Skip Navigation Links | |
Exit Print View | |
Oracle Directory Server Enterprise Edition Man Page Reference 11g Release 1 (11.1.1.5.0) |
Directory Server Configuration
Directory Proxy Server Configuration
aci-manager-bind-pwd-file(5dpconf)
allow-bind-operations(5dpconf)
allow-cert-based-auth(5dpconf)
allow-compare-operations(5dpconf)
allow-delete-operations(5dpconf)
allowed-comparable-attrs(5dpconf)
allowed-ldap-controls(5dpconf)
allowed-search-scopes(5dpconf)
allow-extended-operations(5dpconf)
allow-heuristic-search(5dpconf)
allow-inequality-search-operations(5dpconf)
allow-modify-operations(5dpconf)
allow-persistent-searches(5dpconf)
allow-rename-operations(5dpconf)
allow-sasl-external-authentication(5dpconf)
allow-search-operations(5dpconf)
allow-unauthenticated-operations(5dpconf)
allow-unauthenticated-operations-mode(5dpconf)
alternate-search-base-dn(5dpconf)
cert-data-view-routing-custom-list(5dpconf)
cert-data-view-routing-policy(5dpconf)
cert-search-attr-mappings(5dpconf)
cert-search-bind-pwd-file(5dpconf)
cert-search-user-attr(5dpconf)
client-affinity-bind-dn-filters(5dpconf)
client-affinity-criteria(5dpconf)
client-affinity-ip-address-filters(5dpconf)
client-affinity-policy(5dpconf)
client-affinity-timeout(5dpconf)
close-client-connection(5dpconf)
configuration-manager-bind-dn(5dpconf)
configuration-manager-bind-pwd(5dpconf)
configuration-manager-bind-pwd-file(5dpconf)
connection-idle-timeout(5dpconf)
connection-pool-wait-interval(5dpconf)
connection-pool-wait-timeout(5dpconf)
connection-read-data-timeout(5dpconf)
connection-write-data-timeout(5dpconf)
contains-shared-entries(5dpconf)
coordinated-data-view(5dpconf)
custom-distribution-algorithm(5dpconf)
data-source-read-timeout(5dpconf)
data-view-automatic-routing-mode(5dpconf)
data-view-use-internal-client-identity(5dpconf)
denied-presence-filter-attr(5dpconf)
denied-presence-filter-enabled(5dpconf)
dn-mapping-source-base-dn(5dpconf)
down-monitoring-interval(5dpconf)
email-alerts-message-from-address(5dpconf)
email-alerts-message-subject(5dpconf)
email-alerts-message-subject-includes-alert-code(5dpconf)
email-alerts-message-to-address(5dpconf)
email-alerts-smtp-host(5dpconf)
email-alerts-smtp-port(5dpconf)
enable-client-affinity(5dpconf)
enable-data-view-affinity(5dpconf)
enabled-ssl-cipher-suites(5dpconf)
enabled-ssl-protocols(5dpconf)
enable-remote-user-mapping(5dpconf)
encrypt-configuration(5dpconf)
extension-jar-file-url(5dpconf)
group-search-bind-pwd(5dpconf)
group-search-bind-pwd-file(5dpconf)
jdbc-attr-date-format(5dpconf)
jdbc-attr-time-format(5dpconf)
jdbc-attr-timestamp-format(5dpconf)
jdbc-data-source-pool(5dpconf)
join-rule-control-enabled(5dpconf)
ldap-data-source-pool(5dpconf)
lexicographic-lower-bound(5dpconf)
lexicographic-upper-bound(5dpconf)
load-balancing-algorithm(5dpconf)
log-etimes-in-seconds(5dpconf)
log-level-client-connections(5dpconf)
log-level-client-disconnections(5dpconf)
log-level-client-operations(5dpconf)
log-level-configuration(5dpconf)
log-level-connection-handlers(5dpconf)
log-level-data-source(5dpconf)
log-level-data-sources(5dpconf)
log-level-data-sources-detailed(5dpconf)
log-level-operation-decode(5dpconf)
log-level-operation-processing(5dpconf)
log-rotation-frequency(5dpconf)
log-rotation-start-day(5dpconf)
log-rotation-start-time(5dpconf)
max-client-connections(5dpconf)
max-ldap-message-size(5dpconf)
max-op-count-per-interval(5dpconf)
max-simultaneous-operations-per-connection(5dpconf)
max-total-operations-per-connection(5dpconf)
min-free-disk-space-size(5dpconf)
minimum-search-filter-substring-length(5dpconf)
monitoring-bind-pwd-file(5dpconf)
monitoring-bind-timeout(5dpconf)
monitoring-entry-timeout(5dpconf)
monitoring-inactivity-timeout(5dpconf)
monitoring-retry-count(5dpconf)
monitoring-search-filter(5dpconf)
monitoring-search-scope(5dpconf)
number-of-psearch-threads(5dpconf)
number-of-search-threads(5dpconf)
number-of-worker-threads(5dpconf)
numeric-default-data-view(5dpconf)
one-level-search-base-dn(5dpconf)
op-count-per-interval-timeout(5dpconf)
pattern-matching-base-dn-regular-expression(5dpconf)
pattern-matching-base-object-search-filter(5dpconf)
pattern-matching-dn-regular-expression(5dpconf)
pattern-matching-one-level-search-filter(5dpconf)
pattern-matching-subtree-search-filter(5dpconf)
perform-distinct-select(5dpconf)
prohibited-comparable-attrs(5dpconf)
proxied-auth-check-timeout(5dpconf)
remote-user-mapping-bind-dn-attr(5dpconf)
request-filtering-policy(5dpconf)
request-grouping-size(5dpconf)
require-data-view-availability(5dpconf)
resource-limits-policy(5dpconf)
revert-add-on-failure(5dpconf)
scriptable-alerts-command(5dpconf)
scriptable-alerts-enabled(5dpconf)
ssl-client-cert-alias(5dpconf)
ssl-server-cert-alias(5dpconf)
subtree-search-base-dn(5dpconf)
supported-ssl-cipher-suites(5dpconf)
supported-ssl-protocols(5dpconf)
syslog-alerts-enabled(5dpconf)
syslog-alerts-facility(5dpconf)
target-attr-value-assertions(5dpconf)
target-dn-regular-expressions(5dpconf)
use-cert-subject-as-bind-dn(5dpconf)
use-read-connections-for-writes(5dpconf)
user-mapping-anonymous-bind-dn(5dpconf)
user-mapping-anonymous-bind-pwd(5dpconf)
user-mapping-anonymous-bind-pwd-file(5dpconf)
user-mapping-default-bind-dn(5dpconf)
user-mapping-default-bind-pwd(5dpconf)
user-mapping-default-bind-pwd-file(5dpconf)
vlv-control-page-size(5dpconf)
vlv-control-sorting-attr(5dpconf)
- Directory Proxy Server configuration property
This property specifies the maximum size of the listener's new connection queue. When the queue is full, new connections are rejected.
This property takes an integer.
The value of this property must be at least 1.
This property is used to configure the following features:
The LDAP listener represents the network interface of Directory Proxy Server.
dpconf(1M)
