Skip Navigation Links | |
Exit Print View | |
Oracle Directory Server Enterprise Edition Man Page Reference 11g Release 1 (11.1.1.5.0) |
Directory Server Configuration
Directory Proxy Server Configuration
aci-manager-bind-pwd-file(5dpconf)
allow-bind-operations(5dpconf)
allow-cert-based-auth(5dpconf)
allow-compare-operations(5dpconf)
allow-delete-operations(5dpconf)
allowed-comparable-attrs(5dpconf)
allowed-ldap-controls(5dpconf)
allowed-search-scopes(5dpconf)
allow-extended-operations(5dpconf)
allow-heuristic-search(5dpconf)
allow-inequality-search-operations(5dpconf)
allow-modify-operations(5dpconf)
allow-persistent-searches(5dpconf)
allow-rename-operations(5dpconf)
allow-sasl-external-authentication(5dpconf)
allow-search-operations(5dpconf)
allow-unauthenticated-operations(5dpconf)
allow-unauthenticated-operations-mode(5dpconf)
alternate-search-base-dn(5dpconf)
cert-data-view-routing-custom-list(5dpconf)
cert-data-view-routing-policy(5dpconf)
cert-search-attr-mappings(5dpconf)
cert-search-bind-pwd-file(5dpconf)
cert-search-user-attr(5dpconf)
client-affinity-bind-dn-filters(5dpconf)
client-affinity-criteria(5dpconf)
client-affinity-ip-address-filters(5dpconf)
client-affinity-policy(5dpconf)
client-affinity-timeout(5dpconf)
close-client-connection(5dpconf)
configuration-manager-bind-dn(5dpconf)
configuration-manager-bind-pwd(5dpconf)
configuration-manager-bind-pwd-file(5dpconf)
connection-idle-timeout(5dpconf)
connection-pool-wait-interval(5dpconf)
connection-pool-wait-timeout(5dpconf)
connection-read-data-timeout(5dpconf)
connection-write-data-timeout(5dpconf)
contains-shared-entries(5dpconf)
coordinated-data-view(5dpconf)
custom-distribution-algorithm(5dpconf)
data-source-read-timeout(5dpconf)
data-view-automatic-routing-mode(5dpconf)
data-view-use-internal-client-identity(5dpconf)
denied-presence-filter-attr(5dpconf)
denied-presence-filter-enabled(5dpconf)
dn-mapping-source-base-dn(5dpconf)
down-monitoring-interval(5dpconf)
email-alerts-message-from-address(5dpconf)
email-alerts-message-subject(5dpconf)
email-alerts-message-subject-includes-alert-code(5dpconf)
email-alerts-message-to-address(5dpconf)
email-alerts-smtp-host(5dpconf)
email-alerts-smtp-port(5dpconf)
enable-client-affinity(5dpconf)
enable-data-view-affinity(5dpconf)
enabled-ssl-cipher-suites(5dpconf)
enabled-ssl-protocols(5dpconf)
enable-remote-user-mapping(5dpconf)
encrypt-configuration(5dpconf)
extension-jar-file-url(5dpconf)
group-search-bind-pwd(5dpconf)
group-search-bind-pwd-file(5dpconf)
jdbc-attr-date-format(5dpconf)
jdbc-attr-time-format(5dpconf)
jdbc-attr-timestamp-format(5dpconf)
jdbc-data-source-pool(5dpconf)
join-rule-control-enabled(5dpconf)
ldap-data-source-pool(5dpconf)
lexicographic-lower-bound(5dpconf)
lexicographic-upper-bound(5dpconf)
load-balancing-algorithm(5dpconf)
log-etimes-in-seconds(5dpconf)
log-level-client-connections(5dpconf)
log-level-client-disconnections(5dpconf)
log-level-client-operations(5dpconf)
log-level-configuration(5dpconf)
log-level-connection-handlers(5dpconf)
log-level-data-source(5dpconf)
log-level-data-sources(5dpconf)
log-level-data-sources-detailed(5dpconf)
log-level-operation-decode(5dpconf)
log-level-operation-processing(5dpconf)
log-rotation-frequency(5dpconf)
log-rotation-start-day(5dpconf)
log-rotation-start-time(5dpconf)
max-client-connections(5dpconf)
max-connection-queue-size(5dpconf)
max-ldap-message-size(5dpconf)
max-simultaneous-operations-per-connection(5dpconf)
max-total-operations-per-connection(5dpconf)
min-free-disk-space-size(5dpconf)
minimum-search-filter-substring-length(5dpconf)
monitoring-bind-pwd-file(5dpconf)
monitoring-bind-timeout(5dpconf)
monitoring-entry-timeout(5dpconf)
monitoring-inactivity-timeout(5dpconf)
monitoring-retry-count(5dpconf)
monitoring-search-filter(5dpconf)
monitoring-search-scope(5dpconf)
number-of-psearch-threads(5dpconf)
number-of-search-threads(5dpconf)
number-of-worker-threads(5dpconf)
numeric-default-data-view(5dpconf)
one-level-search-base-dn(5dpconf)
op-count-per-interval-timeout(5dpconf)
pattern-matching-base-dn-regular-expression(5dpconf)
pattern-matching-base-object-search-filter(5dpconf)
pattern-matching-dn-regular-expression(5dpconf)
pattern-matching-one-level-search-filter(5dpconf)
pattern-matching-subtree-search-filter(5dpconf)
perform-distinct-select(5dpconf)
prohibited-comparable-attrs(5dpconf)
proxied-auth-check-timeout(5dpconf)
remote-user-mapping-bind-dn-attr(5dpconf)
request-filtering-policy(5dpconf)
request-grouping-size(5dpconf)
require-data-view-availability(5dpconf)
resource-limits-policy(5dpconf)
revert-add-on-failure(5dpconf)
scriptable-alerts-command(5dpconf)
scriptable-alerts-enabled(5dpconf)
ssl-client-cert-alias(5dpconf)
ssl-server-cert-alias(5dpconf)
subtree-search-base-dn(5dpconf)
supported-ssl-cipher-suites(5dpconf)
supported-ssl-protocols(5dpconf)
syslog-alerts-enabled(5dpconf)
syslog-alerts-facility(5dpconf)
target-attr-value-assertions(5dpconf)
target-dn-regular-expressions(5dpconf)
use-cert-subject-as-bind-dn(5dpconf)
use-read-connections-for-writes(5dpconf)
user-mapping-anonymous-bind-dn(5dpconf)
user-mapping-anonymous-bind-pwd(5dpconf)
user-mapping-anonymous-bind-pwd-file(5dpconf)
user-mapping-default-bind-dn(5dpconf)
user-mapping-default-bind-pwd(5dpconf)
user-mapping-default-bind-pwd-file(5dpconf)
vlv-control-page-size(5dpconf)
vlv-control-sorting-attr(5dpconf)
- Directory Proxy Server configuration property
This property specifies the maximun number of operations, allowed by the connection handler, per interval of time. The interval of time is defined by the property: op-count-per-interval-timeout(5dpconf).
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: Feature is disabled
This property is used to configure the following features:
Resource limit policies define the maximum resources that Directory Proxy Server can process for a given connection handler.
dpconf(1M)
