Go to main content
Sun Storage 16 Gb Fibre Channel ExpressModule Universal Host Bus Adapter, QLogic Installation Guide For HBA Model 7101682
Exit Print View
Updated: July 2018
Installing Software for the Windows OS
Before using the universal HBA, check the Oracle support area of the QLogic web site for the latest drivers. The drivers and utilities, as well as their associated Readme files, are located at: http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
To Install the Universal HBA Software for the Windows OS
  1. Go to the Oracle support area of the QLogic web site at: http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/Oracle_Search.aspx
  2. Perform a search for the universal HBA by using the HBA part number (7101682).
  3. Scroll to the Windows Driver section and locate the driver version that you want to download.
    If the universal HBA is running in CNA/FCoE mode, you might need to update both the FC/FCoE driver and the network driver that are available in this section.
  4. Click the driver version that you want to download, and then click Download Now.
  5. Save the file to a directory on the hard disk of the system.
  6. Follow the installation instructions in the Readme file associated with the driver to complete the driver installation.
  7. Repeat steps 1 through 6 for any additional Windows drivers and utilities that your system requires.
