System Administration Guide: Devices and File Systems
Chapter 2 Managing Removable Media (Tasks)
This chapter describes how to manage removable media from the command line in the Solaris OS.
For information on the procedures associated with managing removable media, see Managing Removable Media (Task Map). For background information on removable media, see Chapter 1, Managing Removable Media (Overview).
The following task map describes the tasks for managing removable media.
Task
Description
For Instructions
1. Load media.
Insert the diskette into the drive and type the volcheck command.
How to Load Removable Media
2. (Optional) Format the diskette.
Format diskette.
How to Format a Diskette (rmformat)
3. (Optional) Add a UFS or PCFS file system.
Add a UFS or PCFS file system to use the media for transferring files.
How to Create a File System on Removable Media
Add a UFS or UDFS file system to a DVD-RAM device.
How to Create a File System on a DVD-RAM
4. (Optional) Check the media.
Verify the integrity of the file system on the media.
How to Check a File System on Removable Media
5. (Optional) Repair bad blocks on the media.
Repair any bad blocks on the media, if necessary.
How to Repair Bad Blocks on Removable Media
6. (Optional) Apply read or write and password protection.
Apply read or write protection or password protection on the media, if necessary.
How to Enable or Disable Write Protection on Removable Media
Formatting Diskettes
You can use the rmformat command to format and protect rewritable diskettes. This utility does not require superuser privilege unless vold is not running. File systems are mounted automatically. So, you might have to unmount media before you can format it, if the media contains an existing file system.
The rmformat command has three formatting options:
Removable Media Hardware Considerations
Keep the following restrictions in mind when working with diskettes:
Diskette Hardware Considerations
Keep the following in mind when formatting diskettes:
A Solaris system can format the following diskette types:
On a Solaris system (either SPARC or x86), you can format diskettes with the following densities.
Diskette Size
Diskette Density
Capacity
3.5”
High density (HD)
1.44 MB
3.5”
Double density (DD)
720 KB
By default, the diskette drive formats a diskette to a like density. This default means that a 1.44 MB drive attempts to format a diskette for 1.44 MB, regardless of whether the diskette is, in fact, a 1.44 MB diskette, unless you instruct it otherwise. In other words, a diskette can be formatted to its capacity or lower, and a drive can format to its capacity or lower.
ProcedureHow to Load Removable Media
For information about removable media hardware considerations, see Removable Media Hardware Considerations.
  1. Insert the media.
  2. Ensure that the media is formatted.
    If you aren't sure, insert the media and check the status messages in the system console window, as described in Step 3. If you need to format the media, go to How to Format a Diskette (rmformat).
  3. (Optional) Notify volume management if you are using a legacy, non-USB diskette device.
    $ volcheck -v
    Two status messages are possible:
    media was found
    Volume management detected the media and will attempt to mount it in the directory described in Table 3–1.
    If the media is formatted properly, no error messages appear in the console.
    If the media is not formatted, the “media was found” message is still displayed. However, error messages similar to the following appear in the system console window:
    fd0: unformatted diskette or no diskette in the drive
    fd0: read failed (40 1 0)
    fd0: bad format
    You must format the media before volume management can mount it. For more information, see Chapter 2, Managing Removable Media (Tasks).
    no media was found
    Volume management did not detect the media. Ensure that the media is inserted properly, and run volcheck again. If unsuccessful, check the media, which could be damaged. You can also try to mount the media manually.
  4. Verify that the media was mounted by listing its contents.
    For example, do the following for a diskette:
    $ ls /floppy
    floppy0 myfiles
    Tip –
    floppy0 is a symbolic link to the actual name of the diskette. In this case, myfiles. If the diskette has no name but is formatted correctly, the system refers to it as unnamed_floppy.
    If nothing appears under the /floppy directory, the diskette was either not mounted or is not formatted properly. To find out, run the mount command and look for the line that begins with /floppy (usually at the end of the listing):
    /floppy/name on /vol/dev/diskette0/name
    If this line does not appear, the diskette was not mounted. Check the system console window for error messages.
ProcedureHow to Format a Diskette (rmformat)
You can use the rmformat command to format a diskette. By default, this command creates two partitions on the media: partition 0 and partition 2 (the whole media).
  1. Verify that removable media service is running. If so, you can use the shorter nickname for the device name.
    $ svcs volfs
    STATE          STIME    FMRI
    online         10:39:12 svc:/system/filesystem/volfs:default
    For information on restarting removable media services, see How to Disable or Enable Removable Media Services. For information on identifying media device names, see Using Removable Media Names.
  2. Format the diskette.
    $ rmformat -F [ quick | long | force ] device-name
    See Formatting Diskettes for more information on rmformat formatting options.
    If the rmformat output indicates bad blocks, see How to Repair Bad Blocks on Removable Media.
  3. (Optional) Label the diskette with an 8-character label.
    $ rmformat -b label device-name
    For information on creating a DOS label, see mkfs_pcfs(1M).
Example 2–1 Formatting a Diskette
This example shows how to format a diskette.
$ rmformat -F quick /dev/rdiskette
Formatting will erase all the data on disk.
Do you want to continue? (y/n) y
ProcedureHow to Create a File System on Removable Media
  1. (Optional) Format the diskette.
    $ rmformat -F quick device-name
  2. (Optional) Create an alternate Solaris partition table.
    $ rmformat -s slice-file device-name
    A sample slice file appears similar to the following:
    slices: 0 = 0, 30MB, "wm", "home" :
                  1 = 30MB, 51MB :
                  2 = 0, 94MB, "wm", "backup" :
                  6 = 81MB, 13MB
  3. Become superuser.
  4. Determine the appropriate file system type and select one of the following:
    • Create a UFS file system. For example:
      # newfs /vol/dev/aliases/floppy0
    • Create a PCFS file system. For example:
      # mkfs -F pcfs /dev/rdsk/c0t4d0s2:c
    • Create a UDFS file system. For example:
      # mkfs -F udfs /dev/rdsk/c0t1d0s1
Example 2–2 Formatting a Diskette for a UFS File System
The following example shows how to format a diskette and create a UFS file system on the diskette.
$ rmformat -F quick /vol/dev/aliases/floppy0
$ su
# /usr/sbin/newfs /vol/dev/aliases/floppy0
newfs: construct a new file system /dev/rdiskette: (y/n)? y
/dev/rdiskette: 2880 sectors in 80 cylinders of 2 tracks, 18 sectors
        1.4MB in 5 cyl groups (16 c/g, 0.28MB/g, 128 i/g)
super-block backups (for fsck -F ufs -o b=#) at:
 32, 640, 1184, 1792, 2336,
Do you want to continue? (y/n)y
$ su
# /usr/sbin/newfs /dev/rdiskette
Example 2–3 Formatting a Diskette for a PCFS File System
This example shows how to create a PCFS file system with an alternate fdisk partition. In these examples, vold is not running.
$ rmformat -F quick /dev/rdsk/c0t4d0s2:c
$ su
# fdisk /dev/rdsk/c0t4d0s2:c
Construct a new FAT file system on /dev/rdsk/c0t4d0s2:c: (y/n)? y
This example shows how to create a PCFS file system without an fdisk partition.
$ su
# mkfs -F pcfs -o nofdisk,size=2 /dev/rdiskette
Construct a new FAT file system on /dev/rdiskette: (y/n)? y
ProcedureHow to Create a File System on a DVD-RAM
Currently, vold doesn't support DVD-RAM devices. So, if you disable vold to use a DVD-RAM device, you cannot use CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW devices because vold is not available during the time that it is disabled.
  1. Become superuser.
  2. Stop vold.
    # svcadm disable volfs
  3. Create a file system on the DVD-RAM device.
      # newfs /dev/rdsk/c0t0d0s2
      # mkfs -F udfs /dev/rdsk/c0t0d0s2
  4. Mount the file system.
    • Mount a UFS file system. For example:
      # mount -F ufs /dev/dsk/c0t0d0s2 /mnt
    • Mount a UDFS file system. For example:
      # mount -F udfs /dev/dsk/c0t0d0s2 /mnt
  5. Verify that you can read or write to the file system.
  6. When finished, eject the DVD-RAM.
  7. Restart vold.
    # svcadm enable volfs
ProcedureHow to Check a File System on Removable Media
  2. Identify the file system type and select one of the following:
    • Check a UFS file system.
      # fsck -F ufs device-name
    • Check a UDFS file system.
      # fsck -F udfs device-name
    • Check a PCFS file system.
      # fsck -F pcfs device-name
Example 2–4 Checking a PCFS File System on Removable Media
The following example shows how check the consistency of a PCFS file system on media. In this example, vold is not running.
# fsck -F pcfs /dev/rdsk/c0t4d0s2
** /dev/rdsk/c0t4d0s2
** Scanning file system meta-data
** Correcting any meta-data discrepancies
1457664 bytes.
0 bytes in bad sectors.
0 bytes in 0 directories.
0 bytes in 0 files.
1457664 bytes free.
512 bytes per allocation unit.
2847 total allocation units.
2847 available allocation units.
ProcedureHow to Repair Bad Blocks on Removable Media
You can only use the rmformat command to verify, analyze, and repair bad sectors that are found during verification if the drive supports bad block management. Most diskettes and USB memory sticks do not support bad block management.
If the drive supports bad block management, a best effort is made to rectify the bad block. If the bad block cannot be rectified despite the best effort mechanism, a message indicates the failure to repair the media.
  1. Repair bad blocks on removable media.
    $ rmformat -c block-numbers device-name
    Supply the block number in decimal, octal, or hexadecimal format from a previous rmformat session.
  2. Verify the media.
    $ rmformat -V read device-name
Applying Read or Write Protection and Password Protection to Removable Media
You can apply read protection or write protection, and set a password, on removable media that support this feature.
ProcedureHow to Enable or Disable Write Protection on Removable Media
  1. Determine whether you want to enable or disable write protection and select one of the following:
    • Enable write protection.
      $ rmformat -w enable device-name
    • Disable write protection.
      $ rmformat -w disable device-name
  2. Verify whether the media's write protection is enabled or disabled.
    $ rmformat -p device-name
ProcedureHow to Enable or Disable Read or Write Protection and Set a Password on Removable Media
You can apply a password with a maximum of 32 characters for removable media that support this feature.
You will receive a warning message if you attempt to apply a password on media that does not support this feature.
  1. Determine whether you want to enable or disable read protection or write protection and set a password. Select one of the following:
    • Enable read protection or write protection.
      $ rmformat -W enable device-name
      Please enter password (32 chars maximum): xxx
      Please reenter password:
      $ rmformat -R enable device-name
    • Disable read protection or write protection and remove the password.
      $ rmformat -W disable device-name
      $ rmformat -R disable device-name
  2. Verify whether the media's read protection or write protection is enabled or disabled.
Example 2–5 Enabling or Disabling Read or Write Protection and Password Protection
This example shows how to enable write protection and set a password on a diskette.
$ rmformat -W enable /vol/dev/aliases/floppy0
Please reenter password: xxx
This example shows to disable read protection and remove the password on a diskette.
$ rmformat -R disable /vol/dev/aliases/floppy0
