Skip Navigation Links
Exit Print View
SPARC M5-32 and SPARC M6-32 Servers Security Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Understanding Hardware Security
Understanding Software Security
Prevent Unauthorized Access (Oracle Solaris OS)
Prevent Unauthorized Access (Oracle ILOM)
Prevent Unauthorized Access (Oracle VM Server for SPARC)
Restricting Access (OpenBoot)
Implement Password Protection (OpenBoot)
Check for Failed Logins (OpenBoot)
Provide a Power-On Banner (OpenBoot)
Oracle System Firmware
Secure WAN Boot
The Oracle system firmware uses a controlled update process to prevent unauthorized modifications. Only the superuser or an authenticated user with proper authorization can use the update process.
For information about obtaining the latest updates or patches, refer to the product notes for your server.
