Skip Navigation Links | |
Exit Print View | |
Oracle Java CAPS Master Index Configuration Reference Java CAPS Documentation |
About Oracle Java CAPS Master Index
Features of Oracle Java CAPS Master Index
Configuration Overview for Oracle Java CAPS Master Index
About the Configuration Files for Oracle Java CAPS Master Index
Master Index validation.xml File
Master Index security.xml File
Match and Standardization Engine Configuration Files
Using the Editors for Oracle Java CAPS Master Index
Master Index Configuration Editor
Master Index Object Definition Configuration
Master Index Object Definition Components
Master Index Object Definition Objects
Master Index Object Definition Fields
Master Index Object Definition Relationships
The Master Index object.xml File
Modifying the Master Index Object Definition
Basic Queries in a Master Index
Blocking Queries in a Master Index
Blocking Query Block Processing
Phonetic Queries in a Master Index
Blocking Query Range Searching
Blocking Query Offset and Constant Combinations
Master Controller Configuration
Custom Logic Classes in master.xml
Merged Record Updates in master.xml
Match and Standardization Engines
Block Picker and Pass Controller
Sample Standardization and Matching Sequence
Survivor Strategy Configuration
The Survivor Calculator and the SBR
Survivor Helper Default Strategy
Survivor Helper Weighted Strategy
Survivor Helper Union Strategy
Weighted Calculator SourceSystem Strategy
Weighted Calculator SystemAgreement Strategy
Weighted Calculator MostRecentModified Strategy
Update Manager Update Policies
Update Manager Update Policy Flag
SBR, Matching, and Blocking Filter Configuration
The Master Index Data Manager (MIDM) is the web-based user interface for the master index application that allows you to monitor and modify data in the index. This interface is highly configurable, and can be customized by modifying midm.xml in the master index project.
The following topics describe the MIDM and the midm.xml structure, and provide a sample of the file structure.
The MIDM is a web-based interface that allows you to manage and monitor the data in your master index database. Using the MIDM, you can search for records; add, update, deactivate, and reactivate records; review and resolve potential duplicate records; compare records; and merge and unmerge records. You can also view a transaction history for each record, view an audit log of access to the database, and run reports on the state of the data and the transactions that have been performed. This interface is configurable, allowing you to customize certain processing properties as well as the appearance of the windows.
The MIDM facilitates the use of screen readers and other assistive technology by providing information through HTML tags. It also provides tooltips when the cursor is placed over links and images on the MIDM pages.
You can configure several properties of the MIDM to display the information you want in the way you want, to define the way searches can be processed, and to define the criteria that can be used for each search. Certain implementation options are also configured in midm.xml, such as application server information, debug options, and security information.
The configurable properties of the user interface fall into these categories:
In midm.xml, you specify which objects appear on the MIDM windows and the order in which they appear. You can also specify the fields displayed in each object and configure properties for each field. This file controls the configuration of a field’s name, length, order of appearance on the MIDM, required data type, whether text can be entered into a field or if it must be selected from a predefined value, whether a field or combination of fields must be unique to a parent or child object, and whether the value of the field is hidden under certain circumstances. You can also specify whether the format of a field is dependent on the value of a related field (for example, the format of a credit card number field could be dependent on the type of credit card specified).
In midm.xml, relationships define the hierarchy of the object types listed on the MIDM. By specifying relationships, you define parent and child nodes. The parent and child nodes you specify in the relationships element must also be defined in the node elements of the file. You can specify one parent object; the remaining objects must be child objects to the parent you define. The relationships section is dependent on the relationships section in object.xml, and should only be changed if corresponding changes are made to object.xml.
You can configure these display options for the MIDM: the appearance of pages, audit log availability, local ID field labels, and the configuration of the search pages.
You can configure several display properties for the pages that appear on the MIDM. For example, you can specify whether certain system fields are visible, the type of object to display on a page, and the name of the tabbed headings. You can also rearrange the order of pages or sub-pages.
In the display configuration, you can specify whether an audit log is maintained of all instances in which object information was accessed from the MIDM. If the log is maintained, then information about each instance of access can be viewed on the MIDM. This is especially useful in healthcare implementations, where privacy of information is mandated.
A local ID is a unique identification code assigned to a record by the system in which the record originated. By default, the fields that display the local IDs are named “Local ID” on the MIDM pages. This name can be modified to a name more recognizable by MIDM users.
Of the configurable pages, the pages that might require the most configuration are the search pages. In addition to defining the number of records to display in the search results list, you can also specify the search criteria that appear and the types of searches allowed from the MIDM.
You can define and name several search pages for each primary MIDM window, each with their own configuration. For each search page, you specify groups of fields that are displayed in boxed areas. Each boxed area can represent a different type of search, such as a demographic search, address search, EUID search, and so on. For the Records Details page searches, you must also specify the search types available for each search you define, such as alphanumeric or phonetic. You can configure searches by specifying a name for the search, the maximum number of records to return, whether the results are weighted, and whether wildcard characters can be used.
When you define the search types for the Records Details page of the MIDM, you must specify a query for each type you define. The queries you specify must already be defined in query.xml.
The midm.xml file defines certain information about the application server for the master index implementation, such as the names of certain validation and management components, and debug parameters. Most of the implementation information is predefined.
MIDM properties are defined in midm.xml. Some of the information entered into the default configuration file is based on the fields you defined in the wizard, and some is standard across all implementations. For most implementations, this file will require customization.
The following topics provide information about working with midm.xml:
You can modify midm.xml at any time, but you must regenerate the application and redeploy the project after making any changes to the file. Changes made to this file do not affect match processing. The possible modifications to this file are restricted by the schema definition, so be sure to validate the file after making any changes. Certain properties of this file can be modified using the Configuration Editor, such as whether a field appears on a search page and is required for that search. Most MIDM properties need to be modified directly in this file.
The following table lists each element in midm.xml and provides a description of each element along with any requirements or constraints. Note that not all elements can be used on all predefined pages.
Table 14 midm.xml File Structure
Note - The subscreen element is used by default to define standard reports that can be run from the MIDM. In these subscreen definitions, the report-name element indicates the type of report being generated.
You can specify any of the following production reports:
Assumed Matches
Potential Duplicate
Deactivated
Merged
Unmerged
Update
Or you can specify any of the following activity reports.
Weekly Transaction Summary Report
Monthly Transaction Summary Report
Yearly Transaction Summary Report
Below is a short excerpt from midm.xml based on a master index application processing person information. This sample defines two pages on the MIDM. The first page defines one blocking search, one simple lookup search, and one search result list. The second page is the reports page, and it defines a Potential Duplicate Report and a Weekly Activity report.
<node> <name>Person</name> <field> <name>LastName</name> <display-name>Last Name</display-name> <display-order>1</display-order> <max-length>40</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <key-type>true</key-type> </field> <field> <name>FirstName</name> <display-name>First Name</display-name> <display-order>2</display-order> <max-length>40</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <key-type>true</key-type> </field> <field> <name>DOB</name> <display-name>DOB</display-name> <display-order>3</display-order> <max-length>32</max-length> <gui-type>TextBox</gui-type> <value-type>date</value-type> <key-type>true</key-type> </field> <field> <name>Gender</name> <display-name>Gender</display-name> <display-order>4</display-order> <max-length>8</max-length> <gui-type>MenuList</gui-type> <value-list>GENDER</value-list> <value-type>string</value-type> <key-type>true</key-type> </field> <field> <name>SSN</name> <display-name>SSN</display-name> <display-order>5</display-order> <max-length>16</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <input-mask>DDD-DD-DDDD</input-mask> <value-mask>DDDxDDxDDDD</value-mask> <is-sensitive>true</is-sensitive> <field> </node> <node> <name>Alias</name> <display-order>1</display-order> <field> <name>LastName</name> <display-name>LastName</display-name> <display-order>1</display-order> <max-length>40</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <key-type>true</key-type> </field> <field> <name>FirstName</name> <display-name>FirstName</display-name> <display-order>2</display-order> <max-length>40</max-length> <gui-type>TextBox</gui-type> <value-type>string</value-type> <key-type>true</key-type> </field> </node> <relationships> <name>Person</name> <children>Alias</children> </relationships> <impl-details> <master-controller-jndi-name>ejb/PersonMasterController </master-controller-jndi-name> <validation-service-jndi-name>ejb/PersonCodeLookup </validation-service-jndi-name> <usercode-jndi-name>ejb/PersonUserCodeLookup</usercode-jndi-name> <reportgenerator-jndi-name>ejb/PersonReportGenerator </reportgenerator-jndi-name> <debug-flag>true</debug-flag> <debug-dest>console</debug-dest> <enable-security>true</enable-security> <object-sensitive-plug-in-class>com.sun.mdm.index.security.VIPPlugIn </object-sensitive-plug-in-class> </impl-details> <gui-definition> <page-definition> <local-id/> <initial-screen-id>1</initial-screen-id> <record-details> <root-object>Person</root-object> <tab-name>Record Details</tab-name> <screen-id>1</screen-id> <display-order>2</display-order> <search-pages> <simple-search-page> <screen-title>Advanced Person Lookup (Phonetic)</screen-title> <search-result-id>1</search-result-id> <search-screen-order>1</search-screen-order> <show-euid>false</show-euid> <show-lid>false</show-lid> <instruction/> <field-group> <description>Person</description> <field-ref required="false">Person.FirstName</field-ref> <field-ref required="false">Person.LastName</field-ref> <field-ref required="false">Person.SSN</field-ref> </field-group> <field-group> <description>Alias</description> <field-ref required="false">Person.Alias.FirstName</field-ref> <field-ref required="false">Person.Alias.LastName</field-ref> </field-group> <search-option> <display-name>Phonetic Search</display-name> <query-builder>BLOCKER-SEARCH</query-builder> <weighted>true</weighted> <parameter> <name>UseWildcard</name> <value>false</value> </parameter> </search-option> </simple-search-page> <simple-search-page> <screen-title>Simple Person Lookup</screen-title> <search-result-id>1</search-result-id> <search-screen-order>2</search-screen-order> <show-euid>true</show-euid> <show-lid>true</show-lid> <instruction/> <field-group/> <search-option> <display-name>Alpha Search</display-name> <query-builder>ALPHA-SEARCH</query-builder> <weighted>false</weighted> <parameter> <name>UseWildcard</name> <value>true</value> </parameter> </search-option> </simple-search-page> </search-pages> <search-result-pages> <search-result-list-page> <search-result-id>1</search-result-id> <item-per-page>10</item-per-page> <max-result-size>100</max-result-size> <field-group> <description/> <field-ref>Person.FirstName</field-ref> <field-ref>Person.MiddleName</field-ref> <field-ref>Person.LastName</field-ref> <field-ref>Person.SSN</field-ref> <field-ref>Person.DOB</field-ref> <field-ref>Person.Gender</field-ref> </field-group> </search-result-list-page> </search-result-pages> </record-details> <reports> <root-object>Person</root-object> <tab-name>Reports</tab-name> <screen-id>6</screen-id> <display-order>5</display-order> <search-pages/> <search-result-pages/> <subscreen-configurations> <subscreen> <enable>true</enable> <root-object>Person</root-object> <tab-name>Potential Duplicate Report</tab-name> <report-name>Potential Duplicate</report-name> <screen-id>0</screen-id> <display-order>1</display-order> <search-pages/> <search-result-pages> <search-result-list-page> <search-result-id>0</search-result-id> <item-per-page>10</item-per-page> <max-result-size>2000</max-result-size> <field-group> <description/> <field-ref>Person.FirstName</field-ref> <field-ref>Person.LastName</field-ref> <field-ref>Person.SSN</field-ref> <field-ref>Person.DOB</field-ref> <field-ref>Person.Gender</field-ref> </field-group> </search-result-list-page> </search-result-pages> </subscreen> <subscreen> <enable>true</enable> <root-object>Person</root-object> <tab-name>Activity Report</tab-name> <report-name>Transaction Summary Report</report-name> <screen-id>2</screen-id> <display-order>2</display-order> <search-pages> <simple-search-page> <screen-title>Weekly Activity</screen-title> <report-name>Weekly Transaction Summary Report</report-name> <search-result-id>0</search-result-id> <search-screen-order>1</search-screen-order> <field-group/> </simple-search-page> <search-result-pages> <search-result-list-page> <search-result-id>0</search-result-id> <item-per-page>10</item-per-page> <max-result-size>2000</max-result-size> <field-group/> </search-result-list-page> </search-result-pages> </subscreen> </page-definition> </gui-definition>
