Skip Navigation Links
Exit Print View
Sun Server X3-2L HTML Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Support and Accessibility
Site Planning
Preparing the Site for Installation
Server Specifications
Preparing the Facility
Installation
About the Installation Procedure
Installation Procedure Overview
About Server Features and Components
Server Components
UEFI BIOS
Front Panel Status Indicators, Connectors, and Drives
Back Panel Status Indicators, Connectors, Drives, and PCIe Slots
Preparing for Server Installation
Shipping Inventory
Optional Component Installation
Tools and Equipment Needed for Installation
ESD and Safety Precautions
Installing the Server Into a Rack
Installation Prerequisites
Rack Requirements
Safety Precautions When Rackmounting the Server
Rackmount Kit Contents
Stabilize the Rack for Installation
Install Mounting Brackets
Mark the Rackmount Location
Attach Tool-less Slide-Rail Assemblies
Install the Server Into the Slide-Rail Assemblies
Install the Second-Generation Cable Management Arm
Remove the Second-Generation Cable Management Arm
Install the First-Generation Cable Management Arm
Verify Operation of Slide-Rails and CMA
Cabling the Server
Rear Cable Connections and Ports
Ethernet Ports
Attaching Data Cables and Power Cords to the Server
Connecting to Oracle ILOM
Oracle ILOM Hardware and Interfaces
Network Defaults
Logging In to Oracle ILOM Using a Local Serial Connection
Logging In to Oracle ILOM Using a Remote Ethernet Connection
Accessing the Host Console Through Oracle ILOM
Troubleshooting the Service Processor Connection
Setting Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware
Setting Up an Operating System and Drivers
Configuring RAID
RAID Configuration Requirements
Configuring Server Storage Drives Into RAID Volumes Using Oracle System Assistant
Configuring RAID Using the BIOS Setup Utility
Configuring the Preinstalled Oracle Solaris 11 Operating System
Preinstalled Operating System RAID Limitations
Operating System Options
Configuration Worksheet
Configure the Preinstalled Oracle Solaris 11 Operating System
Oracle Solaris 11 Operating System Documentation
Configuring the Preinstalled Oracle Linux Operating System
Oracle Linux Configuration Worksheet
Configure the Preinstalled Oracle Linux Operating System
Register and Update Your Linux OS
Configuring the Preinstalled Oracle VM 3.x Software
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Configure the Preinstalled Oracle VM
Oracle VM Documentation
Troubleshooting Installation Issues
Power Off the Server for Orderly Shutdown
Power Off the Server for Immediate Shutdown
Reset the Server
Installation Troubleshooting
Technical Support Information Worksheet
Locating the System Serial Number
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Installing Updates
Oracle Solaris Installation
About Oracle Solaris Operating System Installs
Oracle Solaris OS Installation Task Map
Supported Operating Systems
Selecting the Console Display Option
Selecting the Boot Media Option
Selecting the Installation Target Option
Solaris OS Installation Options
Preparing to Install the Operating System
Setting Up BIOS
Configuring RAID
Installing the Oracle Solaris Operating System
Before You Begin
Installing the Oracle Solaris 10 or 11 Operating System on a Single System Using Media
Installing Updates
Oracle VM Installation
About Oracle VM Installs
Oracle VM Installation Task Map
Supported Oracle VM Software
Oracle VM Installation Options
Preparing to Install Oracle VM
Verify the BIOS Factory Defaults
Configuring RAID
Installing Oracle VM
Before You Begin
Installing Oracle VM on a Single System Using Oracle System Assistant
Installing Oracle VM on a Single System Using Media
Post Installation Tasks for Oracle VM
Configuring Network Interfaces
NIC Connectors
Installing Updates
Linux Installation
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Linux OS Installation Options
Setting Up BIOS
Configuring the SLES 11 SP1 Operating System Software to Support Network Connections
Configuring RAID
Installing the Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Installing Oracle Linux on a Single System Using Media
Installing Red Hat Enterprise Linux on a Single System Using Media
Installing SUSE Linux Enterprise Server on a Single System Using Media
NIC Connectors
Installing Updates
Windows Installation
About Windows Server 2008 Operating System Installs
Windows OS Installation Task Map
Supported Windows Operating Systems
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
Setting Up BIOS
Configuring RAID
Installing the Windows Server 2008
Before You Begin
Installing Windows OS on a Single System Using Oracle System Assistant
Installing Windows Server 2008 on a Single System Using Media
Post Installation Tasks for Windows Server 2008
Supplemental Software Component Options
Installing Device Drivers and Supplemental Software
Configuring Intel NIC Teaming
Installing Updates
VMware ESXi Installation
About VMware ESXi Installs
VMware ESXi Installation Task Map
Supported VMware ESXi Software
VMware ESXi Installation Options
Preparing to Install VMware ESXi
Setting Up BIOS
Configuring the VMware ESXi 5.0 Software or the Server Hardware to Support Network Connections
Configuring RAID
Installing VMware ESXi
Before You Begin
Installing VMware ESXi on a Single System Using Media
Post Installation Tasks for VMware ESXi
Configure Network Adapter Settings
Determine the MAC Address of a Connected Server Network Port
Update the VMware ESXi Software
Manage VMware ESXi Resources
NIC Connectors
Installing Updates
Service
About the Sun Server X3-2L
Product Description
About Controls and Connectors
About Server and Component LEDs
About System Components
Troubleshooting the Server
Service Troubleshooting Task List
Diagnostic Tools
Gather Service Information
Locate the Server Serial Number
Inspecting the System
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
Required Tools
Preparing the Server for Component Replacement
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Servicing Fan Modules (CRU)
Servicing Power Supplies (CRU)
Servicing CRUs That Require Server Power-Off
Servicing the DIMMs (CRU)
Servicing PCIe Cards (CRU)
Servicing the SAS Expander Module (CRU)
Servicing the Air Baffle (CRU)
Servicing the DVD Drive (CRU)
Servicing the Internal USB Flash Drives (CRU)
Servicing the Battery (CRU)
Servicing FRUs
Servicing Processors (FRU)
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Servicing the Front LED/USB Indicator Modules (FRU)
Servicing Cables (FRU)
Servicing the Motherboard Assembly (FRU)
Identifying the Server Ports
Gigabit-Ethernet Ports
Network Management Port
Serial Management Port
Video Connector
USB Ports
Server Filler Panel Requirements
Remove and Install Filler Panels
Install the Top Cover
Install the Fan Assembly Door
Remove Antistatic Measures
Reinstall the Server Chassis in the Rack
Reconnect Power and Data Cables
Power On the Server
Installing Updates
Administration
Planning the System Management Environment
Choosing Tools for Single System Management
Choosing Tools for Multiple System Management
System Management Tools Overview
Common System Management Tasks
Common System Administrative Tasks
Evaluating the Server Environment
Installing System Management Tools
System Management Documentation
Accessing System Management Tools
Accessing Oracle System Assistant
Accessing Oracle ILOM
Accessing Oracle Hardware Management Pack
Set Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware Using Oracle ILOM
Set Up Software and Firmware Using Oracle Hardware Management Pack
Setting Up the Server Using Oracle System Assistant
Organization of Oracle System Assistant
Configuring the Server Using Oracle System Assistant
View Oracle System Assistant ReadMe File
Exit From Oracle System Assistant
View System Information
View System Inventory Information
Configure Network Settings
Get Platform Software Release Updates
Configure MOS to Enable Oracle System Assistant Updates
Update Firmware
Configure Hardware for RAID
Configure Hardware for the Oracle ILOM SP
Install an Operating System
Set Preferences to Disable Oracle System Assistant
Set Preferences for Keyboard Language
Perform Advanced Tasks to Access Oracle System Assistant Shell
Perform Advanced Tasks to Check Media Integrity
Access Firmware and Software on the Oracle System Assistant USB Flash Drive
View Documentation From Oracle System Assistant
Mounting the Oracle System Assistant USB Flash Drive
Mount the Oracle System Assistant USB Flash Drive on Oracle VM 3.0
Mount the Oracle System Assistant USB Flash Drive on a Linux Operating System
Mount the Oracle System Assistant USB Flash Drive on an Oracle Solaris 10 Operating System
Troubleshooting Oracle System Assistant
Verify Oracle System Assistant Is Installed
Troubleshoot Oracle System Assistant Launch From Oracle ILOM
Restore Oracle System Assistant
Accessing the Oracle System Assistant Filesystem
Access the Oracle System Assistant Filesystem
Managing the Server Using Oracle ILOM
Oracle ILOM Features
Oracle ILOM Features for Oracle x86 Servers
Configuring RAID
Supported HBA Disk Controllers
RAID Configuration Options
Creating a RAID Volume Before Installing an Operating System
Creating a RAID Volume After Installing an Operating System
Using Oracle ILOM to Monitor Storage Devices
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
Using Legacy or UEFI BIOS
Using BIOS for Resource Allocation
Common BIOS Setup Utility Tasks
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS IO Menu Selections
BIOS Boot Menu Selections
UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
Identifying SNMP Trap Messages
Installing Updates
Index
You can view or modify a subset of the Oracle ILOM service processor (SP) settings.
Follow these steps to view or modify the Oracle ILOM SP settings using Oracle System Assistant.
  1. Click the Configure Hardware task button, then click the Service Processor Configuration tab.
    The Server Processor Configuration screen appears.
    image:This figure show the Service Processor Configuration screen.
  2. From the Select Task drop-down list, select a task:
    • Identification Information – See Step 3.
    • Network Information – See Step 4.
    • User Accounts – See Step 5.
    • Clock Settings – See Step 6.
    • DNS Settings – See Step 7.
  3. To view or modify Identification Information, complete the following information:
    1. SP Hostname
      Type the Oracle ILOM SP hostname.
      The hostname must start with a letter and can contain up to 60 alphanumeric characters, hyphens, and underscores.
    2. SP System Identifier
      Type the name that identifies the system. Use any characters except quotation marks.
    3. SP System Contact
      Type the name of the person to contact. Use any characters except quotation marks.
    4. SP System Location
      Type the name of the physical location of the system. Use any characters except quotation marks.
      image:This figure shows the Identification Information screen.
  4. To view or modify Network Information, complete the following information:
    Note - Complete the information for the network configuration you are using: either IPv4 or IPv6.
    1. IP Discovery Mode (IPv4)
      Select whether the system uses Dynamic Host Configuration Protocol (DHCP) or a static IP assignment.
    2. IP Address (IPv4)
      If you selected a static IP assignment, provide the IP address of the SP.
    3. Netmask (IPv4)
      If you selected a static IP assignment, provide the netmask for the SP.
    4. Gateway (IPv4)
      If you selected a static IP assignment, provide the gateway address for the SP.
      image:This figure show the Network Configuration screen.
    5. State (IPv6)
      Click the Enabled check box to enable IPv6 network settings.
    6. Autoconfig (IPv6)
      When enabled, the IPv6 Stateless autoconfiguration is run to learn the IPv6 addresses.
    7. DHCPv6 Autoconfig (IPv6)
      When enabled, the DHCPv6 Stateless autoconfiguration is run to learn the DNS and domain information.
      When enabled, the DHCPv6 Stateful autoconfiguration is run to learn the IPv6 addresses and DNS information.
      When enabled, the None state will only set the Link Local address in Oracle ILOM.
    8. Static IP Address (IPv6)
      This is the static IP address of the SP.
    9. Link-Local IP Address (IPv6)
      This is a non-routable address that you can use to connect to the SP from another IPv6 enabled node on the same network.
    10. Gateway (IPv6)
      This is the gateway address for the SP.
    11. Dynamic IP List
      This field is read-only. Oracle System Assistant gets these values from Oracle ILOM.
  5. To view or modify local Oracle ILOM User Accounts, complete the following information:
    1. Add User
      Click the Add User button to add a new local user account. Type a unique user name, select the role (Basic or Advanced) from the drop-down list, set privileges, and type the password.
      Note - If you want to choose specific privileges (not preset) for the user, choose Advanced.
    2. Modify user
      Highlight a user account in the list and click Modify User to review or change the local user account settings.
    3. Delete User
      Highlight a user account in the list and click Delete User to delete a local user account.
      image:This figure show the User Accounts screen.
  6. To view or modify Clock Settings, complete the following information:
    1. Date
      Use the drop-down list to select the month, day, and year.
    2. Time
      Use the drop-down list to set the time using 24-hour format.
    3. Timezone
      Use the drop-down list to select the timezone.
    4. Synchronize Time Using NTP
      Click the check box to enable synchronization with a Network Time Protocol (NTP) server.
    5. Server 1, Server 2
      Enter the information for the NTP servers.
      image:This figure shows the Clock Settings screen.
  7. To view or modify DNS settings, complete the following information.
    1. Auto DNS via DHCP.
      Check enabled or disabled.
    2. DNS Server Name
      Edit this only if Auto DNS is disabled.
      Enter up to three comma-separated name server IP addresses in preferred order. For example, 1.2.3.4.5.6.7.8.
    3. DNS Search Path
      Enter up to six comma-separated search suffixes in preferred order. For example, abc.efg.com,efg.com.
    4. DNS Timeout
      Enter a value between 1 and 10. The default is 5.
    5. DNS Retries
      Enter a value between 0 and 4. The default is 1.
      image:This figure show the DNS Settings screen.
  8. Click Save Settings.
  9. If desired, click Exit to quit Oracle System Assistant and reboot or power off the server.
Related Information
