Chapter 34. Upgrading Berkeley DB 3.0 applications to Berkeley DB 3.1
Table of Contents
Release 3.1: introduction
Release 3.1: DB_ENV->open, DB_ENV->remove
Release 3.1: DB_ENV->set_tx_recover
Release 3.1: DB_ENV->set_feedback, DB->set_feedback
Release 3.1: DB_ENV->set_paniccall, DB->set_paniccall
Release 3.1: DB->put
Release 3.1: identical duplicate data items
Release 3.1: DB->stat
Release 3.1: DB_SYSTEM_MEM
Release 3.1: log_register
Release 3.1: memp_register
Release 3.1: txn_checkpoint
Release 3.1: environment configuration
Release 3.1: Tcl API
Release 3.1: DB_TMP_DIR
Release 3.1: log file pre-allocation
Release 3.1: Upgrade Requirements
The following pages describe how to upgrade applications coded against the Berkeley DB 3.0 release interfaces to the Berkeley DB 3.1 release interfaces. This information does not describe how to upgrade Berkeley DB 1.85 release applications.
