Java Desktop System Release 3 Installation Guide
Boot Disk Locations
The boot disks are available from the following locations:
The boot disk subfolders are named as follows:
Use the following command to make other disks, if required:
dd if=/export/suseimage/boot/bootdisk of=/dev/fd0
Note –
You may need additional disks depending on your hardware, for example, SCSI controllers and USB drives.
