Sun Management Center 3.5 Performance Reporting Manager User's Guide
The Filter field is optional. Click Set Filter to select the desired filter options from the Filter dialog box. Use the drop-down menus to build an expression that creates the report filter wanted. The filtering options are case sensitive. For more information, see Filtering Reports.
