Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Data Service for Apache Guide Oracle Solaris Cluster 4.0 |
1. Installing and Configuring Oracle Solaris Cluster HA for Apache
Planning the Installation and Configuration
Installing and Configuring Apache
Installing a Non Secure Apache Web Server
How to Install and Configure the Apache Software From the Oracle Solaris CD-ROM
How to Install and Configure the Apache Software from the Apache Web Site
Installing the HA for Apache Package
How to Install the HA for Apache Package
Registering and Configuring Oracle Solaris Cluster HA for Apache
Setting Oracle Solaris Cluster HA for Apache Extension Properties
Example-- Setting Monitor_Uri_List for Scalable HA for Apache Instance
Example-- Setting Monitor_Uri_List for Failover HA for Apache Instance
Tools for Registering and Configuring HA for Apache
How to Register and Configure the Oracle Solaris Cluster HA for Apache by Using clsetup
How to Configure SUNW.HAStoragePlus Resource Type
How to Verify Data Service Installation and Configuration
Tuning the Oracle Solaris Cluster HA for Apache Fault Monitor
Operations by the Oracle Solaris Cluster HA for Apache Fault Monitor
Operations by the Fault Monitor Before a Probe
Operations for a Non Secure Web Server
Operations for a Monitored URI List
Upgrading the SUNW.apache Resource Type
Information for Registering the New Resource Type Version
Information for Migrating Existing Instances of the Resource Type
The table below lists the sections that describe the installation and configuration tasks.
Table 1-1 Task Map: Installing and Configuring Oracle Solaris Cluster HA for Apache
