Skip Navigation Links
Exit Print View
Oracle GlassFish Server 3.1-3.1.1 Reference Manual
search filter icon
search icon
Document Information
Preface
Oracle GlassFish Server 3.1 Section 1: asadmin Utility Subcommands
add-resources(1)
apply-http-lb-changes(1)
backup-domain(1)
change-admin-password(1)
change-master-broker(1)
change-master-password(1)
collect-log-files(1)
configure-jms-cluster(1)
configure-lb-weight(1)
configure-ldap-for-admin(1)
copy-config(1)
create-admin-object(1)
create-application-ref(1)
create-audit-module(1)
create-auth-realm(1)
create-backup-config(1)
create-cluster(1)
create-connector-connection-pool(1)
create-connector-resource(1)
create-connector-security-map(1)
create-connector-work-security-map(1)
create-custom-resource(1)
create-domain(1)
create-file-user(1)
create-http(1)
create-http-health-checker(1)
create-http-lb(1)
create-http-lb-config(1)
create-http-lb-ref(1)
create-http-listener(1)
create-http-redirect(1)
create-iiop-listener(1)
create-instance(1)
create-jacc-provider(1)
create-javamail-resource(1)
create-jdbc-connection-pool(1)
create-jdbc-resource(1)
create-jmsdest(1)
create-jms-host(1)
create-jms-resource(1)
create-jndi-resource(1)
create-jvm-options(1)
create-lifecycle-module(1)
create-local-instance(1)
create-message-security-provider(1)
create-network-listener(1)
create-node-config(1)
create-node-ssh(1)
create-password-alias(1)
create-profiler(1)
create-protocol(1)
create-protocol-filter(1)
create-protocol-finder(1)
create-resource-adapter-config(1)
create-resource-ref(1)
create-schedule(1)
create-service(1)
create-ssl(1)
create-system-properties(1)
create-threadpool(1)
create-transport(1)
create-virtual-server(1)
delete-admin-object(1)
delete-application-ref(1)
delete-audit-module(1)
delete-auth-realm(1)
delete-backup-config(1)
delete-cluster(1)
delete-config(1)
delete-connector-connection-pool(1)
delete-connector-resource(1)
delete-connector-security-map(1)
delete-connector-work-security-map(1)
delete-custom-resource(1)
delete-domain(1)
delete-file-user(1)
delete-http(1)
delete-http-health-checker(1)
delete-http-lb(1)
delete-http-lb-config(1)
delete-http-lb-ref(1)
delete-http-listener(1)
delete-http-redirect(1)
delete-iiop-listener(1)
delete-instance(1)
delete-jacc-provider(1)
delete-javamail-resource(1)
delete-jdbc-connection-pool(1)
delete-jdbc-resource(1)
delete-jmsdest(1)
delete-jms-host(1)
delete-jms-resource(1)
delete-jndi-resource(1)
delete-jvm-options(1)
delete-lifecycle-module(1)
delete-local-instance(1)
delete-message-security-provider(1)
delete-network-listener(1)
delete-node-config(1)
delete-node-ssh(1)
delete-password-alias(1)
delete-profiler(1)
delete-protocol(1)
delete-protocol-filter(1)
delete-protocol-finder(1)
delete-resource-adapter-config(1)
delete-resource-ref(1)
delete-schedule(1)
delete-ssl(1)
delete-system-property(1)
delete-threadpool(1)
delete-transport(1)
delete-virtual-server(1)
deploy(1)
deploydir(1)
disable(1)
disable-backup-config(1)
disable-http-lb-application(1)
disable-http-lb-server(1)
disable-monitoring(1)
disable-secure-admin(1)
disable-secure-admin-internal-user(1)
disable-secure-admin-principal(1)
enable(1)
enable-backup-config(1)
enable-http-lb-application(1)
enable-http-lb-server(1)
enable-monitoring(1)
enable-secure-admin(1)
enable-secure-admin-internal-user(1)
enable-secure-admin-principal(1)
export(1)
export-http-lb-config(1)
export-sync-bundle(1)
flush-connection-pool(1)
flush-jmsdest(1)
freeze-transaction-service(1)
generate-jvm-report(1)
get(1)
get-client-stubs(1)
get-health(1)
import-sync-bundle(1)
install-node(1)
jms-ping(1)
list(1)
list-admin-objects(1)
list-application-refs(1)
list-applications(1)
list-audit-modules(1)
list-auth-realms(1)
list-backup-configs(1)
list-backups(1)
list-clusters(1)
list-commands(1)
list-components(1)
list-configs(1)
list-connector-connection-pools(1)
list-connector-resources(1)
list-connector-security-maps(1)
list-connector-work-security-maps(1)
list-containers(1)
list-custom-resources(1)
list-domains(1)
list-file-groups(1)
list-file-users(1)
list-http-lb-configs(1)
list-http-lbs(1)
list-http-listeners(1)
list-iiop-listeners(1)
list-instances(1)
list-jacc-providers(1)
list-javamail-resources(1)
list-jdbc-connection-pools(1)
list-jdbc-resources(1)
list-jmsdest(1)
list-jms-hosts(1)
list-jms-resources(1)
list-jndi-entries(1)
list-jndi-resources(1)
list-jvm-options(1)
list-lifecycle-modules(1)
list-log-attributes(1)
list-log-levels(1)
list-message-security-providers(1)
list-modules(1)
list-network-listeners(1)
list-nodes(1)
list-nodes-config(1)
list-nodes-ssh(1)
list-password-aliases(1)
list-persistence-types(1)
list-probes(1)
list-protocol-filters(1)
list-protocol-finders(1)
list-protocols(1)
list-resource-adapter-configs(1)
list-resource-refs(1)
list-schedules(1)
list-secure-admin-internal-users(1)
list-secure-admin-principals(1)
list-sub-components(1)
list-supported-cipher-suites(1)
list-system-properties(1)
list-threadpools(1)
list-timers(1)
list-transports(1)
list-virtual-servers(1)
list-web-context-param(1)
list-web-env-entry(1)
login(1)
migrate-timers(1)
monitor(1)
multimode(1)
ping-connection-pool(1)
ping-node-ssh(1)
recover-transactions(1)
redeploy(1)
restart-domain(1)
restart-instance(1)
restart-local-instance(1)
restore-domain(1)
resume-domain(1)
rollback-transaction(1)
rotate-log(1)
run-script(1)
set(1)
set-log-attributes(1)
set-log-levels(1)
setup-ssh(1)
set-web-context-param(1)
set-web-env-entry(1)
show-component-status(1)
start-cluster(1)
start-database(1)
start-domain(1)
start-instance(1)
stop-cluster(1)
stop-database(1)
stop-domain(1)
stop-instance(1)
stop-local-instance(1)
suspend-domain(1)
undeploy(1)
unfreeze-transaction-service(1)
uninstall-node(1)
unset(1)
unset-web-context-param(1)
unset-web-env-entry(1)
update-admin-server-coordinates(1)
update-admin-server-local-coordinates(1)
update-connector-security-map(1)
update-connector-work-security-map(1)
update-file-user(1)
update-node-config(1)
update-node-ssh(1)
update-password-alias(1)
uptime(1)
validate-multicast(1)
verify-domain-xml(1)
version(1)
Oracle GlassFish Server 3.1 Section 1M: Utility Commands
Oracle GlassFish Server 3.1 Section 5ASC: GlassFish Server Concepts
Oracle GlassFish Server 3.1 Section 5GFP: Events
Index
- removes the specified connector connection pool
Synopsis
delete-connector-connection-pool [--help] [--target target]
[--cascade={false|true}] poolname
Description
The delete-connector-connection-pool subcommand removes the specified connector connection pool.
This subcommand is supported in remote mode only.
Options
--help
Displays the help text for the subcommand.
--target
Do not specify this option. This option is retained for compatibility with earlier releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and displays a warning message that the option is ignored.
--cascade
When set to true, all connector resources associated with the pool, and the pool itself, are deleted. When set to false, the deletion of pool fails if any resources are associated with the pool. The resource must be deleted explicitly or the option must be set to true. Default is false.
Operands
poolname
The name of the connection pool to be removed.
Examples
Example 1 Deleting a Connector Connection Pool
This example deletes the connector connection pool named jms/qConnPool.
asadmin> delete-connector-connection-pool --cascade=false jms/qConnPool
Command delete-connector-connection-pool executed successfully
Exit Status
0
subcommand executed successfully
1
error in executing the subcommand
See Also
create-connector-connection-pool(1), list-connector-connection-pools(1), ping-connection-pool(1)
asadmin(1M)
