Keep the following key points in mind when you consider copying a disk:
Do not use this procedure to copy a disk that is under the control of a volume manager.
The primary methods for copying UFS file system data from one disk or system to another disk or system is by using the ufsdump and ufsrestore commands. For more information on using these commands, see Chapter 23, Backing Up and Restoring UFS File Systems (Overview).
You can clone systems by creating a flash archive and copying it to destination systems. For more information about creating a flash archive, see Oracle Solaris 10 9/10 Installation Guide: Solaris Flash Archives (Creation and Installation).
If you are copying a disk with an EFI disk label, see Example 28–2.
If you are still considering copying a disk with the dd command keep the following cautions in mind:
Make sure that the source disk and destination disk have the same disk geometry.
Check the UFS file systems on the disk to be copied with the fsck utility.
Make sure the system is in single-user mode when copying a disk with the dd command.
Become superuser or assume an equivalent role.
(Optional) Create the /reconfigure file so that the system will recognize the destination disk to be added when it reboots, if necessary.
# touch /reconfigure |
Shut down the system.
# init 0 |
Attach the destination disk to the system.
Boot the system.
ok boot -s |
Copy the source disk to the destination disk.
# dd if=/dev/rdsk/device-name of=/dev/rdsk/device-name bs=block-size |
Represents the overlap slice of the master disk device, usually slice 2.
Represents the overlap slice of the destination disk device, usually slice 2.
Identifies the block size, such as 128 KB or 256 KB. A large block size decreases the time it takes to copy the disk.
For more information, see dd(1M).
Check the new file system.
# fsck /dev/rdsk/device-name |
Mount the destination disk's root (/) file system.
# mount /dev/dsk/device-name /mnt |
Change to the directory where the /etc/vfstab file is located.
# cd /mnt/etc |
Using a text editor, edit the destination disk's /etc/vfstab file to reference the correct device names.
For example, change all instances of c0t3d0 to c0t1d0.
Change to the destination disk's root (/) directory.
# cd / |
Unmount the destination disk's root (/) file system.
# umount /mnt |
# init 0 |
Boot from the destination disk to single-user mode.
# boot diskn -s |
The installboot command is not needed for the destination disk because the boot blocks are copied as part of the overlap slice.
Unconfigure the destination disk.
# sys-unconfig |
The system is shut down after it is unconfigured.
Boot from the destination disk again and provide its system information, such as host name, time zone, and so forth.
# boot diskn |
After the system is booted, log in as superuser to verify the system information.
hostname console login: |
This example shows how to copy the master disk (with a VTOC label) /dev/rdsk/c0t0d0s2 to the destination disk /dev/rdsk/c0t2d0s2.
# touch /reconfigure # init 0 ok boot # dd if=/dev/rdsk/c0t0d0s2 of=/dev/rdsk/c0t2d0s2 bs=128k # fsck /dev/rdsk/c0t2d0s2 # mount /dev/dsk/c0t2d0s2 /mnt # cd /mnt/etc # vi vfstab (Modify entries for the new disk) # cd / # umount /mnt # init 0 # boot disk2 -s # sys-unconfig # boot disk2 |
In previous Solaris releases, slice 2 (s2) was used to represent the entire disk. On a disk with an EFI label, you must use a slightly different procedure to clone or copy disks larger than 1 terabyte so that the UUID of cloned disks is unique. If you do not create a new label for the cloned disk, other software products might corrupt data on EFI-labeled disks if they encounter duplicate UUIDs.
For example:
Clone the disk with an EFI label. For example:
# dd if=/dev/rdsk/c0t0d0 of=/dev/rdsk/c0t2d0 bs=128k |
Pipe the prtvtoc output of the disk to be copied to the fmthard command to create a new label for the cloned disk. For example:
# prtvtoc /dev/rdsk/c0t0d0 | fmthard -s - /dev/rdsk/c0t2d0 |
For more information about EFI disk labels, see EFI Disk Label.
