Skip Navigation Links
Exit Print View
Sun Server X3-2L HTML Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Getting the Latest Software and Firmware
About This Documentation
Related Documentation
Feedback
Access to Oracle Support
Site Planning
Preparing the Site for Installation
Server Specifications
Preparing the Facility
Installation
About the Installation Procedure
Installation Procedure Overview
About Server Features and Components
Server Components
Front Panel Status Indicators, Connectors, and Drives
Back Panel Status Indicators, Connectors, Drives, and PCIe Slots
Server Management Software Overview
Preparing for Server Installation
Shipping Inventory
Optional Component Installation
Tools and Equipment Needed for Installation
ESD and Safety Precautions
Installing the Server Into a Rack
Installation Prerequisites
Rack Requirements
Safety Precautions When Rackmounting the Server
Rackmount Kit Contents
Stabilize the Rack for Installation
Install Mounting Brackets
Mark the Rackmount Location
Attach Tool-less Slide-Rail Assemblies
Install the Server Into the Slide-Rail Assemblies
Install the Second-Generation Cable Management Arm
Remove the Second-Generation Cable Management Arm
Install the First-Generation Cable Management Arm
Cabling the Server
Rear Cable Connections and Ports
Ethernet Ports
Attaching Data Cables and Power Cords to the Server
Connecting to Oracle ILOM
Oracle ILOM Hardware and Interfaces
Network Defaults
Logging In to Oracle ILOM Using a Local Serial Connection
Logging In to Oracle ILOM Using a Remote Ethernet Connection
Accessing the Host Console Through Oracle ILOM
Troubleshooting the Service Processor Connection
Setting Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware
Setting Up an Operating System and Drivers
Configuring Server Drives for OS Installation
RAID Configuration Tools
RAID Configuration Requirements
Configuring Storage Drives Into RAID Volumes Using Oracle System Assistant
Configuring RAID Using the BIOS RAID Configuration Utilities
Configuring the Preinstalled Oracle Solaris 11 Operating System
Preinstalled Operating System RAID Limitations
Operating System Options
Oracle Solaris Configuration Worksheet
Configure the Preinstalled Oracle Solaris 11 Operating System
Oracle Solaris 11 Operating System Documentation
Configuring the Preinstalled Oracle Linux 6.x Operating System
Oracle Linux 6.x Configuration Worksheet
Configure the Preinstalled Oracle Linux Operating System
Register and Update Your Linux OS
Oracle Linux Operating System Documentation
Configuring the Preinstalled Oracle VM 3.x Software
Preinstalled Oracle VM Server and Oracle VM Manager Compatibility Requirements
Oracle VM Server Configuration Worksheet
Configure the Preinstalled Oracle VM
Oracle VM Documentation
Controlling System Power and Troubleshooting Installation Issues
Power Off the Server for Orderly Shutdown
Power Off the Server for Immediate Shutdown
Reset the Server
Installation Troubleshooting
Technical Support Information Worksheet
Locating the System Serial Number
Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Software Releases
Getting Firmware and Software from MOS or PMR
Installing Updates Using Other Methods
Oracle Solaris Installation
About Oracle Solaris Operating System Installs
Oracle Solaris OS Installation Task Map
Supported Operating Systems
Selecting the Console Display Option
Selecting the Boot Media Option
Selecting the Installation Target Option
Solaris OS Installation Options
Preparing to Install the Operating System
Setting Up BIOS
Configuring RAID
Installing the Oracle Solaris Operating System
Before You Begin
Installing the Oracle Solaris 10 or 11 Operating System on a Single System Using Media
Post Installation Tasks for Oracle Solaris
Software Releases
Getting Firmware and Software From MOS or PMR
Oracle VM Installation
About Oracle VM Installs
Oracle VM Installation Task Map
Supported Oracle VM Software
Oracle VM Installation Options
Single-Server Installation Methods
Preparing to Install Oracle VM
Verify the BIOS Factory Defaults
Configuring RAID
Installing Oracle VM
Before You Begin
Installing Oracle VM on a Single System Using Oracle System Assistant
Installing Oracle VM on a Single System Using Media
Post Installation Tasks for Oracle VM
Configuring Network Interfaces
NIC Connectors
Software Releases
Linux Installation
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Linux OS Installation Options
Oracle System Assistant Overview
Oracle System Assistant Tasks
Get Updates and Install OS Tasks
Obtaining Oracle System Assistant
Setting Up BIOS
Configuring the SLES 11 SP1 Operating System Software to Support Network Connections
Configuring RAID
Installing the Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Installing Oracle Linux on a Single System Using Media
Installing Red Hat Enterprise Linux on a Single System Using Media
Installing SUSE Linux Enterprise Server on a Single System Using Media
NIC Connectors
Software Releases
Windows Installation
About Microsoft Windows Server Operating System Installs
Windows OS Installation Task Map
Supported Windows Operating Systems
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
Windows OS Installation Options
Setting Up BIOS
Configuring RAID
Installing Windows Server Operating System
Before You Begin
Installing Windows Server on a Single System Using Oracle System Assistant
Installing Windows Server on a Single System Using Media
Post Installation Tasks for Windows Server
Supplemental Software Component Options
Installing Device Drivers and Supplemental Software
Configuring Intel NIC Teaming
Software Releases
VMware ESXi Installation
About VMware ESXi Installs
VMware ESXi Installation Task Map
Supported VMware ESXi Software
VMware ESXi Installation Options
Preparing to Install VMware ESXi
Setting Up BIOS
Configuring the VMware ESXi 5.0 Software or the Server Hardware to Support Network Connections
Configuring RAID
Installing VMware ESXi
Before You Begin
Installing VMware ESXi on a Single System Using Media
Post Installation Tasks for VMware ESXi
Configure Network Adapter Settings
Determine the MAC Address of a Connected Server Network Port
Update the VMware ESXi Software
Manage VMware ESXi Resources
NIC Connectors
Software Releases
Service
About the Sun Server X3-2L
Product Description
About Controls and Connectors
About Server and Component LEDs
About System Components
Troubleshooting the Server
Service Troubleshooting Task List
Diagnostic Tools
Gather Service Information
Locate the Server Serial Number
Inspecting the System
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
Required Tools
Preparing the Server for Component Replacement
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Servicing Fan Modules (CRU)
Servicing Power Supplies (CRU)
Servicing CRUs That Require Server Power-Off
Servicing the DIMMs (CRU)
Servicing PCIe Cards (CRU)
Servicing the SAS Expander Module (CRU)
Servicing the Air Baffle (CRU)
Servicing the DVD Drive (CRU)
Servicing the Internal USB Flash Drives (CRU)
Servicing the Battery (CRU)
Servicing FRUs
Servicing Processors (FRU)
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Servicing the Front LED/USB Indicator Modules (FRU)
Servicing Cables (FRU)
Servicing the Motherboard Assembly (FRU)
Identifying the Server Ports
Gigabit-Ethernet Ports
Network Management Port
Serial Management Port
Video Connector
USB Ports
Server Filler Panel Requirements
Remove and Install Filler Panels
Install the Top Cover
Install the Fan Assembly Door
Remove Antistatic Measures
Reinstall the Server Chassis in the Rack
Reconnect Power and Data Cables
Power On the Server
Software Releases
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Administration
Planning the System Management Environment
Choosing Tools for Single System Management
Choosing Tools for Multiple System Management
System Management Tools Overview
Common System Management Tasks
Common System Administrative Tasks
Evaluating the Server Environment
Installing System Management Tools
System Management Documentation
Accessing System Management Tools
Accessing Oracle System Assistant
Accessing Oracle ILOM
Accessing Oracle Hardware Management Pack
Set Up Software and Firmware Using Oracle System Assistant
Set Up Software and Firmware Using Oracle ILOM
Set Up Software and Firmware Using Oracle Hardware Management Pack
Setting Up the Server Using Oracle System Assistant
Organization of Oracle System Assistant
Configuring the Server Using Oracle System Assistant
Mounting the Oracle System Assistant USB Flash Drive
Troubleshooting Oracle System Assistant
Accessing the Oracle System Assistant Filesystem
Managing the Server Using Oracle ILOM
Oracle ILOM Features
Oracle ILOM Features for Oracle x86 Servers
Configuring RAID
Supported HBA Disk Controllers
RAID Configuration Options
Creating a RAID Volume Before Installing an Operating System
Creating a RAID Volume After Installing an Operating System
Using Oracle ILOM to Monitor Storage Devices
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
Using Legacy BIOS or UEFI
Using BIOS for Resource Allocation
Common BIOS Setup Utility Tasks
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS IO Menu Selections
BIOS Boot Menu Selections
UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
Identifying SNMP Trap Messages
Software Releases
Index
  1. Go to the following web site: http://support.oracle.com.
  2. Sign in to My Oracle Support.
  3. At the top of the page, click the Patches & Updates tab.
    The Patch search pane appears at the right of the screen.
  4. Within the Search tab area, click Product or Family (Advanced Search).
    The Search tab area appears with search fields.
  5. In the Product field, select the product from the drop-down list.
    Alternatively, type a full or partial product name until a match appears. For example, Sun Server X3-2L (formerly Sun Fire X4270 M3).
  6. In the Release field, select a software release from the drop-down list.
    Expand the list to see all available software releases.
  7. Click Search.
    The Patch Advanced Search Results screen appears, listing the patches for the software release.
    See Software Releases for a description of the available downloads.
  8. To select a patch for a software release, click the patch number next to the software release version
    You can use the shift key to select more than one patch).
    A pop-up action panel appears. The pop-up panel contains several action options, including the ReadMe, Add to Plan, and Download options. For information about the Add to Plan option, click on the associated drop-down button and select “Why use a plan?”
  9. To review the ReadMe file for the patch, click ReadMe.
  10. To download the patch for the software release, click Download.
    The File Download dialog box appears.
  11. In the File Download dialog box, click the patch zip file name.
    The patch for the software release downloads.
