System Administration Guide: IP Services
Changing nsswitch.conf
The /etc directory contains the nsswitch.conf file that is created by the Oracle Solaris installation program. This directory also contains template files for the following name services:
If you want to change from one name service to another name service, you can copy the appropriate template to nsswitch.conf. You can also selectively edit the nsswitch.conf file, and change the default name service to search for individual databases.
For example, on a network that runs NIS, you might have to change the nsswitch.conf file on network clients. The search path for the bootparams and ethers databases must list files as the first option, and then nis. The following example shows the correct search paths.
Example 10–6 nsswitch.conf for a Client on a Network Running NIS
# /etc/nsswitch.conf:#
passwd:        files nis
group:         files nis
# consult /etc "files" only if nis is down.
hosts:         nis    [NOTFOUND=return] files
networks:      nis    [NOTFOUND=return] files
protocols:     nis    [NOTFOUND=return] files
rpc:           nis    [NOTFOUND=return] files
ethers:        files  [NOTFOUND=return] nis
netmasks:      nis    [NOTFOUND=return] files
bootparams:    files  [NOTFOUND=return] nis
publickey:     nis
netgroup:      nis
automount:     files nis
aliases:       files nis
# for efficient getservbyname() avoid nis
services:      files nis
sendmailvars:  files
For complete details on the name service switch, refer to System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
