unit of Measure Conversion by Branch is Off, all unit of measure (UOM) conversions for the item and a blank branch plant are sent in the real-time event.
If the system constant Unit of Measure Conversion by Branch is On and the Default Branch Plant processing option on version ZJDE0001 of UOM Conversion Real Time Wrapper Application (P4102170) is blank, the UOM conversions for the item and all branch plants are sent in the real-time event.
If the system constant Unit of Measure Conversion by Branch is On and the Default Branch Plant processing option on version ZJDE0001 of UOM Conversion Real Time Wrapper Application (P4102170) is 1, the UOM conversions for the item and the current branch plant are sent in the real-time event.
Objects that Can Initiate the Event
The P41002 - Unit of Measure Conversions - Item program can initiate the RTUOMOUT event.
75.2.1.1 RTUOMDTL
RTUOMDTL is a single event that is generated by the JD Edwards EnterpriseOne system to provide unit of measure conversion information.
Event Type Event Description Event Category Event Aggregate Product Code Data Structure Event Relationship
RTUOMDTL Item UOM Conversion Details RTE Single H41 D4102170A: UOM Conversion Real Time Data Included in container event RTUOMOUT.
Conceptual Approach
Unit of measure conversion information added or modified for a given item in the Unit of Measure table F41002 is sent out in a real-time event.
