Skip Navigation Links
Exit Print View
Oracle Java CAPS Master Index Configuration Reference     Java CAPS Documentation
search filter icon
search icon
Document Information
Related Topics
About Oracle Java CAPS Master Index
Features of Oracle Java CAPS Master Index
Configuration Overview for Oracle Java CAPS Master Index
About the Configuration Files for Oracle Java CAPS Master Index
Master Index object.xml File
Master Index query.xml File
Master Index mefa.xml File
Master Index master.xml File
Master Index update.xml File
Master Index filter.xml
Master Index validation.xml File
Master Index security.xml File
Master Index edm.xml File
Match and Standardization Engine Configuration Files
Using the Editors for Oracle Java CAPS Master Index
XML Editors
Master Index Configuration Editor
The object.xml File
query.xml
master.xml
mefa.xml
update.xml
update.xml
edm.xml
Match Configuration File
Master Index Object Definition Configuration
Master Index Object Definition Components
Master Index Object Definition Objects
Master Index Object Definition Fields
Master Index Object Definition Relationships
The Master Index object.xml File
Modifying the Master Index Object Definition
The object.xml File Structure
object.xml File Description
object.xml Example
Query Configuration
Query Builder Components
Basic Queries in a Master Index
Blocking Queries in a Master Index
Blocking Query Block Processing
Blocking Query for Matching
Phonetic Queries in a Master Index
Range Searching
The query.xml File
Modifying query.xml
The query.xml File Structure
query.xml File Description
query.xml Example
Range Search Processing
Basic Query Range Searching
Blocking Query Range Searching
Blocking Query Offset Values
Blocking Query Constants
Blocking Query Offset and Constant Combinations
Manager Service Configuration
Manager Service Components
Master Controller Configuration
Custom Logic Classes in master.xml
Update Mode in master.xml
Merged Record Updates in master.xml
Blocking Query in master.xml
Transactional Support
Decision Maker
OneExactMatch
SameSystemMatch
DuplicateThreshold
MatchThreshold
EUID Generator
IdLength
ChecksumLength
ChunkSize
The master.xml File
Modifying master.xml
The master.xml File Structure
master.xml File Description
master.xml Example
Match Field Configuration
Matching Service Components
Standardization Configuration
Data Reformatting
Data Normalization
Phonetic Encoding
Matching Configuration
MEFA Configuration
Match and Standardization Engines
Block Picker and Pass Controller
Phonetic Encoders
Sample Standardization and Matching Sequence
The mefa.xml File
Modifying mefa.xml
The mefa.xml File Structure
mefa.xml Description
mefa.xml Example
Survivor Strategy Configuration
The Survivor Calculator and the SBR
Update Manager Components
Survivor Helper
Survivor Helper Default Strategy
Survivor Helper Weighted Strategy
Survivor Helper Union Strategy
Weighted Calculator
Weighted Calculator SourceSystem Strategy
Weighted Calculator SystemAgreement Strategy
Weighted Calculator MostRecentModified Strategy
Update Manager Policies
Update Manager Update Policies
Update Manager Update Policy Flag
The update.xml File
Modifying update.xml
The update.xml File Structure
update.xmlFile Description
update.xml Example
Weighted Calculator Logic
SBR, Matching, and Blocking Filter Configuration
Master Index Field Filters
SBR Filters
Blocking Query Filters
Match String Filters
Exclusion Lists
The filter.xml File
Modifying filter.xml
filter.xml File Structure
filter.xml Example
Field Validation Configuration
The validation.xml File
Modifying validation.xml
validation.xml File Structure
update.xml Example
Master Index Data Manager Configuration
About the MIDM
MIDM Configuration Components
Object and Field Properties
Relationship Properties
Display Properties
Page Display Properties
Audit Log
Local ID Labels
Search Page Configuration
Implementation Configuration
The midm.xml File Structure
Modifying midm.xml
midm.xml File Description
midm.xml File Example
Master Index Field Notations
ePath Notation
ePath Syntax
ePath Notation Example
Qualified Field Name Notation
Qualified Field Name Syntax
Qualified Field Name Example
Simple Field Name Notation
Simple Field Notation Syntax
Simple Field Notation Example
You can define custom logic for field validations and then specify them in validation.xml to associate the logic with the master index application. The custom logic is created as a Java class by defining custom Java classes in the Source Package folder of the EJB project. The custom validation classes must implement com.sun.mdm.index.objects.validation.ObjectValidator. The exception thrown is com.sun.mdm.index.objects.validation.exception.ValidationException.
The following topics describe the structure of validation.xml and provide information about custom field validators.
By default, validation.xml defines one validation rule named validate-local-id. This rule defines certain validations that are performed against local ID and system fields before they are entered into the database. The local ID validator verifies that the system code is valid, the local ID format is correct, the local ID is the correct length, and that neither field is null.
The following topics provide information about working with the validation.xml:
You can modify validation.xml using the XML editor. The possible modifications to this file are restricted by the schema definition, so be sure to validate the file after making any changes. When you modify this file, you must regenerate the application and redeploy the project for the changes to take effect.
validation.xml consists primarily of a list of rules. Each rule is defined within the ValidationConfig element and is defined by attributes within a rules element. Table 13 describes the elements and attributes of validation.xml.
Table 13 update.xml File Elements
Element or Attribute
Description
rules
The configuration information for the validation rules.
rule
The configuration information for a specific validation rule in a rules list.
rule/name
A rule attribute that specifies a name for the validation rule.
rule/object-name
A rule attribute that specifies the name of the class that defines the object to which the validation rule is applied, such as SystemObject or ParentNameObject (where ParentName is the name of the parent object in the Object Definition).
rule/class
A rule attribute that specifies the complete path of the Java class containing the validation rule.
update.xml Example
Plug the custom validation classes you create into the master index application by specifying the name of the custom plug-in for the class in validation.xml, as shown below.
<ValidationConfig module-name="Validation"
parser-class= "com.sun.mdm.index.configurator.impl.validation.ValidationConfiguration"
   <rules>
      <rule name="validate-auxiliary-id" object-name="PersonObject"
       class="com.sun.mdm.index.user.AuxiliaryId"/>
      <rule name="validate-birth-date" object-name="PersonObject"
       class="com.sun.mdm.index.user.BirthDate"/>
   </rules>
</ValidationConfig>
