Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Oracle VM Software |
Part I Oracle VM Software Installation
Supported Virtual Machine Software
Oracle VM Software Installation Prerequisites
Oracle VM Software Installation Task Overview
Installing Oracle VM Using Local or Remote Media
Oracle VM Post Installation Tasks
3. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Oracle VM System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
In the BIOS Setup Utility, you can set optimal defaults, as well as view and edit BIOS settings as needed. Any changes you make in the BIOS Setup Utility (by pressing F2) are permanent until the next time you change them.
In addition to using the F2 key to view or edit the system's BIOS settings, you can use F8 during the BIOS start-up to specify a temporary boot device. If you use F8 to set a temporary boot device, this change is only in effect for the current system boot. The permanent boot device specified through F2 will be in effect after booting from the temporary boot device.
Ensure that the following requirements are met prior to accessing the BIOS Setup Utility.
The server is equipped with a hard disk drive (HDD) or solid state drive (SSD).
The HDD or SSD is properly installed in the server. For details, see the Sun Server X2-4 Service Manual.
A console connection is established to the server. For details, see Table A-1.
