Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Data Services Developer's Guide Oracle Solaris Cluster |
1. Overview of Resource Management
Analyzing the Application for Suitability
Determining the Interface to Use
Setting Up the Development Environment for Writing a Data Service
How to Set Up the Development Environment
Transferring a Data Service to a Cluster
Setting Resource and Resource Type Properties
Declaring Resource Type Properties
Declaring Resource Type Properties for a Zone Cluster
Declaring Extension Properties
Accessing Resource and Resource Group Property Information
How Methods Are Invoked in Zones
Starting and Stopping a Resource
Deciding Which Start and Stop Methods to Use
Using the Optional Init, Fini, and Boot Methods
Guidelines for Implementing a Fini Method
Implementing Monitors and Methods That Execute Exclusively in the Global Zone
Adding Message Logging to a Resource
Providing Administrative Support for a Resource
Implementing a Failover Resource
Implementing a Scalable Resource
Validation Checks for Scalable Services
Writing and Testing Data Services
Using TCP Keep-Alives to Protect the Server
Coordinating Dependencies Between Resources
Rules for Names Except Resource Type Names
3. Resource Management API Reference
6. Data Service Development Library
8. Sample DSDL Resource Type Implementation
9. Solaris Cluster Agent Builder
12. Cluster Reconfiguration Notification Protocol
A. Sample Data Service Code Listings
B. DSDL Sample Resource Type Code Listings
C. Requirements for Non-Cluster Aware Applications
D. Document Type Definitions for the CRNP
The RMAPI and the DSDL provide process management facilities to implement resource monitors and resource control callbacks. The RMAPI defines the following facilities:
Provides a means of monitoring processes and their descendants, and restarting processes if they die. The facility consists of the pmfadm command for starting and controlling monitored processes, and the rpc.pmfd daemon.
The DSDL provides a set of functions (preceded by the name scds_pmf_) to implement the PMF functionality. See PMF Functions for an overview of the DSDL PMF functionality and for a list of the individual functions.
The pmfadm(1M) and rpc.pmfd(1M) man pages describe this command and daemon in more detail.
A program for running a child program while holding a file lock. This command is convenient to use in shell scripts.
The halockrun(1M) man page describes this command in more detail.
A program for running a child program under timeout control. This command is convenient to use in shell scripts.
The DSDL provides the scds_hatimerun() function to implement the features of the hatimerun command.
The hatimerun(1M) man page describes this command in more detail.
