Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Data Services Developer's Guide     Oracle Solaris Cluster
search filter icon
search icon
Document Information
1.  Overview of Resource Management
2.  Developing a Data Service
Analyzing the Application for Suitability
Determining the Interface to Use
Setting Up the Development Environment for Writing a Data Service
How to Set Up the Development Environment
Transferring a Data Service to a Cluster
Setting Standard Properties
Cluster Properties
Resource Type Properties
Resource Properties
Resource Group Properties
Resource Property Attributes
Node List Properties
Setting Resource and Resource Type Properties
Declaring Resource Type Properties
Declaring Resource Type Properties for a Zone Cluster
Declaring Resource Properties
Declaring Extension Properties
Implementing Callback Methods
Accessing Resource and Resource Group Property Information
Idempotence of Methods
How Methods Are Invoked in Zones
Generic Data Service
Controlling an Application
Starting and Stopping a Resource
Using Start and Stop Methods
Deciding Which Start and Stop Methods to Use
Using the Optional Init, Fini, and Boot Methods
Using the Init Method
Using the Fini Method
Guidelines for Implementing a Fini Method
Using the Boot Method
Monitoring a Resource
Implementing Monitors and Methods That Execute Exclusively in the Global Zone
Adding Message Logging to a Resource
Providing Process Management
Providing Administrative Support for a Resource
Implementing a Failover Resource
Implementing a Scalable Resource
Validation Checks for Scalable Services
Writing and Testing Data Services
Using TCP Keep-Alives to Protect the Server
Testing HA Data Services
Coordinating Dependencies Between Resources
Legal RGM Names
RGM Legal Names
Rules for Names Except Resource Type Names
Format of Resource Type Names
RGM Values
3.  Resource Management API Reference
4.  Modifying a Resource Type
5.  Sample Data Service
6.  Data Service Development Library
7.  Designing Resource Types
8.  Sample DSDL Resource Type Implementation
9.  Solaris Cluster Agent Builder
10.  Generic Data Service
11.  DSDL API Functions
12.  Cluster Reconfiguration Notification Protocol
A.  Sample Data Service Code Listings
B.  DSDL Sample Resource Type Code Listings
C.  Requirements for Non-Cluster Aware Applications
D.  Document Type Definitions for the CRNP
E. Application
Before you begin to develop your data service, you must install the Solaris Cluster development package (SUNWscdev) to have access to the Solaris Cluster header and library files. Although this package is already installed on all cluster nodes, you typically develop your data service on a separate, non-cluster development machine, rather than on a cluster node. In this typical case, you must use the pkgadd command to install the SUNWscdev package on your development machine.
Note - On the development machine, ensure that you are using the Developer or Entire Distribution software group of the Solaris 10 OS.
When compiling and linking your code, you must set particular options to identify the header and library files.
Note - You cannot mix compatibility-mode compiled C++ code and standard-mode compiled C++ code in the Solaris Operating System and Solaris Cluster products. Consequently, if you intend to create a C++ based data service for use on Solaris Cluster, you must use the standard mode to compile that data service.
When you have finished development (on a non-cluster node), you can transfer the completed data service to a cluster for testing.
The procedures in this section describe how to complete the following tasks:
This procedure describes how to install the SUNWscdev package and set the compiler and linker options for data service development.
  1. Become superuser or assume a role that provides solaris.cluster.modify RBAC authorization.
  2. Change directory to the CD-ROM directory that you want.
    # cd cd-rom-directory
  3. Install the SUNWscdev package in the current directory.
    # pkgadd -d . SUNWscdev
  4. In the makefile, specify compiler and linker options that identify the include and library files for your data service code.
    Specify the -I option to identify the Solaris Cluster header files, the -L option to specify the compile-time library search path on the development system, and the -R option to specify the library search path to the runtime linker in the cluster.
    # Makefile for sample data service
    -I /usr/cluster/include
    -L /usr/cluster/lib
    -R /usr/cluster/lib
When you have completed the data service on a development machine, you must transfer the data service to a cluster for testing. To reduce the chance of error during the transfer, combine the data service code and the RTR file into a package. Then, install the package on the Solaris hosts on which you want to run the service.
Note - Agent Builder creates this package automatically.
