Use the Level of Detail field to determine the amount of detail wanted in the report. Accept either the default (Detailed) or select Summary. If you select Summary, the following information is returned:
Alarm Reports – The number of alarms
Hardware Reports – The number of hosts
Packages Reports – The number of packages
Patch Reports – The number of patches
