Skip Navigation Links
Exit Print View
man pages section 9: DDI and DKI Driver Entry Points     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
Introduction
Driver Entry Points
aread(9E)
attach(9E)
audio_engine_channels(9E)
audio_engine_chinfo(9E)
audio_engine_close(9E)
audio_engine_count(9E)
audio_engine_format(9E)
audio_engine_open(9E)
audio_engine_playahead(9E)
audio_engine_qlen(9E)
audio_engine_rate(9E)
audio_engine_start(9E)
audio_engine_stop(9E)
audio_engine_sync(9E)
awrite(9E)
chpoll(9E)
close(9E)
csx_event_handler(9E)
detach(9E)
devmap(9E)
devmap_access(9E)
devmap_contextmgt(9E)
devmap_dup(9E)
devmap_map(9E)
devmap_unmap(9E)
dump(9E)
_fini(9E)
getinfo(9E)
gld(9E)
gldm_get_stats(9E)
gldm_intr(9E)
gldm_ioctl(9E)
gldm_reset(9E)
gldm_send(9E)
gldm_set_mac_addr(9E)
gldm_set_multicast(9E)
gldm_set_promiscuous(9E)
gldm_start(9E)
gldm_stop(9E)
identify(9E)
_info(9E)
_init(9E)
ioctl(9E)
ks_snapshot(9E)
ks_update(9E)
mac(9E)
mac_capab_rings(9E)
mac_group_info(9E)
mac_ring_info(9E)
mc_getcapab(9E)
mc_getprop(9E)
mc_getstat(9E)
mc_ioctl(9E)
mc_multicst(9E)
mc_propinfo(9E)
mc_setpromisc(9E)
mc_setprop(9E)
mc_start(9E)
mc_stop(9E)
mc_tx(9E)
mc_unicst(9E)
mgi_addmac(9E)
mgi_add_vlanfilter(9E)
mgi_getsriov_info(9E)
mgi_remmac(9E)
mgi_rem_vlanfliter(9E)
mgi_setmtu(9E)
mgi_start(9E)
mgi_stop(9E)
mmap(9E)
mr_gaddring(9E)
mr_gget(9E)
mr_gremring(9E)
mri_intr_disable(9E)
mri_intr_enable(9E)
mr_rget(9E)
open(9E)
power(9E)
prefix_ring_poll(9E)
prefix_ring_start(9E)
prefix_ring_stat(9E)
prefix_ring_stop(9E)
prefix_ring_tx(9E)
print(9E)
probe(9E)
prop_op(9E)
put(9E)
quiesce(9E)
read(9E)
segmap(9E)
srv(9E)
strategy(9E)
tran_abort(9E)
tran_bus_reset(9E)
tran_destroy_pkt(9E)
tran_dmafree(9E)
tran_getcap(9E)
tran_init_pkt(9E)
tran_pkt_constructor(9E)
tran_pkt_destructor(9E)
tran_quiesce(9E)
tran_reset(9E)
tran_reset_notify(9E)
tran_setcap(9E)
tran_setup_pkt(9E)
tran_start(9E)
tran_sync_pkt(9E)
tran_teardown_pkt(9E)
tran_tgt_free(9E)
tran_tgt_init(9E)
tran_tgt_probe(9E)
tran_unquiesce(9E)
write(9E)
mac_ring_info
, prefix_ring_start
, prefix_ring_stop
, prefix_ring_tx
, prefix_ring_poll
, prefix_ring_stat
, mri_intr_enable
, mri_intr_disable
- MAC ring info driver entry points
Synopsis
#include <sys/mac_provider.h>
int prefix_ring_start(mac_ring_driver_t ring_handle, uint64_t gen_num);
void prefix_ring_stop(mac_ring_driver_t ring_handle);
mblk_t *prefix_ring_tx(void *arg, mblk_t *mp);
mblk_t *prefix_ring_poll(void *arg, int nbytes, int npackets);
int prefix_ring_stat(mac_ring_driver_t ring_handle, uint_t stat,
      uint64_t *val);
int mri_intr_enable(mac_intr_handle_t *ihandle);
int mri_intr_disable(mac_intr_handle_t *ihandle);
Parameters
ring_handle
The opaque handle to the driver's representation of the specified ring.
gen_num
Generation number for this ring.
arg
Opaque handle to the driver's ring.
mblk_t
Chain of mblk packet buffers.
nbytes
The number of total bytes that will be polled for this call to prefix_ring_poll().
npackets
The maximum number of packets that will be returned for this call to prefix_ring_poll().
statsp
The pointer to the ring statistic being queried.
ihandle
The opaque handle to the driver private data representing this interrupt.
Interface Level
Solaris architecture specific (Solaris DDI).
Description
The prefix_ring_start() function is the driver entry point called by the MAC layer to start the ring processing packets. The prefix_ring_stop() function is the driver entry point called by the MAC layer to stop the ring processing packets.
The mri_stop() function is the driver entry point called by the MAC layer to stop the ring processing packets
The prefix_ring_tx() function is the driver entry point called by the MAC layer to transmit packets. This is a TX ring only entry point.
The prefix_ring_poll() function is the driver entry point called by the MAC layer to poll for the reception of incoming packets. This is RX ring only driver entry point. Packets are returned to the MAC layer as a chain of mblks. The parameters of nbytes is used to cap the number of bytes that can be polled while the npackets parameters caps the number of packets that can be polled.
The prefix_ring_stat() function is the driver entry point called to get various ring statistics. Statistics included for TX/RX rings:
MAC_STAT_OERRORS
MAC_STAT_OBYTES
MAC_STAT_OPACKETS
MAC_STAT_IERRORS
MAC_STAT_IBYTES
MAC_STAT_IPACKETS
The mri_intr_enable() function is the driver entry point called by the MAC layer to enable interrupts to re-enable interrupts while transitioning the ring from polling mode to interrupt mode. This is an RX ring entry point.
The mri_intr_disable() function is the driver entry point called by the MAC layer to disable interrupts for the specified ring while transitioning the ring to polling mode.
Return Values
The prefix_ring_start() function returns 0 on success and EIO when the operation fails.
The prefix_ring_tx() function returns NULL if all packets are transmitted. It returns some or all of the mblk chain if some or all of the packets where processed.
The prefix_ring_poll() function returns It returns a chain of packets received during this poll call or NULL if no packets where received.
The prefix_ring_stat() function returns 0 on success and ENOTUSP if the statistic is not supported.
The mri_intr_enable() function returns 0 on success.
The mri_intr_disable() function returns 0 on success.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
system/header
Interface Stability
Committed
See Also
attributes(5), mac_capab_rings(9S), mac_register(9S)
