Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Data Service for Apache Guide     Oracle Solaris Cluster 4.0
search filter icon
search icon
Document Information
Preface
1.  Installing and Configuring Oracle Solaris Cluster HA for Apache
Planning the Installation and Configuration
Overview of the Installation and Configuration Process for Oracle Solaris Cluster HA for Apache
Installing and Configuring Apache
Installing a Non Secure Apache Web Server
How to Install and Configure the Apache Software From the Oracle Solaris CD-ROM
How to Install and Configure the Apache Software from the Apache Web Site
Installing the HA for Apache Package
How to Install the HA for Apache Package
Registering and Configuring Oracle Solaris Cluster HA for Apache
Setting Oracle Solaris Cluster HA for Apache Extension Properties
Monitoring Arbitrary URIs
Example-- Setting Monitor_Uri_List for Scalable HA for Apache Instance
Example-- Setting Monitor_Uri_List for Failover HA for Apache Instance
Tools for Registering and Configuring HA for Apache
How to Register and Configure the Oracle Solaris Cluster HA for Apache by Using clsetup
How to Register and Configure Oracle Solaris Cluster HA for Apache Using Oracle Solaris Cluster Command Line Interface (CLI)
How to Configure SUNW.HAStoragePlus Resource Type
How to Verify Data Service Installation and Configuration
Tuning the Oracle Solaris Cluster HA for Apache Fault Monitor
Operations by the Oracle Solaris Cluster HA for Apache Fault Monitor
Operations by the Fault Monitor Before a Probe
Operations for a Non Secure Web Server
Operations for a Monitored URI List
Actions in Response to Faults
Upgrading the SUNW.apache Resource Type
Information for Registering the New Resource Type Version
Information for Migrating Existing Instances of the Resource Type
A.  HA for Apache Extension Properties
Index
Before you install Oracle Solaris Cluster HA for Apache, update the following information in the Apache configuration file httpd.conf.
Note - The location of the httpd.conf file varies according to installation. System administrators typically install the httpd.conf file on the cluster file system. When installing the Apache package bundled with Oracle Solaris, the file is located in the /etc/apache2/2.2 directory.
Note - If you run Oracle Solaris Cluster HA for Apache and another HTTP server, configure the HTTP servers to listen on different ports. Otherwise, a port conflict can occur between the two servers.
To register and configure Oracle Solaris Cluster HA for Apache, you must consider or provide information on the following points.
