System Administration Guide: Basic Administration
Chapter 10 Shutting Down a System (Tasks)
This chapter describes the procedures for shutting down systems.
The following is a list of the information that is in this chapter:
For overview information about system run levels, see Chapter 18, Managing Services (Overview).
For information on the procedures associated with run levels and boot files, see Shutting Down the System (Task Map).
Task
Description
For Instructions
Determine who is logged in to a system.
Use the who command to determine who is logged in to a system.
How to Determine Who Is Logged in to a System
Shut down a server.
Use the shutdown command with the appropriate options to shut down a server.
How to Shut Down a Server
Shut down a stand-alone system.
Use the init command and indicate the appropriate run-level to shut down a stand-alone system.
How to Shut Down a Stand-Alone System
Turn off power to all devices.
Powering down a system includes the following devices:
  • CPU
  • Monitor
  • External devices, such as disks, tapes, and printers
How to Turn Off Power to All Devices
Oracle Solaris is designed to run continuously, so that the electronic mail and network software can work correctly. However, some system administration tasks and emergency situations require that the system be shut down to a level where it is safe to remove power. In some cases, the system needs to be brought to an intermediate level, where not all system services are available.
Such cases include the following:
For a complete list of system administration tasks that require a system shutdown, see Chapter 9, Shutting Down and Booting a System (Overview).
For information on using your system's power management features, see the pmconfig(1M) man page.
System Shutdown Commands
The use of the init and shutdown commands are the primary ways to shut down a system. Both commands perform a clean shutdown of the system. As such, all file system changes are written to the disk, and all system services, processes, and the operating system are terminated normally.
The use of a system's Stop key sequence or turning a system off and then on are not clean shutdowns because system services are terminated abruptly. However, sometimes these actions are needed in emergency situations. For instructions on system recovery techniques, see Chapter 12, Booting an Oracle Solaris System (Tasks) andChapter 13, Managing the Oracle Solaris Boot Archives (Tasks).
Note –
On x86 systems that are running at least the Solaris 10 6/06 release, pressing and releasing the power button initiates a clean system shutdown. This method is equivalent to using the init 5 command.
The following table describes the various shutdown commands and provides recommendations for using them.
Table 10–1 Shutdown Commands
Command
Description
When To Use
shutdown
An executable shell script that calls the init program to shut down the system. The system is brought to run level S by default.
Recommended for servers operating at run level 3 because users are notified of the impending shutdown. Also notified are the systems that are mounting resources from the server that is being shut down.
init
An executable that kills all active processes and synchronizes the disks before changing run levels.
Recommended for stand-alone systems when other users will not be affected. Provides a faster system shutdown because users are not notified of the impending shutdown.
reboot
An executable that synchronizes the disks and passes boot instructions to the uadmin system call. In turn, this system call stops the processor.
The init command is the preferred method.
halt, poweroff
An executable that synchronizes the disks and stops the processor.
Not recommended because it doesn't shutdown all processes, and unmount any remaining file systems. Stopping the services, without doing a clean shutdown, should only be done in an emergency or if most of the services are already stopped.
User Notification of System Down Time
When the shutdown command is initiated, a warning followed by a final shutdown message is broadcast to all users who are currently logged in to the system and all systems that are mounting resources from the affected system.
For this reason, the shutdown command is preferred instead of the init command when you need to shut down a server. When you use either command, you might want to give users more notice by sending them a mail message about any scheduled system shutdown.
Use the who command to determine which users on the system need to be notified. This command is also useful for determining a system's current run level. For more information, see Determining a System's Run Level and the who(1) man page.
ProcedureHow to Determine Who Is Logged in to a System
  1. Log in to the system to be shut down.
  2. Display all of the users who are logged in to the system.
    $ who
Example 10–1 Determining Who Is Logged in to a System
The following example shows how to display who is logged in to the system.
$ who
holly       console      May  7 07:30
kryten      pts/0        May  7 07:35   (starlite)
lister      pts/1        May  7 07:40   (bluemidget)
ProcedureHow to Shut Down a Server
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Find out if users are logged in to the system.
    # who
    A list of all logged-in users is displayed. You might want to send mail or broadcast a message to let users know that the system is being shut down.
  3. Shut down the system.
    # shutdown -iinit-level -ggrace-period -y
    -iinit-level
    Brings the system to an init level that is different from the default of S. The choices are 0, 1, 2, 5, and 6.
    Run levels 0 and 5 are reserved states for shutting the system down. Run level 6 reboots the system. Run level 2 is available as a multi-user operating state.
    -ggrace-period
    Indicates a time (in seconds) before the system is shut down. The default is 60 seconds.
    -y
    Continues to shut down the system without intervention. Otherwise, you are prompted to continue the shutdown process after 60 seconds.
    For more information, see the shutdown(1M) man page.
  4. If you are asked for confirmation, type y.
    Do you want to continue? (y or n): y
    If you used the shutdown -y command, you will not be prompted to continue.
  5. Type the superuser password, if prompted.
    Type Ctrl-d to proceed with normal startup,
    (or give root password for system maintenance): xxxxxx
  6. After you have finished the system administration tasks, press Control-D to return to the default system run level.
  7. Use the following table to verify that the system is at the run level that you specified in the shutdown command.
    Specified Run Level
    SPARC Based System Prompt
    x86 Based System Prompt
    S (single-user level)
    0 (power-down level)
    ok or >
    Press any key to reboot
    Run level 3 (multiuser level with remote resources shared)
    hostname console login:
Example 10–2 SPARC: Bringing a Server to Run Level S
In the following example, the shutdown command is used to bring a SPARC based system to run level S (single-user level) in three minutes.
# who
root   console      Jun 14 15:49    (:0)
# shutdown -g180 -y
Shutdown started.    Mon Jun 14 15:46:16 MDT 2004
Broadcast Message from root (pts/4) on venus Mon Jun 14 15:46:16...
The system venus will be shut down in 3 minutes .
The system venus will be shut down in 30 seconds .
INIT: New run level: S
The system is coming down for administration.  Please wait.
Unmounting remote filesystems: /vol nfs done.
Shutting down Solaris Management Console server on port 898.
Print services stopped.
Jun 14 15:49:00 venus syslogd: going down on signal 15
Killing user processes: done.
Requesting System Maintenance Mode
SINGLE USER MODE
Root password for system maintenance (control-d to bypass): xxxxxx
single-user privilege assigned to /dev/console.
Entering System Maintenance Mode
Example 10–3 SPARC: Bringing a Server to Run Level 0
In the following example, the shutdown command is used to bring a SPARC based system to run level 0 in 5 minutes without requiring additional confirmation.
# who
root       console       Jun 17 12:39
userabc		 pts/4        Jun 17 12:39   (:0.0)
# shutdown -i0 -g300 -y
Shutdown started.    Thu Jun 17 12:40:25 MST 2004
Broadcast Message from root (console) on pretend Thu Jun 17 12:40:25...
The system pretend will be shut down in 5 minutes
Changing to init state 0 - please wait
INIT: New run level: 0
The system is coming down.  Please wait.
System services are now being stopped.
The system is down.
syncing file systems... done
Program terminated
Type  help  for more information
ok
If you are bringing the system to run level 0 to turn off power to all devices, see How to Turn Off Power to All Devices.
Example 10–4 SPARC: Rebooting a Server to Run Level 3
In the following example, the shutdown command is used to reboot a SPARC based system to run level 3 in two minutes. No additional confirmation is required.
# who
userabc    pts/4        Jun 14 15:46    (:0.0)
# shutdown -i6 -g120 -y
The system venus will be shut down in 2 minutes
Changing to init state 6 - please wait
INIT: New run level: 6
The system is down.
rebooting...
venus console login:
See Also
Regardless of why you shut down a system, you will probably want to return to run level 3, where all file resources are available, and users can log in. For instructions on bringing a system back to a multiuser level, see Chapter 12, Booting an Oracle Solaris System (Tasks).
ProcedureHow to Shut Down a Stand-Alone System
Use this procedure when you need to shut down a stand-alone system.
  2. Shut down the system.
    # init 5
    For more information, see the init(1M) man page.
    • Alternately, you can use the uadmin command to shut down the system.
      # uadmin 2 0
    • If you have an x86 based system that is running at least the Solaris 10 6/06 release, you can press and release the power button to initiate a clean system shutdown and turn off the system.
      This functionality is equivalent to using the init 5 command to shut down a system. For more information, see What's New in Shutting Down and Booting a System.
  3. Use the following table to verify that the system is at the run level that you specified in the init command.
    Specified Run Level
    2 (multiuser level)
    ok or >
    3 (multiuser level with NFS resources shared)
Example 10–5 Using the uadmin command to Shut Down a System
# uadmin 2 0
Program terminated
Example 10–6 Bringing a Stand-Alone System to Run Level 0
In this example, the init command is used to bring an x86 based stand-alone system to the level where it is safe to turn off power.
# init 0
The system is down.
syncing file systems... [11] [10] [3] done
Example 10–7 SPARC: Bringing a Stand-Alone System to Run Level S
In this example, the init command is used to bring a SPARC based stand-alone system to run level S (single-user level).
# init s
SINGLE USER MODE
See Also
Regardless of why you shut down the system, you will probably want to return to run level 3, where all file resources are available, and users can log in. For instructions on bringing a system back to a multiuser level, see Chapter 12, Booting an Oracle Solaris System (Tasks).
Turning Off Power to All Devices
You need to turn off power to all system devices when you do the following:
Turn off the power to system devices, including the CPU, the monitor, and external devices such as disks, tapes, and printers.
Before you turn off the power to all system devices, shut down the system cleanly, as described in the preceding sections.
ProcedureHow to Turn Off Power to All Devices
  1. Select one of the following methods to shut down the system:
  2. Turn off the power to all devices after the system is shutdown. If necessary, also unplug the power cables.
  3. After power can be restored, use the following steps to turn on the system and devices.
    1. Plug in the power cables.
    2. Turn on the monitor.
    3. Turn on disk drives, tape drives, and printers.
    4. Turn on the CPU.
      The system is brought to run level 3.
