Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for Oracle VM Software
search filter icon
search icon
Document Information
Using This Documentation
Part I  Oracle VM Software Installation
1.  Getting Started
Supported Virtual Machine Software
Oracle VM Software Installation Prerequisites
Oracle VM Software Installation Task Overview
2.  Installing Oracle VM
Installing Oracle VM Using Local or Remote Media
Oracle VM Post Installation Tasks
3.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Part II  Oracle VM System Administrator References
A.  Supported Installation Methods
Console Outputs
Installation Boot Media
Installation Targets
B.  Supported Operating Systems
C.  BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
Index
To install the virtual machine software, complete the following procedures in order:
  1. Gather the media for installing the Oracle VM software.
    Note - You can use the Oracle VM software ISO image for remote installation or for creating an installation CD or DVD.
  2. Choose and set up an installation method for deploying the installation of the Oracle VM software as described in Appendix A, Supported Installation Methods.
  3. Follow the instructions for installing the Oracle VM software as described in Installing Oracle VM Using Local or Remote Media.
  4. Review and perform the applicable post installation tasks as described in Oracle VM Post Installation Tasks.
