Java Desktop System Email and Calendar User Guide
Task Functions
Table C–7 lists the keyboard shortcuts that you can use to perform task functions when you use a tasks folder, or the task pane.
Table C–7 Keys for Task Functions
Ctrl + Tab
Move focus between the following interface items:
  • The Click to add a task text.
  • The table of tasks.
up arrow, down arrow
Navigate the table of tasks.
left arrow, right arrow
Navigate the columns in a task, that is, navigate between the task assignment column, the task status column, and the task summary column.
Select or deselect the task status column for the selected task.
Ctrl + O
Open the selected task in the Task window.
Shift + F10
Open the popup menu.
