Oracle GlassFish Server 3.1 Section 1: asadmin Utility Subcommands
create-connector-connection-pool(1)
create-connector-security-map(1)
create-connector-work-security-map(1)
create-jdbc-connection-pool(1)
create-message-security-provider(1)
create-resource-adapter-config(1)
delete-connector-connection-pool(1)
delete-connector-security-map(1)
delete-connector-work-security-map(1)
delete-jdbc-connection-pool(1)
delete-message-security-provider(1)
delete-resource-adapter-config(1)
disable-http-lb-application(1)
disable-secure-admin-internal-user(1)
disable-secure-admin-principal(1)
enable-secure-admin-internal-user(1)
enable-secure-admin-principal(1)
list-connector-connection-pools(1)
list-connector-security-maps(1)
list-connector-work-security-maps(1)
list-message-security-providers(1)
list-resource-adapter-configs(1)
list-secure-admin-internal-users(1)
list-secure-admin-principals(1)
list-supported-cipher-suites(1)
unfreeze-transaction-service(1)
update-admin-server-coordinates(1)
update-admin-server-local-coordinates(1)
update-connector-security-map(1)
update-connector-work-security-map(1)
Oracle GlassFish Server 3.1 Section 1M: Utility Commands
Oracle GlassFish Server 3.1 Section 5ASC: GlassFish Server Concepts
- removes a system property of the domain, configuration, cluster, or server instance, one at a time
delete-system-property [--help] [--target target_name ] [property_name]
The delete-system-property subcommand deletes a system property of a domain, configuration, cluster, or server instance. Make sure that the system property is not referenced elsewhere in the configuration before deleting it.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
This option specifies the target on which you are deleting the system properties. The valid targets for this subcommand are instance, cluster, configuration, domain, and server. Server is the default option.
The name of the system property to remove.
Example 1 Deleting a System Property
This example deletes the system property named http-listener-port.
asadmin> delete-system-property http-listener-port Command delete-system-property executed successfully.
subcommand executed successfully
error in executing the subcommand
