Java Desktop System Email and Calendar User Guide
Weather Preferences
Use the Weather tabbed section to specify the locations whose weather you want to view in the Summary. Table 12–17 lists the weather preferences that you can configure for the Summary.
Table 12–17 Summary Weather Preferences
Dialog Element
Description
All location tree
Use the location tree to select the locations whose weather you want to display in your summary. Click on the plus sign (+) beside a location to expand the contents of the location. To collapse the contents of a location, click on the minus sign (-) beside the folder.
Add
To add a location to your summary, select the location in the All location tree, then click on the Add button. The location is added to the Shown location list.
Remove
To remove a location from your summary, select the location in the Shown location list, then click on the Remove button.
Shown location list
Displays a list of the locations whose weather is displayed in your summary.
Show temperatures in
Select whether to display temperatures in degrees Celsius or degrees Fahrenheit.
Refresh time (seconds)
Use the spin box to specify how often you want to refresh the display of weather information in your summary.
